T-Series Gear box servicing cap.
Louis 52MGTD
Am I the only one that has ever dropped the filler cap to the gear box on a MGTD when servicing it ? I have done it twice now and had to remove the bellhousing cover to get it out, plus the carpet and padding. look's like MG would have left a bigger hole to get your fingers in to reach the filler plug. what a pain in the a$$ job.
You can't use a magnet because the cap is made of alum./ brass ? I think if I ever have to remove it again I will drill a hole in the cap and install a small piece of wire in it. what do you folks use ?
AHH, I feel better already. :smile:
JPSmit
Confession is good for the soul :ROFLMAO:
Grantura_MKI
Would maybe cut a larger hole in the tunnel and fab a larger cover.
Many of these caps have a breather hole in them, so would not drill extra holes.
L
Louis 52MGTD
Grantura,
I think I will try and cut a larger hole the next time, if there is a next time :( . thanks for the input.
Beautiful car you have there.
Grantura_MKI
Not mine, but thank you. The Mercedes had been standing in a garage for 20 odd years and needed recommissioning.
Was a rather large job.
Good luck with your cap issue.
Todd78d Sprit MK1 gear box filler Spridgets 2
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
D Socket for TR3 Gear box drain plug Restoration & Tools 6
Joe_Healey TR5/TR250 Overdrive Gear box oil Triumph 8
F BN1 vs Bn2 gear box Austin Healey 23
B General TR Putting the rebuilt gear box back in the TR6 Triumph 1
Got_All_4 General TR Problem mounting the a type to the gear box Triumph 12
K TR2/3/3A Gear box to Motor Bolts? Triumph 6
Got_All_4 TR2/3/3A Continually Rebuilding of my J Type Gear Box Triumph 2
Got_All_4 TR2/3/3A Removing the J type unit from the gear box Triumph 24
J TR2/3/3A Gear oil in the gear box? Triumph 13
S TR6 Help installing the Gear Box 1972 Triumph TR6 Triumph 13
J Healey Gear Box & OD oil Racing 5
D gear box fill plug Triumph 13
andrea $ SPEED SIDE SHIFT GEAR BOX Unknow spare piece Austin Healey 3
tahoe healey Gear box woes Austin Healey 10
ekamm TR2/3/3A Tr3 steering gear box removal Triumph 6
Got_All_4 TR2/3/3A Prize in every box! TR3 gear box Triumph 30
A Gear box oil MG 9
ekamm gear box oil Triumph 13
W Over drive gear box MG 0
J Gear Box Jaguar 10
tahoe healey Fillintg the gear box on a BJ* Austin Healey 3
TRnorwegian Japanese gear box better? Triumph 29
R T-Series TC Steering Box Worm Gear MG 1
mountainman TR2/3/3A TR3 STEERING GEAR BOX FLUID Triumph 5
Tinkerman TR4/4A Cluster gear removal TR4 syncro box Triumph 2
W Silly question Gear Box oil change/top up MG 11
J Speedometer housing at gear box Spridgets 2
Tinkerman TR2/3/3A TR3 gear box shaft selectors Triumph 6
Tinkerman Cleaning Tranny, OD and Gear Box Covers Triumph 9
B Gear box whine MG 11
Got_All_4 TR2/3/3A Removal of Steering Box Worm Gear In Car TR3A Triumph 3
M Gasket sealer on bell housing to gear box Austin Healey 13
M Steering gear box zerk fitting Austin Healey 16
LuckyLuke Right Oil for BN1 axle and gear box Austin Healey 4
tahoe healey big gear box problem Austin Healey 7
R MG MIdget 1500 gear box oil changing MG 0
R MG MIdget 1500 gear box oil changing Spridgets 13
A TR4/4A TR4 gear box question Triumph 4
tahoe healey Gear box dip stick Austin Healey 2
R Gear Box/Stick Problems Austin Healey 5
W O/D Gear Box Or Not MG 28
W 5 Speed conversion gear box MG 3
A TR2/3/3A TR3 gear box dismantle question Triumph 1
A TR4/4A TR4 gear box oil Triumph 13
A TR4/4A Converting TR4 gear box to O/D Triumph 4
W MGB MGB GEAR BOX OIL. MG 7
tahoe healey gear box/ OD oil Austin Healey 6
tahoe healey gear box drip Austin Healey 7
