    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
TR6 Brake Warning Light Stays On
Gerry M
Member
I have a 74 TR6. My brake warning light (and oil pressure light) come on when I turn the ignition 'on'. I believe this normal. But they stay on after the car is started and don't go out until the ignition is turned off. The brake fluid is full, the brakes have plenty of pedal and feel normal, and the oil pressure switch wiring looks OK. What could be causing the lights to stay on?
The wiring diagram for your '74 is in the PDF linked below from the Advance Auto Wire web site.
https://www.advanceautowire.com/tr2506.pdf
It looks like a failure of the oil pressure warning light switch (or if you really have no oil pressure) will cause the problem you are experiencing. If you unplug the white/brown wire from the oil pressure switch with the engine on or ignition on and the lights go out, confirm you really have oil pressure. If the pressure is OK, consider replacing the switch.
Yeah, it's not a brake problem. If it were, the OP lamp would not be lit and the BRAKE lamp would be brighter
I had a similar the problem when I first got my '76 TR6. The oil light stayed on despite the fact that the pressure gauge showed I had plenty of oil pressure. The light stayed OFF until I started the engine and then the light stayed ON.
What I found was that the previous owner had the wires switched on the oil pressure switch. He had the White/Brown wire and White/Purple wire switched on the oil pressure switch. Essentially, once the engine started the White/Brown went to ground to close the circuit.
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Gerry M TR6 Brake warning light & oil pressure light stay on Triumph 2
7 brake warning light coming on Other Cars 5
J MGB Electrical issue- turn signals dim and cause the brake warning light to flash MG 8
J MGB Question on the brake warning light for 78 MGB MG 6
hondo402000 TR6 71 TR6 Brake warning light and oil pressure light Triumph 6
I Brake warning light stays on - help please Triumph 28
I TR6 TR6 Brake line, hazard warning light not working. Triumph 3
Woodie Brake warning light Spridgets 15
Musicman Brake Warning Light Triumph 5
certifiedcarnut 948 front brake shoes warning Spridgets 5
Morris Brake Warning Switch Assembly Spridgets 10
angelfj1 BRAKE CLEANER - PLEASE READ THIS SAFETY WARNING Restoration & Tools 13
angelfj1 Silicone Brake Fluid Warning??? Restoration & Tools 3
angelfj1 Silicone Brake Fluid Warning??? Triumph 26
A Brake warning switch has a Ford part# --$20 Triumph 7
jcatnite Brake Failure Warning Switch Spridgets 16
jjbunn T-Series Brake Pressure Warning Switch MG 10
weewillie brake pressure warning lamp Spridgets 12
Woodie brake warning switch Spridgets 2
jerrybny Brake Warning Lite switch Triumph 1
M Brake Caliper Attachments Austin Healey 4
M Brake Servo Austin Healey 8
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 8
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
