Gear box whine
Barry72B
Hi,
My 1972 MGB gear box whines when in neutral and engine idling, the noise goes away if I press the clutch in or roll the car back or forwards about 1 foot. clean castrol GTX 20w50 in it & up to the high mark.
What could it be?
Thank you,
Barry
Ralph_Y
Member
Probably normal input shaft noise, if it is just loud enough to be annoying and not frightning.
B
Barry72B
Hi Ralph,thanks for the reply.
The noise is annoying and propebly a bearing,is it going to
damage other parts ?
Barry
Ralph_Y
Member
I have the same type of annoying whine and am living with it until I have to pull the engine and or transmission for other work. One thing you can do is check to see if it is a throw out bearing problem. Car idling, transmission in neutral, reach in and push the clutch in until it <u>just </u>begins to make "contact". you should be able to feel/hear a substantial change if it is the throw out bearing. When I did this = no change. Others that i respect on the boards told me this more or less eliminated the TO bearing from consideration. Perhaps the real experts can correct or modify my advice.
If it is a bearing failure can possibly damage other items. Wait for people who have more experience than I to chime in for a a more definitive answer.
B
Barry72B
Thanks, I will test TO bearing & report back.
I also posted on MGB Experience board.
Any safe additive to quiet down the box ?
jlaird
No additives.
ronzet
Or thicker oil to increase oil pressure...
The logic of avoiding the unavoidable....IMHO /bcforum/images/%%GRAEMLIN_URL%%/rolleyes.gif
PAUL161
My guess is with the rest. Input shaft bearing is worn. Mine has a slight bearing noise when idling, but not annoying yet. I wouldn't let it worry you. Naturally, if you have to pull the engine for any reason, I'd put a new one in.JMHO. PJ
jlaird
Input shaft from the rear is turning something that is makeing a difference in the way it all fits together. Bet you knew that.
Shoot I am not a tranny expert or even a non-expert, leave the rebuilding to the pros.
L T-Series Gear box servicing cap. MG 5
Todd78d Sprit MK1 gear box filler Spridgets 2
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
D Socket for TR3 Gear box drain plug Restoration & Tools 6
Joe_Healey TR5/TR250 Overdrive Gear box oil Triumph 8
F BN1 vs Bn2 gear box Austin Healey 23
B General TR Putting the rebuilt gear box back in the TR6 Triumph 1
Got_All_4 General TR Problem mounting the a type to the gear box Triumph 12
K TR2/3/3A Gear box to Motor Bolts? Triumph 6
Got_All_4 TR2/3/3A Continually Rebuilding of my J Type Gear Box Triumph 2
Got_All_4 TR2/3/3A Removing the J type unit from the gear box Triumph 24
J TR2/3/3A Gear oil in the gear box? Triumph 13
S TR6 Help installing the Gear Box 1972 Triumph TR6 Triumph 13
J Healey Gear Box & OD oil Racing 5
D gear box fill plug Triumph 13
andrea $ SPEED SIDE SHIFT GEAR BOX Unknow spare piece Austin Healey 3
tahoe healey Gear box woes Austin Healey 10
ekamm TR2/3/3A Tr3 steering gear box removal Triumph 6
Got_All_4 TR2/3/3A Prize in every box! TR3 gear box Triumph 30
A Gear box oil MG 9
ekamm gear box oil Triumph 13
W Over drive gear box MG 0
J Gear Box Jaguar 10
tahoe healey Fillintg the gear box on a BJ* Austin Healey 3
TRnorwegian Japanese gear box better? Triumph 29
R T-Series TC Steering Box Worm Gear MG 1
mountainman TR2/3/3A TR3 STEERING GEAR BOX FLUID Triumph 5
Tinkerman TR4/4A Cluster gear removal TR4 syncro box Triumph 2
W Silly question Gear Box oil change/top up MG 11
J Speedometer housing at gear box Spridgets 2
Tinkerman TR2/3/3A TR3 gear box shaft selectors Triumph 6
Tinkerman Cleaning Tranny, OD and Gear Box Covers Triumph 9
Got_All_4 TR2/3/3A Removal of Steering Box Worm Gear In Car TR3A Triumph 3
M Gasket sealer on bell housing to gear box Austin Healey 13
M Steering gear box zerk fitting Austin Healey 16
LuckyLuke Right Oil for BN1 axle and gear box Austin Healey 4
tahoe healey big gear box problem Austin Healey 7
R MG MIdget 1500 gear box oil changing MG 0
R MG MIdget 1500 gear box oil changing Spridgets 13
A TR4/4A TR4 gear box question Triumph 4
tahoe healey Gear box dip stick Austin Healey 2
R Gear Box/Stick Problems Austin Healey 5
W O/D Gear Box Or Not MG 28
W 5 Speed conversion gear box MG 3
A TR2/3/3A TR3 gear box dismantle question Triumph 1
A TR4/4A TR4 gear box oil Triumph 13
A TR4/4A Converting TR4 gear box to O/D Triumph 4
W MGB MGB GEAR BOX OIL. MG 7
tahoe healey gear box/ OD oil Austin Healey 6
tahoe healey gear box drip Austin Healey 7
