TR2/3/3A Gear reduction starter problems
Got_All_4
Went out to move the TR3 to another garage and as soon as I pushed the starter button there was a pop and then nothing. Not even a red ignition light for a while. It came back. tried to jump the starter with a cable from the + battery to the starter and all it did was spark. No engagement. Reading something here years ago where something freezes up due to the heat from the down pipe. I wrapped my so I would have this problem. Surprise! Any suggestions?
CJD
The “nothing” for awhile would lead me to think one of the large cable connections is loose or dirty. If it were the starter itself, it would not have affected the rest of the electrical system. So, connections to look at in easiest to check order:
Neg cable from battery to solenoid
Pos cable from battery to body
Cable from solenoid to starter
Cable from engine to Frame at left front.
poolboy
If you put the transmission in 4th gear, are you able to roll the car a foot or more?
I'm just wondering if the starter is hung up on the flywheel ring gear
Got_All_4
Got_All_4
Charged the battery, cleaned the terms which weren't cruddy at all and also tried rocking the car thinking like poolboy. The only thing is now the starter tries to engage and I can hear it hitting but no turning of the motor. latter today I'll try tapping it with a hammer like I use to to with the Lucas starter.
DavidApp
Have heard of the bolts in those starters coming lose. Not sure what effect that would have on it's performance.
David
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
N TR6 gear reduction starter wiring connections for 1972 TR6 Triumph 1
D Gear Reduction Starter Austin Healey 15
RAC68 Gear Reduction Starter Infor and Suggestions Requested Austin Healey 11
J TR2/3/3A Need opinion on gear reduction starter for TR3A Triumph 23
R Gear reduction starter hits distributor oil line bolt Austin Healey 14
davidb AH 3000 gear reduction starter Austin Healey 13
R BJ7 Gear reduction starter and starter ring gear orientation Austin Healey 17
Willie_P TR4/4A WIRING question: gear reduction starter Triumph 3
H gear reduction starter cross reference Austin Healey 12
S TR6 Quick TR6 gear reduction starter wiring help Triumph 10
M Gear Reduction Starter comparison Austin Healey 7
NardisCNC How do I wire this new Gear Reduction Starter?? Spridgets 4
H Gear reduction starter motor Austin Healey 9
T 100 4 Gear Reduction Starter Austin Healey 1
Tremelune TSI gear-reduction starter into '65 Sprite Spridgets 12
J Gear Reduction Starter Question Triumph 8
Glen_B Gear reduction starter pinion detail needed Spridgets 2
angelfj1 TR5/TR250 TR250 - gear reduction starter install Triumph 4
King_of_England aftermarket gear reduction starter failure Triumph 10
M Flywheel ,ringgear.gear reduction starter guestion Triumph 4
T Starter for a 1275 - stock or gear reduction? Spridgets 9
MTribe gear reduction starter fix ring gear bevel? Triumph 5
M TR2/3/3A TR3 Gear Reduction Starter Triumph 5
T Gear reduction starter compared to original Triumph 10
Tronch Gear reduction starter connection Austin Healey 3
B GT6 Isuzu Trooper Gear reduction starter for TR6/GT6? Triumph 5
Darrell_Walker Mounting position for gear reduction starter Triumph 2
VelodromeRacer Gear Reduction starter! Austin Healey 21
T Wedge TR8 Gear reduction starter Triumph 2
A Gear reduction starter Triumph 11
S Who has best price for gear reduction starter? Triumph 9
J Gear Reduction Starter Austin Healey 2
JPSmit Gear reduction starters anyone? Restoration & Tools 5
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
F TR6 speedo gear reduction Triumph 3
T TR4/4A TR4A wiring - gear reduction & external solenoid? Triumph 6
T How tell if gear reduction start fits is right? Triumph 2
angelfj1 Gear Reduction Starters - are . . . Triumph 17
TRMark TRF Gear Reduction Starters Restoration & Tools 1
Aldwyn TRF Gear Reduction Starters Triumph 31
DerekJ High Torque Gear Reduction Starters Austin Healey 2
G Gear Reduction Starters Success Triumph 15
D Gear Reduction Motors Austin Healey 1
L T-Series Gear box servicing cap. MG 5
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Todd78d Sprit MK1 gear box filler Spridgets 2
