General Tech Gear Shift Sticks
KVH
I have a problem and I don’t think it’s internal to the transmission. I think it relates to the stick shift. When I try to takeoff from a stoplight and put it in first gear, I am totally stuck until I fiddle with the shifter, often lifting it up about an eighth of an inch and then pushing it forward into first. I have other problems with the shifter, too.
For example, sometimes when I’m in neutral the shifter won’t wobble back-and-forth as it should. It is absolutely stuck. Only way I can release it is to lift it or play with it or maybe double clutch. At other times, I have no problem at all with the shifting or the transmission, and I just enjoy a nice drive. Then, suddenly, I can’t takeoff from the stoplight until I play with the shifter again.
I am very willing to remove the dash support saddle and inspect the ship mechanism, spring, and anti-rattle pin, but I’d really like to avoid pulling the center consul entirely.
Do any of you have any thoughts as to what’s going on here and what I need to do? I’m doubtful I have a shift fork issue, but I did replace those “detents” a few years back. Can’t imagine that’s a problem but I don’t know.
thx all.
titanic
I was surprised about how much the effort to shift was effected by lack of lube and dirt between the gear lever cap and retainer spring (Moss part # 845-185&848-170). This may or may not be the cause of your problem, but is an easy culprit to eliminate.
Berry
KVH
KVH
I’m going to try that first chance I get. I’m actually hoping to find something lodged there, because I can’t figure the problem logically. If there were a syncro or shift fork issue I don’t think I’d be able to wiggle or lift my way around the problem or that it would appear so sporadically and randomly. Something is jamming.
CJD
It sounds like something on the shift lever is worn...either the ball is loose on the shifter, or the end of the lever is worn where it engages the shift rods. Of course, Berry may be right and it's just old, gummy grease sticking things. All of this can be checked by just pulling the rubber boot and shift lever cap.
KVH
KVH
Are new shifters available? My recollection is “no” from Moss. It is for a TR4 but not for a TR4A. And I do recall that mine was quite worn in the location where the antirattle pin sits. I will take a look.
KVH
KVH
Holy Cow, does anything ever get easier? I just pulled my console and removed the shifter to inspect it. To me, it doesn't look worn, and the ball looks normal, but I was shocked to find no spring or anti-rattle plunger. I know for a fact, a given known fact, that I put a spring and plunger in there. I say that because I rebuilt the overdrive and put everything back twice (long story). I recall dropping the plunger and finding it after much effort, and then carefully putting it back in. If somehow, after all my care, I actually dropped it again and didn't notice, I'd be sufficiently alarmed to suspect senility. So, here's a question. Is it in any way possible that the plunger I put in there could slide out two years later while I was shifting, and that's how I got stuck to begin with?
I just can't imagine that happening. I'm now ready to put in a new spring and plunger. To me the plunger (I keep spare new parts) looks awfully short. It's 5mm in length and protrudes the shifter with the spring in place by only about 1.5 mm.
About worn shift rods, mine look perfect. And my spring under the shifter cap looks good. I think that's new, too. I'm wondering about the diameter to the long bolt that does thru the shifter ball. I used a new one from the hardware store. Can't imagine that's an issue.
Well, I'd sure appreciate any thoughts. Thx all
(Geo, are you laughing at the hour of the night I send these posts out? Certain habits seldom change.)
Sarastro
It might have dropped out as you were installing the shifter, and you didn't notice it.
I'm not sure that would cause your problem. I think it would be a good idea to check everything else you can get to. Make sure that the screws holding the selector rod ends are tight, for example. Beyond that, I can't imagine any other cause.
S Gear Shift Lever Travel Austin Healey 13
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
S TR2/3/3A Gear shift knob Triumph 8
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
J TR2/3/3A such strange thread on gear shift knob Triumph 12
RAC68 First Gear Shift Difficuties Austin Healey 3
Rob Glasgow Wanted Austin Healey Gear Shift Lever Austin Healey Classifieds 2
G BJ-7 Center Shift Gear Lever and bush Austin Healey 4
Michael Oritt Gear shift lever modifiacation [No Healey Content] Austin Healey 7
wangdango BJ8 gear shift consol restoration... Austin Healey 9
tinman58 TR5/TR250 Funny sounds from gear shift Triumph 4
Rut 5 speed gear shift lever Spridgets 28
Rut MGB MGB OD gear shift lever MG 0
6 Gear Shift Lever Spridgets 3
T TR2/3/3A Rubber gear shift boot tearing Triumph 14
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
KVH TR4/4A Top Gear Shift Mechanism Triumph 4
T TR4/4A Second gear hard to shift into on first try Triumph 10
af3683 TR2/3/3A TR3 Original Gear Shift Knob Triumph 16
mdw BJ8 gear shift thread Austin Healey 7
T TR2/3/3A TR3B gear shift lever Triumph 6
C Gear shift patten on a Super 7? Other British Cars 6
brgrmyster GTG6 Gear Shift Lever Inner Ferrule? Triumph 0
S Gear Shift Freezes Between Shifts Jaguar 1
K TR2/3/3A TR3 Gear Shift Anti Rattle Spring ##%&*rikerfrats Triumph 8
andrea $ SPEED SIDE SHIFT GEAR BOX Unknow spare piece Austin Healey 3
PAUL161 Gear Shift Lever Thread Size? MG 28
A New!!! Gear Shift Knobs for 5 Speed Transmission Triumph 1
jerrybny Gear Shift Triumph 4
R gear shift stick movement in 3rd gear question Spridgets 46
Tinkerman TR2/3/3A TR3 A Gear shift question Triumph 3
davidk Gear Shift Lever Vibration Triumph 4
Tinkerman Gear shift lever threads Triumph 21
jpr28056 Gear shift lever twisting Spridgets 10
JPSmit Gear Shift threads and trivia question Spridgets 1
SCguy TR4/4A TR4 gear shift knob Triumph 13
gsalt57tr3 Gear shift knob idea Triumph 7
Dave Richards Gear shift Surround Trim Austin Healey 6
jjbunn Confused about gear stick/shift knobs MG 14
kyreb1862 Gear Shift Knob Removal MG 7
RSMTR8 Wedge TR8 Gear Shift Knob Triumph 7
Tinkerman TR2/3/3A TR-3, Pitting on gear shift lever ball. Triumph 2
Frank C. Gear Shift Boot Installation Austin Healey 18
MrPandy TR6 Question about TR6 gear shift knob Triumph 15
G Transmission will not shift into any gear Spridgets 2
S Gear Shift Knob Jaguar 3
J 73 Gear shift knob MG 0
L T-Series Gear box servicing cap. MG 5
