Front end rebuilt help
bugedd
My soon to occur project of a front end rebuild just suffered a setback due to tragedy. My local Moss supplier about 5 years ago lost the owner to cancer. His wife has been continuing the business with an employee who had been with them since he was eighteen or so. Five weeks ago he was diagnosed with lung cancer, and two weeks ago he passed, only in his early 50's. Now there is no one in the store who knows the cars, and I no longer have a helper and friend that I can rely on. So I need your help :smile: The bugeye will need lower control arms I'm sure, as there is play at the inner mounts. Other than bushings, what else will I need to replace, and what should I inspect to see what I need to replace?
Wow, talk about tradgety! I'm sorry to hear about your friends in the business and pray for them. If your lower A arms are shot I would suggest a complete rebuild and I really like working with PeterC.
Rut
You're going to need a major suspension kit. Peter Caldwell at world wide imports in Madison, WI will take care if kingpin reaming. Withthe price drop in wishbones recently it's not cost effective to rebuild. I saw wishbones as low as $99.95 during a VB sale in the Fall. While you have things apart consider tie rod ends along with a new set of shocks from Peter C.
Okay, why do the kingpins need to be reamed? That's one part of the rebuild that has confused me.
The new bushings that are installed in the spindle assembly, aka stub axle, must be reamed for the new kingpins for proper fit. The old bushings must be pressed out and the new ones pressed in and it can be a pita.
Rut
Gotcha. That was something Mike was going to do for me. I would like to keep giving this shop business, but without a competent person, I may have to source out. Guess I should call Peter B.
Btw, smoking and a life long of working around chemicals/cars did Mike in. Makes you think about that Berryman Chemtool and venting the garage.
G MGB '71 MGB Front End Rebuild MG 2
X Front End Alignment Austin Healey 14
craigshealey3000 Front End Shake Austin Healey 31
B Bent frame rails near BE front end Spridgets 2
B 2013 Nissan Frontier front end mystery Other Cars 7
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
AUSMHLY BJ8 Front End Squeak Austin Healey 25
AUSMHLY 64 front end too high Austin Healey 14
thibault BJ8 plus 55mph Front end shaking Austin Healey 100
vette Effects of Lowering the Front End Austin Healey 21
G Front end Alignment - Total Toe vs. Individual Toe Austin Healey 3
R Front wheel bearing - end float Austin Healey 40
T For Sale For Sale: Bugeye Front End Spridgets Classified 0
K TR2/3/3A Front end woes... Triumph 18
S Wedge tr8 front end Triumph 0
B TR2/3/3A Front end alignment Triumph 23
Jim_Gruber Bugsy IV Front End Rebuild Spridgets 5
mcmillal TR4/4A Front End Vibration Triumph 9
K TR2/3/3A Front end Question.... Triumph 4
M front end alignment Austin Healey 12
T TR4/4A Front end alignment specs for lowered car Triumph 2
Joe Reed MGB Rattle under front end? MG 8
J MGB Project car done; front end clunk noise while braking MG 4
S TR2/3/3A Front end alignment and tire wear Triumph 9
aeronca65t Minor front end work Spridgets 12
RAC68 Calculating Front Hub End-Play Austin Healey 32
aeronca65t front end maintenance Spridgets 5
BlueMax Front End Completed Spridgets 23
bugedd About to rebuild front end...any tips? Spridgets 5
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
K TR2/3/3A Front end reassembly: trunnion spindles and wishbone bushes??? Triumph 10
BillyB62 TR2/3/3A TR3 front end shake Triumph 24
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
D XJ6 series III front end rattle Jaguar 5
Tr3aguy Front end rebuild questions>? Triumph 6
S Finally got my front end back together Triumph 5
O TR2/3/3A TR3 front End Alignment Triumph 8
RickB Box Spridget fiberglass front end - front mounting Spridgets 5
K TR6 TR6 front end Triumph 2
Burrell22 TR4/4A Tr4 front end help. Triumph 10
B Bugeye front end Spridgets 0
H Should I drop the front end down a little? Austin Healey 25
M Advice on doing a front end rebuild via kit? Spridgets 4
hondo402000 TR6 TR6 front end alignment and wheel balancing Triumph 4
S TR2/3/3A tr3 front end alignment Triumph 9
MY66AH Front end question Spridgets 9
regularman Has anyone here put a bugeye front end on a square Spridgets 2
bugedd Lowering front end Spridgets 8
