MGB 1977 MGB Antenna Installation???
Alfletch
I remove the broken antenna and tried to push the new antenna lead thru the hole inside the fender but there seem to be a metal plate covering the hole and preventing the antenna lead from going thru the hole. I removed the side panel inside the car where you would expect the antenna lead to enter the car and there is no sign of a hole!!!
Do I need to remove the instrument consol?
90 XJ-S
Alf,
No, the wire should come in behind the dress panel.
Try this, go to the radio, find the antenna wire. disconnect it and start pushing it out backwards until you come to where it enters the cabin.
Mike
A
Alfletch
Glad to know I don't have to remove the console.
My car is a left hand drive. The dress panel by my left foot? I removed that out of the way with some difficulty and had someone push the lead from the outside to the inside of the car but the lead would not go thru the hole.
I don't know where the antenna should emerge in the car!!! High up on the left side of the console?
90 XJ-S
[ QUOTE ]
The dress panel by my left foot? I removed that out of the way with some difficulty ... I don't know where the antenna should emerge in the car!!! High up on the left side of the console?
[/ QUOTE ]
Your on the right track!!
Just slightly below the level of the dash about 200mm in from the front of the door.
Do you still have the black panels underneath the dash? I'm not 100% sure but that might hide it.
Like I said, find the antenna Wire at the back of the radio and follow the wire backwards to the antenna. That HAS to find where it come through.
Mike
JTB
Assuming antenna mounts on fender behind the splash guard at the back of the wheel well, remove that splash guard ( about 6 to 8 bolts) which should give you access to see where exactly it goes into car which should be just behind the top of the inside panel...then route it up behind dash and down to radio. I replaced mine twice.
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
B MGB 1977 MGB Battery Box and Shifter knob MG 4
Celtic 77 MGB 1977 MGB Brake issues MG 8
L MGB Rebuilding a 1977 MGB MG 1
L MGB 1977 MGB will only run on full choke MG 53
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
Y MGB 1977 MGB Ignition Coil and Wiring. MG 7
Boggsy64 MGB Driving 1977 MGB 2000+ miles any concerns I should look in to?? MG 13
6 MGB 1977 MGB Exhaust Leak MG 0
QuickSilver MGB What size is the steering wheel on a 1977 MGB? MG 9
A MGB MGB 1977 oil pressure problem MG 31
A MGB 1977 MGB oil pressure problem MG 0
C MGB Console tunnel - 1977 - 1980 MGB MG 5
tony barnhill MGB The 1977 MGB "Survivor" MG 22
C MGB 1977 MGB Electrical Problems - fuse box MG 4
A MGB trying to locate the ignition relay on a 1977 mgb MG 4
kyreb1862 MGB 1977 MGB Intake MG 7
kyreb1862 MGB 1977 MGB Master Cylinder MG 0
kyreb1862 MGB 1977 MGB Brake Master Cylinder Identification MG 7
A MGB What is this in a 1977 MGB? MG 14
C T-Series 1977 MGB ignition switch MG 4
kyreb1862 MGB 1977 MGB MG 9
J MGB WTB: 1977 MGB intake/exhaust manifold MG 7
A MGB Buying 1977 MGB Advice Needed MG 3
1 MGB My new 1977 MGB? cant turn distributor MG 3
1 MGB color of carpet for 1977 MGB MG 4
Celtic 77 MGB 1977 seat webbing replacement. MG 1
M 1977 MG Midget 1500 Problem Spridgets 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
B 1977 Midget Bra Spridgets 9
FredApplerot For Sale Free: Midget sun visors to fit 1977-80 Spridgets Classified 1
kennypinkerton MGB 1977 VDO clock... can it be opened? MG 7
M MGB Tail lights do not work- 1977 MG 8
DrEntropy MGB 1977 B with some issues MG 3
J Spitfire 1977 Spitfire hard top Triumph 2
K 1977 924 Fuel Injection Other Cars 6
K 1977 Porsche 924 Other Cars 0
E 1977 Midget Weber carb FORUM Navigation Questions 0
E 1977 Midget Weber carb Spridgets 1
QuickSilver OT: Value Of A 1977 MG B Engine & Transmission MG 2
T MGB-GT 1977 MG BGT electrical MG 6
77_MG_Midget air pump on a 1977 1500 midget Spridgets 2
J 1977 MG HELP!!! Fluid issue MG 7
F what to do when you remove the bumper[1977] MG 4
Basil Panther/Jaguar 1977 Jaguar 2
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
