TR2/3/3A Water pump issue
cammau29
1959 TR3a new water pump shaft snapped which holds pully with Woodruff key. Second pump key shears distroying inside of pully. Has anyone else had problems with Lucus Pump & Pully
sp53
Something is not correct perhaps a bent pulley something stuck in a pulley like a rock or a really bad alignment of the pulleys
charleyf
The most common cause of such pump failures is having the belt to tight. You will be surprised just how loose the belt can be and still run the water pump and generator. Watch your amp gauge to see that the generator is charging after loosening the belt. Easy to spot.
Charley
bobhustead
I had an aftermarket pump in which the keyway was 5mm, while the original is 1/8 inch. Either of the conditions you report could be brought on by this mismatch. A machine shop can easily widen the keyway.
Bob
DavidApp
The pully needs to be a very good fit on the pump shaft. A tight push fit. Any play between the pully and shaft will allow the pully to wobble a little as it turns. This will put a lot of load on the threaded portion of the shaft. Also there is an extra thick washer under the nut.
I got a 5 vane pump from TRF that has a larger diameter thread than the original pump. I also got a new pully but I did notice that the woodruff key supplied did not match both the pully and shaft. It was to narrow for the pully. I bought a new key that fit the pully and carefully filed the key to fit the shaft key slot taking an equal amount off both sides of the key.
The photo is of the two shaves showing the thread difference.
David
Frank Canale
Thank you for the pictures and information about the beefier shaft, That is a big difference. Frank
bobhustead
I believe that the malfitting keyway on my pump was 3mm, not 5mm. David's fix apparently accommodated the same problem.
Bob
DavidApp
When I rebuilt my engine I put a new pump in it as the old pump bearings were shot but used the original pully. Everything seemed to fit ok.
After a club drive where a fellow member's TR3A water pump failed at the threaded section of the shaft I went back and gave my one a second look. The old pulley had a small amount of play in its fit on the shaft and with the amount the pully overhangs I could see that the pully would wobble a little with every revolution possible causing the thread to fail.
That is why I replaced both the pump and pully. The pully fit was tight. Not a press fit but a tight push fit.
David
Sarastro
I think you are using the same pump I used: the infamous "improved" one with the five-blade impeller.
I found that the slot in the shaft was sized for a no. 5 SAE key (1/8" thick), but a 3mm key was supplied. I got the right key, but then it didn't fit into the pulley well; I had to grind the edges of the key. I also found that the pump body interfered with the pulley and had to be ground down a little in a couple places. Finally, the nyloc nut and washer were not sized right; the nut would not thread onto the shaft enough to engage the locking part. All these problems can be fixed, as long as you know about them. But it's still annoying.
Yes, the pulley absolutely must fit tightly, with no wobble or slack.
matmire Replacement Water pump issue Spridgets 5
Michael Oritt Water Pump Recommendations Austin Healey 1
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
M 1500 Midget water pump weep hole Spridgets 2
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
KVH General Tech Water Pump Triumph 3
T TR2/3/3A Moss uprated water pump Triumph 6
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Aussiea40 A40 water pump British Motor Corp 7
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
AngliaGT Water Pump Recommendations? Other Cars 2
nevets Water Pump Installation Austin Healey 9
drooartz Hose from water pump to head, remove water pump? Spridgets 12
nevets Water Pump Removal Austin Healey 6
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Water pump Austin Healey 5
George Zeck Water Pump ? Spridgets 5
nichola TR6 Resurrecting a water pump, worth it? Triumph 7
D TR2/3/3A extra hole in my water pump? Triumph 3
JPSmit water pump installation Spridgets 6
Michael Oritt Water Pump Leak Austin Healey 41
Kleykamp TR2/3/3A Water pump gasket sealant??? Triumph 5
F Water pump replacement on my BT7 advice needed please Austin Healey 18
D Lotus Elan S4, From water pump...to a strip down.. Lotus 2
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
D TR2/3/3A TR3 water pump question Triumph 4
S For Sale BJ8 Water pump for sale Austin Healey Classifieds 4
Got_All_4 TR2/3/3A Water Pump "Here I Go Again" Triumph 61
G Water Pump Failure - Diagnostic Steps? Austin Healey 16
G Wanted TR4 Water Pump Housing and Fuel Line Triumph Classifieds 3
Got_All_4 TR2/3/3A Water pump problem Triumph 7
Gordon_Dedrick TR2/3/3A TR3 Water pump replacement Triumph 5
C Healey BN6 water pump and overheating problems Austin Healey 11
K TR4/4A Water pump and water pump housing bolts..... Triumph 3
A TR2/3/3A Uprated pulley kit with uprated 6 blade water pump problems. Triumph 7
histerical Water Pump Spridgets 1
D TR4/4A water pump mystery hole Triumph 6
T TR2/3/3A Water Pump Housing Bypass Triumph 11
B TR2/3/3A end of me water pump thread Triumph 2
B TR2/3/3A Replacement or rebuild kit for water pump Triumph 11
B TR2/3/3A Water pump color Triumph 4
vickxxx TR2/3/3A new water pump noisy after 6 months Triumph 5
2 TR2/3/3A Classic Gold TR2-4 water pump Triumph 5
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
Got_All_4 TR2/3/3A Water pump dissasembly Triumph 10
L Trouble refitting pulley to new water pump Spridgets 9
JFS TR2/3/3A Bad Water Pump Triumph 11
tomshobby replacing water pump Spridgets 1
