Tinkerman
I can move the cluster gear set upwards out of the box about an inch and the back end hits something with a resounding metal clank. Nelson Riedel suggests that removing the rear thrust washer should give enough clearance to remove the gears. It has, so far, resisted my attempts at removal. Going to take a lunch break and think on it. Maybe I will get some inspiration. Will work on the thrust washer when I get back.
In the meantine if any of you have any thoughts I would appreciated them.
Tinkerman
Tinkerman
