TR2/3/3A Body Measurement differences between pre & post 60,000 TR3s
Miles58
Members, I need some advice
I have a 58 TR3A (TS25663L) I have begun gathering body repair parts for in anticipation of a full restoration. The car is in pretty bad shape, particularly the rear section, aft of the B posts. The floors are gone and large portions of the truck floor...you get the picture. I purchased a post-60,000 rear section that was in pretty good condition for a great price. It had been cannibalized by the PO around the spare tire storage and rear panel but otherwise was pretty solid. I recently purchased a rear panel repair section from Victoria British and began to compare the panel's measurements to both the pre and post 60,000 rear sections. It seemed the pre-60000 was wider than the post 60000 and the repair panel seemed to match the post 60,000 better.
Here's my question, can I successfully mate the pre-60000 front end to the post 60,000 rear? Does any one of you have measurements of their cars I could use as a reference? Can I alter the post rear to conform to the pre measurements?
BTW, I've owned the car since 1977 and drove it daily from 77-83, then marriage, military, travel and children took hold. Now trying to do what I've wanted to do for years.
Thanks, Larry
CJD
You are right. My pre-60k tub measures 45-1/4" at the tail lights. My post-60k is 44-1/8". Past that, I am not sure what to tell you. An inch is enough to open up a can of worms in trying to change along the rear quarters. If I were looking at it, I'd likely look for a closer panel, or plan on a lot of time to fit that one.
M
Miles58
Thanks. That helps confirm there are differences. Now to decide to how to rebuild the pre-60000 rear. I'm think I may still be able to salvage individual parts off the post 60000 rear if i disassemble it. I will definitely have to do more work that I had hoped or planned.
Larry
Andrew Mace
I've seen a few "clip" cars over the years: post-60000 front and pre- rear end and vice versa, so I'm sure it can be done. There's a pretty good chance that this would greatly reduce the value of the car to a future potentially serious buyer if he/she has even a passing knowledge of these cars, though! Just sayin'....
M
Miles58
Thanks Andy, I would also suspect it might cause a problem with a future buyer (although my children are forcing me to will the car to them, LOL). The right answer is I have to rebuild the existing rear section and either try and sale my post 60 rear to recoup some cash for new parts or break it down into parts I can use, specifically the B Posts. I have my work cut out for me.
Larry
GregW What!? another body measurement? Austin Healey 7
D TR6 lost body shell Triumph 1
J Can a TF engine be installed in a TD body? MG 7
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
5 MGA Body and Chassis Separation? MG 2
Bayless How does '67 Sprite top attach to body? Spridgets 3
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
K TR2/3/3A The "wide body" TR3? Triumph 6
W TR2/3/3A Interior and Body Colours Triumph 14
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
D Body/Paint Shop Recommendations Austin Healey 1
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
T TR2/3/3A Question on TR3A front body mounting Triumph 6
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 6
M BJ8 Inner Body Panel Repair Austin Healey 2
T TR2/3/3A Body Tub Weight Triumph 8
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
D TRIUMPH TR6 BODY SHELL Triumph Classifieds 1
B After bead blasting the body I noticed some interesting things… Spridgets 2
S Inner Body Alignment Austin Healey 0
B Body Reassembly Austin Healey 2
S TR2/3/3A Body Mounting Bolts. Triumph 14
F TR2/3/3A front body mounts Triumph 7
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
Csarneson Body panel assembly order? Austin Healey 6
J Wanted WTB Triumph TR6 Body/ Rolling Chassis Triumph Classifieds 0
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
X Production year based on body number ? TVR 3
TRclassic3 TR2/3/3A Body leans to right side Triumph 10
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
J For Sale La Dawri 'Del Mar' fiberglass body for TR-2 thru TR-6 Other British Classifieds 1
T For Sale MGB Pull Handle Tub Body Shell for sale MG Classifieds 0
BJ8Healeys Body Parts Code Austin Healey 5
BOBBYR Body Panel measurements and angles Austin Healey 6
S TR2/3/3A Frame off vs. body on restoration Triumph 21
B Longbridge 100-6 Windshield Posts - Body Color or Silver? Austin Healey 16
A Recommendations for body repair near NYC Restoration & Tools 2
H GT6 Replacement body panels Triumph 4
Jim_Stevens TR2/3/3A Rear fender stays: black or body color? Triumph 8
J TR2/3/3A Body Restoration - Inner Sill Replacement Triumph 38
J TR2/3/3A Body Mounting Strip Adhesive Triumph 10
