What do you put in your Armstrong lever shocks?
glemon
Just curious, I was working on the MG morning, I thought it rode very rough, checked the shocks, the front right was doing nothing--aha.
I filled with straight 30 weight oil, I think that is a little thicker than stock shock fluid. Anyway after filling and levering back and forth it seemed to work fine.
I have done this in other cars as well, and "fixed" shocks that didn't seem to be working well with even thicker mixtures too.
No noticeable ill effects and seems to hold up well over time.
Am I the only one that does this? or do others of you mix your own shock oil, or am I risking life and limb, or at least shock be doing this?
tony barnhill
Great Pumpkin - R.I.P
I use plain old clear mineral oil that you can buy at your corner drugstore.
Steve_S
"What do you put in your Armstrong lever shocks?"
Armstrong shock oil.
30-weight will work, but it's heavier than the shock was designed for. I would strongly recommend against putting anything heavier in there. The recommended oil is approximately 20-weight. If you want stiffer shocks, it's a better idea to put in heavy duty valves rather than heavier oil.
Mineral oil lacks anti-foaming agents necessary to prevent foaming within the shock's chambers. Once it starts to foam from the agitating action of the shock assembly, air pockets will form where they shouldn't be and the shock will no longer perform properly. Yes, it will still function, but not as well as it should.
Motorcycle shock oil is perfectly fine and is easy to find locally. Or, buy a bottle of the Armstrong oil as sold by most of the British parts suppliers for a bit more money. This is something you don't have to do very often anyway, and with a new or rebuilt shock it will be many years before you have to worry about it.
tony barnhill
Haven't observed any problems with any of the shocks in which I've used mineral oil, Steve....
<span style="text-decoration: underline">Bentley</span> says, <span style="font-style: italic">"Use Armstrong Super (Thin) Shock Absorber Fluid No. 624. (If this fluid is not available, any good-quality mineral oil to specification S.A.E. 20W should be used, but this alternative is not suitable for low-temperature operation.)"</span>
I use motorcycle shock oil purchased at the local Harley Davidson dealership....but now my exhaust goes "Potato-potato-potato-potato-potato"
1965_MGB
I use 20wt shock oil I got from a Kawasaki dealer. Seems to work great, and much cheaper than the Armstrong oil that is available. They also had a syringe that makes putting the oil in much easier than a funnel. :smile:
tony barnhill
I also use one of those huge plastic syringes!
jlaird
I have a deal. Anytime a shock is not working properly I send it to Peter C and it comes back like new.
I use a 60cc syringe (minus needle) that can be found at your local farm supply house. That, in combination with some plastic/vinyl tubing makes an easy job of filling either the front or rear shocks.
vping
Bronze
Nice one! :smile: I've the used the Screaming Eagle oil from HD without troubles.
glemon
glemon
Ironically, after I filled my shocks and posted this topic I remembered that I had this:
They are still full and sealed and look to be the right stuff for lever shocks.
T Got the engine put together Spridgets 4
S TR6 After I put in my new oil pump.... Triumph 3
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
M TR2/3/3A Has anyone put in a Hi Torque Starter from Moss? Triumph 21
M TR2/3/3A Where have you guys put your stereos and speakers? Triumph 3
M TR2/3/3A Phone charger & Radio can I put these in my car??? Triumph 7
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
R TR4/4A About to put in an OD Transmission. What else should I do while in the air Triumph 7
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
glemon General TR Time to Put Your Tops Up? Triumph 12
jlaird Before I put in classifieds Spridgets 36
Bob McElwee Rode Hard and Put Away Lovingly Austin Healey 6
J How to put a stop on the end of a choke cable? Restoration & Tools 2
M Who put the stick in my heater hose? Spridgets 6
BN6_2197 What to put in steering idler reservoir of BN6 Austin Healey 2
drooartz Help me put together a plan for my Bugeye Spridgets 46
PAUL161 General MG Where Would You Put This? MG , VW, Motorcycle? MG 3
R 100-4 PUT-BACK-TOGETHER ?'s Austin Healey 2
RickB Just put headrest speakers in - wow! Spridgets 8
T TR2/3/3A Has anyone put sound deadening in a TR3. Were the results worth it? Triumph 21
DrEntropy Can't put it off any longer. MG 10
M Body ready to be put on Chassis, 1 question first Triumph 9
B TR2/3/3A TR3. Would you put it back to right hand drive? Triumph 11
T Where to put the OD relay? Triumph 13
bugedd Before I put it on ebay.... Spridgets 0
K TR4/4A Can I put a TR3A Clutch in a 4A? Triumph 16
Basil Where to put that bumper sticker Spotted 1
middie Before I put engine back Spridgets 22
Jims71TR Put a new fuse box in now I have troubles Triumph 15
regularman Has anyone here put a bugeye front end on a square Spridgets 2
G GT6 Can I put a GT6 balancer [crank pulley] on a TR6? Triumph 2
BugeyeNJ58 Put on Harley Muffler--now backfires?? Spridgets 26
doughairfield Where to put the ground. Triumph 6
B Before I put the heater in my 57... Triumph 10
JPSmit Wasn't quite sure where to put this -youtube video Spotted 6
BugeyeNJ58 Radius arm came out...how to put new one in? Spridgets 6
bigjones Spare coil - put it under the hood? Spridgets 8
Marvin Gruber Put off too long Jaguar 4
T OT - what do you think, put a Rover V8 in it? Triumph 29
T Did they put TR frames under these? Triumph 8
jackq Something to put in front of your MG MG 0
Tinkerman Need to put a new hole in my dash! Triumph 20
JohnnyMead What to Put Under Carpeting? Triumph 11
I TR6 TR6 put put sounds, part 2 Triumph 74
T What do you think - put a team together for this? Triumph 2
livinginthepast Stupid Q dejour - horn push/badge won't stay put! Spridgets 14
T Largest tire size I can put on my 89 xj40 Jaguar 1
