TR2/3/3A Question on TR3A front body mounting
TR3-Stu
I did a search of this forum, but was unable to find info on the front body mounting. On the front diagonal tubes, there are rubber body pads (two per bolt), aluminum body mount pads (one per bolt), and an inner fender mount plate. My question (as I forgot what was there when I took it apart :() - does the steel fender mount plate go on top of the body flange, and the aluminum body pad (sandwiched with a rubber washer on top and bottom) go between the body flange and the frame?
Stu Boyd TS78330-L
CJD
+1 to the first way...the plate goes on top of the body flange, with 2 washers and then the bolts. All the pads and spacers go between the flange and the frame.
T
TR3-Stu
Thank you John for the quick response. Great support on this forum.
sp53
One thing that might help on installation of the pads and aluminum spacer is to put the aluminum piece in after you have the bolt and rubber is in place. The aluminum piece has that slot and can slide onto the bolt from underneath. Moreover, if the holes do not line up, put a punch into the adjacent hole and pry over to where you need it.
steve
T
TR3-Stu
steve
Thanks for the helpful hints Steve.
Tinkerman TR2/3/3A Front turn signal wiring question on my post 60000 TR3A Triumph 8
JFeher TR2/3/3A TR3A Front Suspension question Triumph 3
B TR2/3/3A TR3A front wheel bearing question Triumph 5
T TR2/3/3A TR3A Windshield Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
71TR6 TR2/3/3A TR3A Scuttle Rim Question Triumph 4
D TR2/3/3A TR3A overdrive question Triumph 6
T TR2/3/3A tr3a verticle link removel question Triumph 11
Tinkerman TR2/3/3A 1960 TR3A engine compression question. Triumph 7
6TTR3A TR2/3/3A TR3A overdrive relay question Triumph 3
D TR2/3/3A Question about a '60 TR3A for sale by P Braun in BCF Classifieds. Triumph 0
R TR2/3/3A Anotehr TR3A transmission question Triumph 1
2billydavies TR2/3/3A question about 1958 TR3a engine number, body number, etc Triumph 7
T TR2/3/3A Question on TR3A aftermarket side curtains Triumph 8
Tinkerman TR2/3/3A Tunnel installation question 1960 TR3A Triumph 11
2billydavies TR2/3/3A dumb question of the day: engine fan for TR3a position Triumph 11
2billydavies TR2/3/3A engine fan assembly on TR3a: balance weight question Triumph 3
M_Pied_Lourd TR2/3/3A TR3A Crankshaft Question Triumph 3
T TR2/3/3A Question on TR3A hood lift assembly Triumph 2
T TR2/3/3A TR3A fuel gauge question Triumph 36
B TR2/3/3A TR3a oil line at block question Triumph 5
Tinkerman TR2/3/3A TR3A Post 60,000 seat question Triumph 2
A TR2/3/3A 1959 triumph tr3a transmission question Triumph 3
PatGalvin TR2/3/3A Boot Lid Reinforcing Supports Question, TR3A Triumph 8
S TR2/3/3A Another Amp Meter & Regulator Question - TR3A Triumph 19
Tinkerman TR2/3/3A 60 TR3A Dip Stick Question Triumph 5
TR4nut TR2/3/3A TR3A door seal question Triumph 7
Geo Hahn TR2/3/3A Yet Another TR3A Slave Cyl Question Triumph 4
Tinkerman TR2/3/3A Parts question TR3A post 60,000 series Triumph 5
JohnnyMead TR2/3/3A TR3A Rear Wheel Cyl Assembly Question Triumph 5
PatGalvin TR2/3/3A TR3A Door Handle Key Question Triumph 12
Tinkerman TR2/3/3A Wiring question TR3A Triumph 5
M_Pied_Lourd TR2/3/3A TR3A Gauge Cluster Wiring Question Triumph 7
PatGalvin TR2/3/3A TR3A Door Question Triumph 17
J TR2/3/3A TR3A control head question Triumph 4
Tinkerman TR2/3/3A Starter Terminal post question, post 60000 TR3A Triumph 7
T TR2/3/3A TR3A interior question Triumph 11
M_Pied_Lourd TR2/3/3A TR3A Seat Track Colour Question Triumph 16
M_Pied_Lourd TR2/3/3A TR3A Battery Box Replacement Question Triumph 12
M_Pied_Lourd TR2/3/3A TR3A Resto/Adding Metal Question Triumph 8
M_Pied_Lourd TR2/3/3A TR3A Sheetmetal Part # Question Triumph 11
M_Pied_Lourd TR2/3/3A TR3A Floor Welding Question Triumph 8
mountainman TR2/3/3A TR2-TR3-TR3A Top Question Triumph 12
Got_All_4 TR2/3/3A TR3A carpet question Triumph 6
Tinkerman TR2/3/3A TR3A Boot trim out.question. Triumph 17
Tinkerman TR2/3/3A Wiring Harness Question on my TR3A Triumph 8
Tinkerman TR2/3/3A Overdrive Switch question. TR3A, Problem Solved! Triumph 10
