Brake Light - Getting them working
Jim_Gruber
So not getting brake lamps working. If I jump across the brake light switch should I not see lights come on. Are lights switched or not switched? Not seeing voltage on either side of the switch. Set up as positive ground presently. Thoughts on troubleshooting? Looks like it goes to post # 4 on the fuse box.
dklawson
One side should be "hot"... at least when the ignition is on. As you said, bridging the switch contacts should turn the brake lights on.
Jim_Gruber
Jim_Gruber
found a whole bunch of crud that I cleaned out. About to go try it. Update soon.
Jim_Gruber
Jim_Gruber
Voltage there now but still no joy if I short across the terminals. I think I need t oget a new brake light switch and then run a jumper direct to the rear lights after I check and clean the two unions they lie between there and the tail lamps. Might be time to put the rear wheels back on before I crawl into the boot with the car on jack stands. But on a positive note I pulled the choke on a little turned on the ignition. pulled the starter and beautiful Vroom, Vroom noises, I got to annoy my neighbors tonight, revving Bugsy in the garage. Nice sounds with headers and the muffler on it. And Rut I will take a video of starting up Bugsy for you. I know you are in Bugeye withdrawal right now until you get your engine back.
Desert Rat
How is it wired up? On the brake light switch the connection closet to radiator should be green, other should be green w/purple. Green goes to the fuse block green and purple to the brake lights.
JPSmit
Not remeb
mbering the colours but, the switch is just a switch - there is no polarity.
Bayless
If you jump across the switch terminals and still gt no lights, that tells you nothing about the switch, specifically it is not an indication of a bad switch.
Jim_Gruber
Jim_Gruber
You assume that a 56 y.o. Fabric Covered Wiring still has Fabric on it. Have voltage on one side of switch. Jumping across switch = still no brake lights. There are two connections in the boot I need to take apart and clean.
Bayless
You know you voltage voltage at one side of the switch. Jumping across the switch does make make good so there is something further downstream that is the problem. Possibly the connections in the boot or maybe more likely a bad ground.
G Brake Light Switch Failure Austin Healey 24
6 E-Type brake light pressure switch location Jaguar 5
K TR2/3/3A The two wires that go to the brake light stop switch junction......... Triumph 1
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Hamish Racing TR2/3/3A Remote brake light switch Triumph 5
B Brake light weirdness Dodge Ram Other Cars 5
D TR2/3/3A Brake light switch. Triumph 22
Boink Brake Light Switch... Spridgets 4
RAC68 Third *[3rd] Brake Light Austin Healey 11
K TR2/3/3A 3rd brake light question Triumph 3
L TR2/3/3A Brake light switch location Triumph 9
edkap2002 TR6 stop light [brake light] swith Triumph 9
T Adding a third brake-light Spridgets 5
D extra stop/brake light Austin Healey 33
T 3rd brake light again! Austin Healey 29
T TR2/3/3A 3rd. brake light set up Triumph 12
M TR2/3/3A Brake Light Switch Triumph 24
M_Pied_Lourd TR2/3/3A Brake Light Problem Triumph 9
maxwedge5281 third brake light ideas Austin Healey 34
Gerry M TR6 Brake warning light & oil pressure light stay on Triumph 2
M Brake Light Switch Austin Healey 14
7 brake warning light coming on Other Cars 5
Gerry M TR6 Brake Warning Light Stays On Triumph 3
AUSMHLY Watson Mechanical Brake Light Switch Austin Healey 13
J TR2/3/3A Add brake light to Rear turn signals Triumph 12
wkilleffer MGB MGB brake light switches lately MG 1
wkilleffer MGB brake light switches of late Restoration & Tools 3
Crankshaft TR2/3/3A Brake light wiring? Triumph 6
I TR6 Brake light on -reasons? Triumph 6
M TR2/3/3A Single brake light modifcation Triumph 2
D TR6 Brake light Triumph 3
N Brake light switch??? Spridgets 9
J MGB Electrical issue- turn signals dim and cause the brake warning light to flash MG 8
T 3rd brake light or LED's Austin Healey 28
alanjohnturner TR4/4A intermittent brake-light switch Triumph 11
mgedit TR2/3/3A Brake Light Switch 56 TR3 Triumph 3
J MGB Question on the brake warning light for 78 MGB MG 6
T TR2/3/3A What is thread size on TR3 brake light switch? Triumph 5
P Brake light switch Austin Healey 12
Gliderman8 Faded brake light lens Restoration & Tools 17
T TR6 TR 6 Brake light on Dash Triumph 4
D Spitfire MKII Spitfire brake light pblms Triumph 3
R more reliable brake light switch!?! Spridgets 13
AUSMHLY Stealth third brake light Austin Healey 26
BobbyD TR6 TR6 and other TRs - Brake Light Switch Alternative Triumph 7
tomshobby new brake light switch Spridgets 10
waltesefalcon Spitfire Spitfire brake light Triumph 3
K TR2/3/3A Generic TR3 Brake Light Switch? Triumph 3
T Third Brake Light Triumph 6
