MGB Electrical issue- turn signals dim and cause the brake warning light to flash
Jerry
1978 MGB. When you turn on the turn signals, the brake warning light flashes and the lights are very dim. Indicating a cross wire somewhere. The ignition switch was just replaced in this car and the problem started after the replacement. I pulled the plastic column off and the ignition switch appears to have been installed correctly.
Is there any way the turn signal stalk has become defective and somehow is feeding back though the other dash system? When this car was dropped off at my house, he turned off the key and the engine turned off, but the dash lights were still on. We had to unhook the battery to shut them off.
Looking for ideas please.
Jerry
My first inclination - as always is to check and clean all your grounds. That said, I have had two related issues with the Midget. I did have to take apart the stalk and clean, not so much the contacts, but the whole face. Current was creeping. Also i have had to disconnect my brake warning light sensor because it made the starter run on. Never could figure out why, even after i removed the diodes.
I was looking at the wiring diagram and I did find one loose wire this afternoon. A ground wire to the wiper pump. This ground is shared with other switches. So I will repair that and see what happens.
Jerry
Good first step is as JP says: Check all grounding points. Electrons are lazy. If the grounding leg of a circuit has resistance it will go for the next available path. That is usually through lightbulbs.
So the loose ground caused the turn signal issue, but another problem was left on the car. Someone had hot wired the car because the ignition was causing problems, or they so they thought. They installed a new ignition, but never took off the hot wire, so there was a hot lead going to all white wires, all the time. IE: the coil was hot, we were lucky it did not burn up the pertronix. all fixed now!
Jerry
Well found, Jerry.
I haven't dug too closely into my Millie GT's wiring yet -- I'm partly scared of what I might find, and your issue is a reminder of what can be done to these poor cars over the years.
Drew, yours is far less "complicated" than the later ones.
Yea, after working on this 1978 with all the smog equipment and extra safety switches, I must say that I would buy an earlier car if given the choice. But it runs again! I was going to take it back to the owner today but driving in weather that will hit 99 is not fun. He can wait.
Jerry
Well said, Jerry. :thumbsup:
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
N Electrical issue. FORUM Navigation Questions 2
S TR2/3/3A Electrical Issue Triumph 40
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
jmayzer electrical issue!!! who's surprised? Spridgets 7
busybrit Electrical tach issue on Aston Martin DB5 Other British Cars 2
Gordon_Dedrick TR2/3/3A 59 TR3A Intermittant electrical issue, Triumph 5
K Need some help, electrical issue Austin Healey 45
6 Electrical System Issue- Thougths Please Spridgets 6
B Stumped on Electrical Issue Restoration & Tools 6
BillyB62 TR2/3/3A TR3 Electrical issue - anything obvious? Triumph 11
R Electrical issue MG 14
bugedd Electrical Issue Spridgets 5
bugedd Electrical issue, with dancing fuel gauge! Spridgets 11
prb51 TR2/3/3A TR3 Electrical issue flasher unit Triumph 3
B TR6 Need guidance on TR6 electrical issue Triumph 7
Lin Electrical Issue - Need help Austin Healey 8
G Electrical Issue MG 4
RSMTR8 Wedge TR8 Electrical Issue Triumph 14
C TR2/3/3A TR3A Electrical problem Triumph 20
CARSINC Sprite Electrical System Information Spridgets 2
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
lram59 General Tech Electrical terminals Triumph 8
6 Electrical Help Please Spridgets 7
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
KVH General Tech O/D Electrical Wire Burned Triumph 22
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
E GT6 Help electrical guru needed Triumph 4
B Bugeye Electrical Diagram Spridgets 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
D TR2/3/3A TR3A electrical issues Triumph 2
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
Simmo General Tech Electrical question Triumph 4
B BJ8 Phase 1 Electrical Diagram Austin Healey 21
T TR6 72 TR6 electrical snafu Triumph 4
P TR6 Electrical Problem Triumph 26
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
N Electrical Issues Need Help Austin Healey 8
