1977 924 Fuel Injection
K
KSIS
Below is the latest project. Swaping out the CIS sytem for a DIgifant system from a 92 GTI.
Before:
After:
Pretty happy with the performance. Almost looks like a factory install. Was pretty much a drop in system. No major modifcations that could not be undone to return to original. Even found that a Dodge Neon fuel rail drop right in.
jessebogan
So can you tell me how to do that on my 5 cylinder Audi??
K
KSIS
this system may work as the injectors are non sequencial when firing. Send me an email as i have a quick write up with a list of the parts needed. You'd be on your own for a fuel rail.
I will do some research and check into modifying a distributor and the hall sender signal.
Banjo
Impressive! That the silver Porsche in your driveway? I gotta stop by and check it out! I would never have thought to do something like that. Looks great!
K
KSIS
That will be my sons first car. Needed something reliable. We also pulled a F/I system from a SAAB and put that into a 924 turbo. Works pretty good!
stop on by. I'll show you the steering column from the spit also.
Banjo
Been there...hehehehe. Porsche looks great! you guys are doing some impressive things.
K
KSIS
Thanks for stopping by. Enjoyed the chat. The VW looks great, may have to find one for myself.
K 1977 Porsche 924 Other Cars 0
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
M 1977 MG Midget 1500 Problem Spridgets 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B 1977 Midget Bra Spridgets 9
Celtic 77 MGB 1977 MGB Brake issues MG 8
L MGB Rebuilding a 1977 MGB MG 1
L MGB 1977 MGB will only run on full choke MG 53
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
FredApplerot For Sale Free: Midget sun visors to fit 1977-80 Spridgets Classified 1
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
kennypinkerton MGB 1977 VDO clock... can it be opened? MG 7
Y MGB 1977 MGB Ignition Coil and Wiring. MG 7
M MGB Tail lights do not work- 1977 MG 8
DrEntropy MGB 1977 B with some issues MG 3
J Spitfire 1977 Spitfire hard top Triumph 2
Boggsy64 MGB Driving 1977 MGB 2000+ miles any concerns I should look in to?? MG 13
E 1977 Midget Weber carb FORUM Navigation Questions 0
E 1977 Midget Weber carb Spridgets 1
6 MGB 1977 MGB Exhaust Leak MG 0
QuickSilver OT: Value Of A 1977 MG B Engine & Transmission MG 2
QuickSilver MGB What size is the steering wheel on a 1977 MGB? MG 9
A MGB MGB 1977 oil pressure problem MG 31
A MGB 1977 MGB oil pressure problem MG 0
C MGB Console tunnel - 1977 - 1980 MGB MG 5
tony barnhill MGB The 1977 MGB "Survivor" MG 22
C MGB 1977 MGB Electrical Problems - fuse box MG 4
A MGB trying to locate the ignition relay on a 1977 mgb MG 4
T MGB-GT 1977 MG BGT electrical MG 6
kyreb1862 MGB 1977 MGB Intake MG 7
kyreb1862 MGB 1977 MGB Master Cylinder MG 0
kyreb1862 MGB 1977 MGB Brake Master Cylinder Identification MG 7
A MGB What is this in a 1977 MGB? MG 14
C T-Series 1977 MGB ignition switch MG 4
kyreb1862 MGB 1977 MGB MG 9
77_MG_Midget air pump on a 1977 1500 midget Spridgets 2
J 1977 MG HELP!!! Fluid issue MG 7
A MGB 1977 MGB Antenna Installation??? MG 4
J MGB WTB: 1977 MGB intake/exhaust manifold MG 7
A MGB Buying 1977 MGB Advice Needed MG 3
1 MGB My new 1977 MGB? cant turn distributor MG 3
1 MGB color of carpet for 1977 MGB MG 4
F what to do when you remove the bumper[1977] MG 4
Basil Panther/Jaguar 1977 Jaguar 2
JPSmit Porsche 924 question Other Cars 11
R TR2/3/3A Fuel pump? Triumph 8
AndreL TR6 Conversion to electric fuel pump Triumph 14
