MGB Swapping to dual SU on later MGB with brake booster
drooartz
My other recent thread explains the problems my friend is having with a Mikune carb on his MGB LE.
I happen to have an extra set of dual SUs off of a '70 GT, and we've discussed swapping them on. They're a little tired, but were off of a running parts car (the same parts car that donated the engine I'm currently trying to get refreshed). I've got the full carb and manifold setup.
A couple questions if we go down this route:
1. Brake booster, is there an air filter that we know would fit?
2. Brake booster vacuum line?
Anything else I need to think about before we try this swap? Looks like the fuel line and choke/throttle cables shouldn't be a problem.
Carb in question:
Mickey Richaud
Hey, Drew -
I believe there's a K&N tapered filter that will fit. And there's a filter offered by Moss that uses a sort of manifold with the filter located forward of the carbs. They're both in their Performance section of the catalog, pp A45 & A46 in the catalog I'm looking at.
Later model intake manifold should have a port for the booster.
drooartz
drooartz
Thanks, Mickey. I'll have to get a pic of the intake that I have, and see if it has that port for the booster. New territory for me.
Platinum
If the SU manifold is a 12H1398 it has a blanking plug at the front, suitable for fitting a booster line.
drooartz
drooartz
Here's the intake that I have, came off a '70 GT.
Platinum
Looking from the carb side, the angled port with the plug on the right side appears to be a good take-off for the booster.
drooartz
drooartz
Thanks, Doc. I was eyeing that one myself. We're going to try to clean out the existing Mikuni carb, but if that fails these will be going on.
billspohn Engine Swapping for Straight 6 Power Other Cars 3
R GT6 Swapping bellhousings Triumph 0
F Swapping out original 1098 distributor to electronic Spridgets 13
B Spitfire Advice on swapping to J Type OD with 1500 engine in 69 Spitfire Triumph 13
Jim_Gruber Swapping Vent Windows from a '72 into a '68 Spridgets 10
K TR4/4A Linkage?Swapping SU's on to a 4A Triumph 4
George Zeck Swapping Differential ?? Spridgets 3
B Swapping gear boxes Triumph 1
T swapping a 1275 for a 1500 Spridgets 4
T Swapping exhaust systems on a Sprite Spridgets 3
PSJ 100 differential - swapping Austin Healey 3
losmorob Swapping rear axle gear ratios Spridgets 10
G MG and Morris 10 engines, any swapping bits ? MG 5
msoylemez Question on swapping out diffs Spridgets 1
G Swapping out tranny, use old B&B Clutch? Triumph 9
ronzet MGA Swapping Carbs MGB to MGA MG 22
C Swapping steering wheel MG 15
vping Rear spring longevity & swapping. MG 15
SilentUnicorn swapping ends Spridgets 15
regularman Anyone interested in some swapping? Spridgets 80
T MGC Swapping manual for auto trans in a MGC MG 17
drooartz Swapping to later carbs Spridgets 9
T TR6 Swapping 1974 TR6 fenders on to my 71 TR6? Triumph 5
L Tunnel swapping anyone? MG 1
S swapping out my 1500 for a 1275. do-able? Spridgets 9
D Swapping 948 for 1275 engine Spridgets 11
R Swapping out Z-S for SU's MG 0
nathandarby67 Swapping rear hub on a Midget MG 7
R Bugeye dual horns Spridgets 16
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
M Mallory Dual point distributor Austin Healey 0
aero3113 100-4 dual gauge Austin Healey 16
B Dual Circuit Brakes Austin Healey 3
B MGB New Dual SU's and Run-On MG 3
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
B Mallory Dual Point gap Austin Healey 4
apbos Interesting dual cylinder Bugeye setup Spridgets 6
F General MG Help needed with su dual carburetor identification MG 4
A TR4/4A TR4A dual exhaust specs Triumph 3
T TR2/3/3A Dual circuit brakes Triumph 2
longbridgehealey Longbridge built 100-6 dual washer nozzle Austin Healey 6
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
B Question about Dual Polarity Electronic Fuel Pump - How to Connect Wiring? Austin Healey 9
andrea Dual Beam LED Head Light Cree Austin Healey 4
steveg Fiat Dual Master Cylinder Austin Healey 7
maxwedge5281 dual circuit braking system Austin Healey 29
