TR2/3/3A 1st gear again
TomMull
There was an earlier thread about jumping out of first gear https://www.britishcarforum.com/community/members/paullongbl.18115/ but I decided to start a new one since I have never driven with this gearbox so I don't actually know that it does that but it certainly should from the looks of it.
It looks like the springs and balls that ride on the teeth froze at some point and took out the splines. At any rate, if someone has a decent used 1st gear available I'd be interested. (Moss wants 489.95 for a new one). The teeth are not up to John's (CJD) standards either but I could live with that.
Tom
mastaphixa
Bronze
Tom,
I'm won't be home till next week, but I've got 4 of these boxes sitting in my storage container. If you haven't got a lead on a part by next week, PM me and I'll find one for you.
Steve Baker
CJD
As strange as it seems, I have seen other sliders that were machined that way. I have no idea why, but I do believe the factory did it. I would not reject the hub just for those 2 splines. Now your 1st gear teeth could use some dressing...
TomMull
TomMull
Thanks for the reply John. You are absolutely right. I just took the second one apart (found it in one of my own bins) and they are identical, right down to the bad teeth. I can only guess that they were done that way to get the correct load on the balls.
Tom
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
AUSMHLY Remanufactured Laygear with welded 1st gear Austin Healey 20
P TR2/3/3A Help needed. TR3A transmission popping out of 1st gear Triumph 13
R bj7 hard shifting into 1st & 2nd gear Austin Healey 6
J BN2 Tranny Jumping Out of 1st Gear Austin Healey 1
H 1st and 2nd gear problems Austin Healey 5
theleisure Stuck in 1st Gear Spridgets 11
T Wedge I just lost 1st gear in the TR8 Triumph 11
N Starting out in 1st gear knock or clunk Triumph 20
J 1st gear problem, jumps out Austin Healey 13
V T-Series 54MGTF jumps out of 1st gear MG 4
W Noise in 1st Gear Austin Healey 13
Bruce Bowker MGB MGB synchro 1st gear MG 5
Tim Hollister Rib Case Trans Problem - 1st Gear Spridgets 6
Webb Sledge 1st Gear Ratio on a Healey Hundred Austin Healey 2
V BN1 gearbox question - "1st gear" Austin Healey 3
AUSMHLY 1st Motion Shaft Bearing Austin Healey 7
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
M T-Series MG TD 1st/2nd sliding hub end play MG 1
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
AUSMHLY 1st Motion Shaft Play Austin Healey 3
Hamish Racing 1st sprint of the season Racing 10
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
KVH General Tech Grinding Gears in Shift From 1st to 2nd Triumph 13
JPSmit 1st Gen Acura NSX - spotted Other Cars 1
Tom74TR6 Off Topic British Cars and Coffee in North Salem NY Nov 1st MG 0
Tom74TR6 Off Topic British Cars and Coffee in North Salem NY Nov 1st Triumph 9
Tom74TR6 British Cars and Coffee in North Salem NY Nov 1st Jaguar 0
Tom74TR6 British Cars and Coffee in North Salem NY Nov 1st Austin Healey 0
C Looking for 1st British sports car TVR 6
Jer Another Co-Pilot, New Parts & 1st Ride Spridgets 10
6 It's snowing, 1st real one here! Spridgets 5
Jer Wife's 1st drive alone in Bridget Spridgets 7
Randy Harris Congrats AUSMHLY on another 1st Place! Austin Healey 7
hilsideser Rochester Hills, Michigan on June 1st Spotted 0
J Buying a Sprite as 1st time classic car buyer Austin Healey 10
doates 1st Real Drive Triumph 7
kodanja 1st Drive of 2011' Triumph 4
robdmau 1st things to look for before driving... Spridgets 10
JPSmit 1st time - 1500 engine on ebay. Spridgets 13
rikiwho123 starting rebuilt 1300 for 1st time Triumph 7
RickB MGB-GT 1970 MGB GT restored by Chris Longo - 1st in show! MG 10
prb51 1st oil change on rebuilt motor Triumph 4
Tr4dude TR4/4A anybody want 1st crack on tr4 bitsbefore fleabay Triumph 2
R lost 1st and 2nd! Spridgets 10
NardisCNC 1st Time Overhaul / Performance questions?? - 1275 Spridgets 17
NardisCNC Gearbox Noise in 1st!! - Is this normal?? Spridgets 13
Westfield_XI 1st Drive in 11 replica !! Lotus 16
Westfield_XI 1275 firing order- help needed for 1st start! Spridgets 9
