Hi all,
While cleaning up the rear suspension on my 1961 BT7 after a 30 year wait (http://www.britishcarforum.com/bcf/...ip-I-decided-to-clean-my-1961-Healey-3000-BT7) I took the opportunity to check the level on the rear Armstrong shocks (not having done so in 30 years). The shocks have always passed the "bounce test" (bouncing each corner) and appear to be working fine, but at least I expected the fluid to be severely depleted (I read somewhere they a supposed to leak a little in order to lubricate the arm). I was amazed to find the shocks were fully topped up. However, I drew of some liquid and it was quite dark with what looked like disintegrated rubber causing the colour.
I was wondering if it was easy to service these shocks (this guy make it look pretty straight forward - https://www.youtube.com/watch?v=oGUhb90Voyk) amusing they are easy to remove. On the other hand should I leave well alone, apart form sucking out the old fluid and replacing with some fresh shock oil.
What do you all think?
Phil
Phil
