Differences in Armstrong Lever Arm Shocks
twas_brillig
I've got three Armstrong lever arm shocks that I pulled the filler plugs from tonight (they should all be from Sprites).
A - the filler plug has a single o-ring, sealing to the body of the shock
- the six machine bolts holding the plate over inner workings are Phillips style
- one shock had two flat washers on the 'pin' between the filler plug and the bottom spring; the other had a single flat washer (I may have lost one)
B - the filler plug has a second 0-ring, sealing up against the bore of the shock
- the six machine bolts holding the plate over the inner workings are slot style
Any wisdom out there regards these differences (other than 'don't lose any of the washers').
Thanks
Doug
T
twas_brillig
there's a difference between the 'pins' that fit between the bottom spring and the top filler cap: one type is round (and appears to be soldered onto the centre threaded rod); the other is an hexagonal nut. More trivia! Doug
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
Quackedo TR6 1969 Triumph TR6 Differences Triumph 18
R TR6 Radiator protection shield differences Triumph 0
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
maxwedge5281 Front Shroud Differences: 3000 vs. BJ8 Austin Healey 5
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
Got_All_4 TR6 Looking at clutches and their differences for my 69 TR6 Triumph 14
J TR6 TR6 Cross Tube Differences? Triumph 6
CJD TR2/3/3A Knock Off Differences Triumph 13
MisterB Shut pillar differences? BN4 to BJ8 Austin Healey 7
D TR4/4A any major vendor differences in replacement suspension bushes? Triumph 5
R Differences in BJ7s Austin Healey 1
D Differences between BT7 and BJ8 engines. Austin Healey 12
busybrit Healey BN4/6 bell housing vs BN7/BT7 differences. Austin Healey 2
Marvin Gruber TR4/4A TR4 hood differences Triumph 2
anarchy99 GT6 Body differences between gt6 and spitfire... Triumph 12
Scotsman GT6 GT6 early vs later model differences / upgrades Triumph 13
K TR2/3/3A Clutch and Gearbox Sleeve Differences. Triumph 12
B TR4/4A Body tub differences - TR4/4A Triumph 8
C Idler Arm Differences and Rebuild Question. Need Help! Austin Healey 2
T TR2/3/3A Type A Overdrive, Physical Differences between Roadster Brands? Triumph 2
T TR2/3/3A Type-A Overdrive Handling Differences Triumph 9
Mink TR4/4A Dash/Crash pads - differences in quality between vendors? Triumph 8
M TR2/3/3A Body Measurement differences between pre & post 60,000 TR3s Triumph 4
RAC68 Dimensional Differences [brake Calipers] Austin Healey 5
Marvin Gruber TR5/TR250 TR250 Engine differences Triumph 2
DanLewis Rear brake backing plate differences: Bugeye vs. later model MG Midget Spridgets 12
K TR2/3/3A Clutch disc and Pressure plate differences? Triumph 3
K TR2/3/3A Differences in Distributors? Triumph 9
Got_All_4 Fuel Tank Differences Triumph 5
W Steering column differences Spridgets 0
Jim_Gruber Seat Differences between Mk 1 and Mk 2 Spridgets 10
K TR6 Differences in Chassis on 67 TR4A and 73 TR6? Triumph 8
bugedd Bugeye bonnet differences Spridgets 9
K TR4/4A 3A and 4A Clutch Component Differences? Triumph 19
rovernut TR4/4A TR4A IRS VIN differences Triumph 9
J TR2/3/3A Frame differences in a TR3?? Triumph 17
M 4.0 V-8 for XJ8, XK8 and S-Type Differences? Jaguar 1
drooartz Starting to look for spare motor, differences? MG 2
britlover TR6 TR4A IRS body on a TR6 Frame?? Differences? Triumph 10
C What are the differences in Midget MK2 and MK3 top Spridgets 6
Got_All_4 Wedge TR7 Head differences Triumph 1
R TR4/4A TR4A sway bar , any vendor differences Triumph 11
T TR6 Differences in ZS carbs for emissions TR6s Triumph 6
A Differences between 3000 models Austin Healey 8
RedTR3 TR2/3/3A TR3 Transmission Differences Triumph 27
AH224414 Differences between AHCA and AHCUSA Austin Healey 14
T TR6 Differences between TR4a and TR6 convertible tops Triumph 14
B frame differences Austin Healey 4
Parker TR2/3/3A TR3A Lamp lenses: NOS / "Lucas" repro differences? Triumph 9
