Wedge TR8 Electrical Issue
RSMTR8
Ok, so I am out driving my 8 tonight it was beautiful here, and it was late so I had the lights on, and after about 30 minutes of driving listening to a little Eagles on the Cassette Player, all of the sudden my headlights start to dance, the Eagles start to sound like they are in a time warp (super slow) and the lights on the dash are very dim! This lasted about 30 seconds, then everything went back to normal, but did it again when I pulled in to the garage, and turned the lights off, they did a dance, the lights and radio in the car flashed on and off a few times, then finally went off like they are supposed to! Suggestions?! New alternator needed? If so, what does everyone recommend? It is the original one, maybe something a little more powerful?!.........Any input would be appreciated! On a positive note, the car is running great!
Thanks!
Rod
Sounds like a loose battery connection, or possibly a bad ground. I know this will sound strange, but if the tail lights are not grounded well, all kinds of weird things can happen when your lights are on. You will notice that there is a male spade connector on the tail lamps. You can run a secondary ground from the spade to one of the screw holes for the black cardboard tail lamp covers.
Hmm............very interesting, I will check the battery connections tomorrow. As for the grounding issue, not sure exactly what you mean. The lights have spade connectors running to them. So how do I run a ground? I am sorry, but I am leraning as I go along with this car. I was thinking alternator, because this problem has ONLY happened at night when the lights are running. SO I figured a larger load was being put on the alternator and maybe it wasnt able to handle it due to being old and possibly worn out........or maybe even the voltage regulator was faulty or worn out, and in that case I would just replace the whole thing I think and be done with it. I will check the battery connections first thing in the AM. But any additional details on how to run another ground wire in the trunk for the tail lights would be GREATLY apprecaited. I was wondering, any idea how many amps the original alternator is rated for? I know the one most people replace them with is the 85 amp Range Rover unit.
Thanks!!
Rod
12 volt DC power is sent to the tail lamps through various wires. The bulbs ground against the metal tail lamp housing. The tail lamp housing grounds to the body through the six bolts. The bolt holes are covered in paint and don't ground well. The body of the car acts as the return wire to the negative terminal of the car. If any part of this chain is weak, electricity won't flow. Grounding problems are very common on British cars.(specially those that sit and allow corrosion at the grounding locations) The spade terminal of which I speak is on the housing itself, not on the bulbs which srew into the housing. It is smack dab in the middle. It would seem that the engineers saw this as a potential problem, but the additional ground wire was never installed. I have seen things like rear lights and dash lights going out when the headlight are turned on. I have also seen lights going dark when a radio or wipers are turned on. An alternator problem will cause a slow lose of power, not a sudden on/off. Your problem sounds like an interuption in power supply or grounding. Start with the battery terminals, move onto installing the rear grounds(14 gauge wire with a female terminal on one end and a ring on the other), and then to the relays and headlight motor harness connections.
Look at it this way. A 12 volt system works on a loop. You must have a way for the power to get back to the battery (sorta). You can have all the power wires you want, they will do you no good without a ground. It is just as important to be properly grounded as it is to be powered. I don't mean to "dumb it down" but a lot of people have a problem with this. /ubbthreads/images/graemlins/grin.gif
Lucas 17ACR is rated at 36amps.(non ac cars) Lucas 25ACR is rated at 60amps.(ac cars) Others I know of are 15ACR=27amps, 16ACR=34amps,18ACR=43amps. Theses were used in other British cars. I don't know for sure but I think the 20ACR is also 60amps.
I was told an Alternator from a 1987-92 Range Rover will bolt right on, and it is rated at 85A. I was told this by Brad from WedgeParts. He is VERY helpful and knowledgable!
Rod
Could be. I am pulling a 3.9 with 138,000 miles out of a 1990 some time this week. I saw it at the local junkyard on Saturday and the guy only wants $150.00 for the complete motor. I'll let you know if the alt bolts up.
There is a smaall trick to fit a GM alternator to the Triumph. All you have to do is create a small spacer using a peice of copper piping. I was even able to do this myself. I will see if I can find the web site I found this off of but if not I will take a pic and post it later. Much cheaper and probably more reliable
You are gonna think I am an idiot, I do not see the terminal. Can you send me a pic? Thanks again!
Rod
Look again. I am holding one in my hands now. It is a spade connector, located between the bottom two light sockets. It is located on a boss that is on the structural webbing of the lamp housing. It is held on with a rivet and juts out at a 90 degree to the lamp. Remember, it is on the silver metal lamp housing that bulb holders screw into. If you still can't find it, I'll drag out the camera, charge the battery, take the pics, load the pics onto the computer, find your email address, and send you the photos. I might even have to recruit one of my kids to help out with all of the technical stuff, so I think I am the idiot here!
Thanks, I will look again when I get home. Just to conmfirm we are talking about the rear brake lights, in that area correct?! The outside of the housing is black.
Rod
Sort of, but not really. The hosing is silver pot metal and is covered/protected by a black paper/cardboard material. On mst cars, the black cover is long gone. Any way, directly beneath the lamp, on the trunk floor, is a screw hole that is used to secure the previously mentioned black cardboard panel. That is where you attach the new ground wire to.
I will check it out tonight. I know the drivers side still has the black cardboard cover, but the passenger side near the battery, does not. So I will try to use that side to do the ground.
Rod
Ok, I found the spot you were talking about on the passenger side of the trunk, and ran a gorund wire from the spade connector to the screw that the car battery is ground to, will that be ok ya think? or should I use a different spot to ground that wire? It was already there, so i figured what the heck.
Thanks!
Rod
JodyFKerr Wedge Electrical issues [TR8] Triumph 67
RSMTR8 Wedge TR8 Headlight/Electrical Problem Triumph 11
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
P Wedge Starting problems TR8 Triumph 3
tr6nitjulius Wedge Rare TR8 Triumph 0
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
Hamish Racing TR8 IMSA GTO around Spa Racing 0
MadMarx Wedge Dijon 2019 - Triumph TR8 IMSA GTO Triumph 0
MadMarx General TR Spa Summer Classic 2019 - TR8 IMSA GTO Triumph 1
MadMarx Brands Hatch - Triumph TR8 IMSA GTO Racing 0
MadMarx General TR Brands Hatch - Triumph TR8 IMSA GTO Triumph 0
MadMarx Wedge The IMSA TR8 is ready to go again Triumph 7
MadMarx Wedge IMSA TR8 video with some roar Triumph 0
MadMarx Triumph TR8 at Spa Racing 0
MadMarx Le Mans - YTCC - Triumph TR8 IMSA Racing 1
B Gold TR8 Waxhaw N.C. Spotted 2
MadMarx Wedge Canadian Group 44 TR8 at Hockenheim Triumph 2
MadMarx Wedge TR8 IMSA at Le Castellet Triumph 1
J Wedge TR8 research before purchase Triumph 16
MadMarx Wedge Custom Header IMSA TR8 Triumph 14
S Wanted TR8 with blown motor or no motor Triumph Classifieds 0
T Wedge Triumph TR8 for Sale - 1,020 miles Triumph 3
S Wedge tr8 front end Triumph 0
S Wedge TR8 starter solenoid details? Triumph 3
S Wedge Tr8 manual Triumph 2
S Wedge Need help with TR8 no spark Triumph 7
MadMarx Wedge IMSA TR8 goes on Salzburgring Triumph 6
S Wedge TR8 Starter wiring help needed Triumph 18
Rut Wedge TR8 for sale Triumph 1
MadMarx Spa Summer Classic - IMSA TR8 Racing 0
MadMarx Wedge Spa Summer Classic - IMSA TR8 Triumph 7
B Wedge tr8 oil pressure switch number needed Triumph 3
G Wedge TR8 Classified? Triumph 0
G Wedge New to me TR8 Barn find Triumph 8
MadMarx Wedge IMSA TR8 - a recent photo Triumph 3
MadMarx Wedge IMSA TR8 - Spax on the rear axle Triumph 3
W TR8 brake aclipers on a Spridget Spridgets 38
MadMarx IMSA TR8 on the NĂĽrburgring Racing 3
MadMarx Wedge IMSA TR8 is racing Triumph 7
tr7andtvr Wedge TR8 Rotor Specs? Triumph 0
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
tr7andtvr Wedge TR8 calipers? Triumph 3
tr7andtvr Wedge Tr7, Tr8 or SD1 3.08 rear needed.... Triumph 25
Mickey Richaud General TR TR8 Folks Triumph 0
T Wedge TR8 parts car Triumph 3
philman Wedge Tr8 on local craigs list Triumph 11
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
Darrell_Walker Wedge Rimmer's front rally spoiler installed on my TR8 Triumph 22
