TR4/4A Second Gear Bushing
DocDup1
I am trying to gather parts for a repair on my TR4A gearbox and I am searching for a top hat bushing for second gear. It seems that the steel bushings are not available and will not be for a while. I have found a bronze bushing from Moss and a brass bushing from Rimmer Brothers. I just assumed that it would be bronze. Can anyone tell me the pros and cons of brass vs bronze? Thanks
Sarastro
I'm sure they are the same bushings, but many people can't get it straight. Usually they are bronze, as I understand it. Bronze generally has better strength and wear characteristics than brass alloys.
Bronze is an alloy of copper and tin, often with other elements to improve its hardness and tensile strength. Brass is fundamentally an alloy of copper and zinc. There are lots of different flavors of both, depending on the tin/zinc content and other minor alloying elements.
DocDup1
DocDup1
Thanks, I thought that might be the case but the price is $90 at Moss and $47 at Rimmer Brothers. That is about the normal difference between the two companies. I will call Rimmer Brothers and ask about the material.
Doc
CJD
If done properly either will work. Bronze has a slight high temperature advantage.
mastaphixa
Bronze
I think you will find there is more to it than just swapping out the bronze/brass for the steel. The flange on the steel bushing is thinner than the bronze and requires a thicker spacer to make up for that. I believe it also has a dedicated 2nd main shaft gear which may affect your 2nd gear on the lay shaft.
AUSMHLY BJ8 Second Gear Needed Austin Healey 16
O TR4/4A tr4 pops out of second gear on deceleration Triumph 13
S Issue with second gear slipping out... Austin Healey 12
J T-Series Clatter in second gear only? MG 1
T TR4/4A Second gear hard to shift into on first try Triumph 10
W pops out of second gear on acceleration Austin Healey 12
L Popped out of second gear! Austin Healey 4
bthompson I've lost second gear!! Spridgets 95
T Argh! Jumping out of second gear now Triumph 10
T Flat. Stopped. First or second gear? Austin Healey 4
K Second gear grinding Triumph 17
S TR2/3/3A welders have a second Triumph 5
Basil Second Telluride Spotting at Costco Spotted 0
D Lilly second time running... or trying Austin Healey 8
GTP1960 Here's one worth a second look. Other Cars 1
gbtr6 TR6 Top Cover On, won't go into first or second Triumph 6
S TR2/3/3A Well onto the second half Triumph 2
I adding a second fuel pump Austin Healey 16
Basil Lotus and Jags second try Spotted 3
H second guessing myself-oil thrower question Austin Healey 2
M MGB Second MGB Off Production Line and First LH MGB [GHN3L/102] MG 3
Triumph_TR4_Girl TR4/4A Second Hand Copy of Original Triumph TR4 Triumph 1
B Second picture. I don't quite get this yet Triumph 1
N What to buy, second try MG 26
K Second hand spoked rims Triumph 18
W Second Motor, looking to rebuild it Triumph 16
tinman58 Second thing to check Triumph 14
L Difficult to engage second MG 4
R Need a Second Opinion Spridgets 17
Marvin Gruber XKE second opinon Jaguar 28
T TR6 Purchased a second TR6 Triumph 29
R My second crash and first in a car. Austin Healey 9
Sopwith_Camel from last summer my second to last day in norway Spridgets 8
JPSmit second verse same as the first [almost] Spridgets 13
Brosky eBay Hardtop, second go around Triumph 5
hondo402000 TR6 TR6 rebuilt the Front Calipers, second time Triumph 2
Dadandson My 1974 Midget took Second!! Spridgets 6
Brosky TR6 Second chance on Special Order white/blue TR6 Triumph 8
T Today's Second Stupid Question? Triumph 8
John_Mc Second boot lid Triumph 0
S Second blown head gasket in my Midget! Help? MG 21
P Second Time Around... Spridgets 2
drooartz High idle, second test Spridgets 3
simpzimmer Second Question British Motorbikes 6
RobT Second Failed Ignition Rotor in 100 miles???? Triumph 14
L Help!! wife says I'm in second childhood MG 5
J so i'm kinda having second thoughts about my car.. Austin Healey 29
J New lotus offshoot Vauxall version of elise with turbo pulls 4.5 second 0 to 60mph! Lotus 0
L T-Series Gear box servicing cap. MG 5
