Front end Alignment - Total Toe vs. Individual Toe
gonzo
Purchased 2 x 40in. angle iron (aluminum) and set about measuring total toe on my BJ 7. The 90 degree angle and some weights (two lead hammers) allow for a fairly solid mount flush to tire and floor. From the # of threads exposed on the center rod, the left and right tie rod ends appear to be turned in equally. Measurements taken from the front and back of the front tires showed a repeatable 1/8 in. total toe-in. This was encouraging. With the "string method" results were different: 3/16 in. toe-out on right and 0 toe on left. I wasn't confident determining toe in by string method, but wanted to measure individual toe.
Some Tenhulzen toe plates were ordered from Summit Racing (pic below) and are likely to reproduce the total toe-in determined with the inexpensive aluminum angle iron...we'll see. But the question still remains...how to measure individual toe? Any thoughts? GONZO
red57
Toe-in is the relationship of the right wheel to the left wheel - not sure what you would be relating a wheel to if not the other wheel?
Maybe in modern cars where they do 4 wheel alignment you could have a theoretical one-wheel toe as it relates to the vehicle centerline?
As far as the center rod, if you screwed one side in and the other side out, all you would do is change the steering wheel orientation, but when driving it would automatically split the difference from side to side and be equal - ie if you have an individual of 1/16", then you would have a total of 1/8".
I could be all wet on this though....
Dave
vette
This has always been my understanding of car alignment. A true or comprehensive front end alignment is aligning the wheels in relation to the center line of the car. If your frame or suspension has never been wrecked then adjusting the toe in or out of the front wheels relative to each other is an acceptable method to get toe adjustment. But it will be noted that at some point in different series of racing the cars have been aligned with a different toe-in relative to the center line to achieve different toe of each wheel to achieve different handling characteristic. Such things as a quicker entry into a turn as example. If you want to check comprehensive wheel tracking and alignment without a machine, then it is possible yet laborious, to do it with a set of strings. You want parallel strings down each side of the car. The car must be on a level surface and the strings are gauged off of the center point of the rear axles and the front spindles. With these parallel strings established then, for toe adjustment, measure the back rim bead of the front wheel to the string and the front rim bead of the front wheel to the string and you have your toe setting. At least this is the way I have understood it for many years. I have only had a need to check total alignment and tracking once in my life and that was on an MGA that was wrecked.
X Front End Alignment Austin Healey 14
B TR2/3/3A Front end alignment Triumph 23
M front end alignment Austin Healey 12
T TR4/4A Front end alignment specs for lowered car Triumph 2
S TR2/3/3A Front end alignment and tire wear Triumph 9
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
O TR2/3/3A TR3 front End Alignment Triumph 8
hondo402000 TR6 TR6 front end alignment and wheel balancing Triumph 4
S TR2/3/3A tr3 front end alignment Triumph 9
L Front end alignment Austin Healey 6
DrEntropy Anyone interested in DIY front-end alignment? Restoration & Tools 14
CraigLandrum TR2/3/3A TR3A Front End Alignment guru wanted Triumph 26
SCguy TR4/4A TR4 front end alignment Triumph 2
ronzet Speaking of front end alignment MG 20
G Front End Alignment Spridgets 41
PAUL161 Front End Alignment MG 8
bluemiata90 Brake shims/Rough front end alignment Triumph 4
R Front end alignment Triumph 2
M Spitfire Alignment on Spit Front End Triumph 6
G MGB '71 MGB Front End Rebuild MG 2
craigshealey3000 Front End Shake Austin Healey 31
B Bent frame rails near BE front end Spridgets 2
B 2013 Nissan Frontier front end mystery Other Cars 7
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
AUSMHLY BJ8 Front End Squeak Austin Healey 25
AUSMHLY 64 front end too high Austin Healey 14
thibault BJ8 plus 55mph Front end shaking Austin Healey 100
vette Effects of Lowering the Front End Austin Healey 21
R Front wheel bearing - end float Austin Healey 40
T For Sale For Sale: Bugeye Front End Spridgets Classified 0
K TR2/3/3A Front end woes... Triumph 18
S Wedge tr8 front end Triumph 0
Jim_Gruber Bugsy IV Front End Rebuild Spridgets 5
mcmillal TR4/4A Front End Vibration Triumph 9
K TR2/3/3A Front end Question.... Triumph 4
Joe Reed MGB Rattle under front end? MG 8
J MGB Project car done; front end clunk noise while braking MG 4
aeronca65t Minor front end work Spridgets 12
RAC68 Calculating Front Hub End-Play Austin Healey 32
aeronca65t front end maintenance Spridgets 5
bugedd Front end rebuilt help Spridgets 6
BlueMax Front End Completed Spridgets 23
bugedd About to rebuild front end...any tips? Spridgets 5
K TR2/3/3A Front end reassembly: trunnion spindles and wishbone bushes??? Triumph 10
BillyB62 TR2/3/3A TR3 front end shake Triumph 24
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
D XJ6 series III front end rattle Jaguar 5
Tr3aguy Front end rebuild questions>? Triumph 6
