MGB brake light switches of late
wkilleffer
Hi everyone,
After about 12 years of faithful service, the brake light switch I installed on my 1974 MGB started getting a bit flaky and smelling hot if I sat too long at a traffic light. I attempted to disassemble and re-solder the leads to the terminals, but my efforts didn't help all that much. It was time for a new switch, which I ordered from Moss.
Now, I don't want this to turn into a bash-Moss session, cause they do some things quite well. But my attempts at fitting the new switch all but caused it to fall apart. I don't handle everything with kid gloves, but nor am I some ham-fisted klutz whot can't be trusted with a screwdriver. The part looked a bit questionable even while still in the package.
Initially, it was difficult to screw the end of the switch into the pedal box. Once in, all was fine except for two things: the wires had all but broken off at the switch terminals, and the female end of the wiring was too small for the bullets on my wiring harness. My attempts to open them up a bit caused one of the female terminals to break off.
The reason I don't want to bash Moss is because they sent a new one out free of charge after I called them about it. Managed to control my temper on the phone and all that. The new one came today, though I haven't yet opened the package.
Now, I guess my questions are, is this sort of thing normal for this particular switch, and what can I do to open the female connectors up larger to fit my harness?
glemon
I don't know about the MGB switch particularly (you might get more traffic on the MG section of the forum) but in general many of the reproduction switches I have seen lately have been a little dodgy, I had a new headlight switch fail shortly after installation on my Healey 100 a few years ago, and more recently had to re-solder some of the connections in the new turn signal switch I put in my TR250. As far as the bullet connector you might try squeezing or crimping where it goes into the harness down rather than trying to make the bullet connector end bigger, I imagine you could also solder the old bullet connector ends onto the new wire ends, but you would think you would get a part that would work better and you wouldn't have to do that.
PAUL161
This is a major problem in the T series brake switches also. Dave DuBois has relay kits for these changes at reasonable prices plus other electrical repairs. here's his email.
sufuelpumps@donobi.net
Gliderman8
I bought a brand new ignition switch for my TR6. The wire harness on the switch terminates in a 5-pin plug. After installing the switch I tried plugging the male end from the switch into the female end on the cars wiring harness, but it would not fit. The pins on the male end were too large a diameter. I called the supplier who suggested I cut the original plug off and solder it to the new switch. Knowing this might void the warranty I asked about it and was told they would still honor the warranty. I asked for and received it in writing before I cut the plug off. New part but still a PITA to install.
wkilleffer MGB MGB brake light switches lately MG 1
J MGB Question on the brake warning light for 78 MGB MG 6
Scott_Hower MGB MGB - Left turn signal wont flash, brake light dim MG 16
Celtic 77 MGB 1977 MGB Brake issues MG 8
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
drooartz MGB Swapping to dual SU on later MGB with brake booster MG 7
B T-Series MGB Brake Pressure Switch MG 2
S MGB-GT mgb gt brake caliper rebuild kit? MG 2
B MGB GT V8 brake pad part number Racing 1
G MGB '71 MGB brake lights MG 18
QuickSilver MGB 77 MGB - Turn Signal, Brake Lamp and Hazard Issues MG 22
R6MGS MGB MGB brake problems MG 14
glemon MGB MGB Brake Bleeding MG 14
Shinsen774 T-Series Hydraulic Brake Switch-Early MGB-Still a problem? MG 9
kyreb1862 MGB Hand Brake Problem 77 MGB MG 3
kyreb1862 MGB 1977 MGB Brake Master Cylinder Identification MG 7
kyreb1862 MGB 77 MGB Brake Booster Color MG 5
kyreb1862 MGB MGB Brake Booster Diagnosis MG 1
PAUL161 MGB MGB Rear Disc Brake Conversions MG 14
A MGB MGB Brake M/Cyl...Made in China MG 9
N MGB MGB brake servo MG 4
G MGB '77 MGB Brake Master Cylinder MG 8
Carlbanan56 MGB MGB valve seals MG 1
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
ab-1970mgb Wanted 1970 MGB - Emissions Parts MG Classifieds 4
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
