    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
TR2/3/3A Starter Terminal post question, post 60000 TR3A
Tinkerman
On my starter terminal post (which is copper)there was one brass jam nut and a fiber washer. I was missing the second jam nut. I got a jam nut from another source and he sent it to me with the nut a fiber washer and a plain flat washer. Does the assembly need two fiber washers? It did not come off my original terminal post so I have no way of knowing what was on it originally. I would have thought the order of assembly would have been: fiber washer, jam nut. solenoid terminal, lock washer, jam nut.
Any thoughts greatly appreciated!
Thanks, Tinkerman
Sorry, I'm a bit confused...are we talking about the starter motor or the solenoid?
John
Starter motor. Long nose. I should have said solenoid wire not terminal.
Sorry about the confusion. Thanks for asking the question.
Tinkerman
One fiber washer, between the inner nut & the housing. Your order sounds good.
Tinkerman
Didn't post 60,000 cars use the later (short) starter?
T
The stud on the starter needs to be insulated from the housing of the starter. There should be a fiber washer on the inside of the housing, where the stud goes through the housing, many times this washer has a shoulder on it that keeps it centered in the hole in the housing. Then there is another fiber washer on the outside of the case, the regular plain washer over that (the regular washer spreads the pressure of the nut out over the fiber one, so you don't crack or tear the fiber)then nut number one holds all those parts tight to the housing of the starter.
I personally then use another brass washer on top of the first nut, then your wire from the solenoid goes next, another brass washer, then either a star washer or a spring lock washer, then the second nut.
care needs to be taken when assembling, that the stud doesn't contact the case. A resistance reading with a VOM from the stud to the case, with the brushes out, should be on the order of several MegOhms.
Tinkerman
A common confusion. Dick said long <span style="text-decoration: underline"><span style="font-weight: bold">nose</span></span> starter, and the later starter is considerably longer from the mounting surface to the end of the exposed shaft, which I would call the 'nose'. The early starter has a shorter 'nose' but a much longer 'body', making it slightly longer overall.
And the change point was at TS50k, not 60. Gearbox housing and tunnel had to be modified to clear the later starter's nose, flywheel was changed to a bolt-on ring gear, and the gearbox dipstick was deleted.
Thanks Randall, your explanation was much better than my "well gosh. that's what everyone calls them" type of answer.
Cheers, Dick
Tinkerman Starter Terminal Post Nut Size Triumph 14
T TR4/4A Starter Terminal Triumph 2
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
J TR6 72 TR6 starter problem Triumph 10
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
C MGA Change a pull starter to a push button system MG 6
Michael Oritt Starter Button Austin Healey 19
D WOSP Starter Austin Healey 9
DrEntropy MGB Replacement starter MG 7
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
AUSMHLY Crankshaft Starter Nut Austin Healey 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
B TR4/4A Starter dog bolt Triumph 15
D Starter Austin Healey 26
red57 What starter is this? Austin Healey 6
S TR2/3/3A Correct Starter Triumph 4
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
R TR6 Is this a starter issue? Triumph 6
Got_All_4 TR2/3/3A Gear reduction starter problems Triumph 5
John_Mc TR6 Starter not engaging consistently Triumph 9
R TR2/3/3A Starter rear plate 54 TR-2 Triumph 12
