lost 1st and 2nd!
rightlane
hello all, my '63 sprite has been having some issues popping out of 2nd gear on the downshift for about 3 days. today i can barely get 1st to grab and can't find 2nd at all. 3rd and 4th are working just fine. when i clutch out in 2nd i don't even get a grind and 1st, if i can find it, has a tendency to pop out. any help or advice on the matter would be greatly appreciated. thanks, Chris
smaceng
Hi,
1st thing would be to check the level of the oil in the transmission. 2nd would be to make sure you have brake fluid in the brake/clutch reservoir in the engine compartment. 3rd would be to have a helper safely get under the car, and with the engine off and the body secured, and for you to push on the clutch pedal. The helper should verify that the clutch rod is moving correctly.
Good luck, there is not much else you can do, other than taking it out.
Scott in CA.
bgbassplyr
Bayless
:iagree: Yep. Sounds like the fork all right.
jvandyke
I would suggest you hunt down a known "decent" gearbox (~$100) Pull and swap. Tear down and assess the old gearbox at your leisure, fix it up for when the replacement needs replacing. My '63 had a 3/4 slider go bad and I swapped gearboxes to get back on the road. Don't be put off by the engine pull and swap it is really quite easy.
Deleted member 8987
Can't you access that from the side cover?
Been a lot of years, but I think I remember having to do that in a shop once or twice.
You access the pins on the forks through the side cover anyway for disasembly, right?
I think (therefore I am, I think) I dropped the trans as low as I could, drained, pulled the side cover and replaced the pin.
But, might just be scrambled memory banks.
Dave
jlaird
You can, but best know what you are doing as it is all by feel work.
Deleted member 8987
Well, at least I remembered correctly.
Oh, and it was on a hoist, not on my back.
R
rightlane
i just pulled the engine/gearbox and accessed the box from the side. it looks like both shift selector forks seem very loose. is there a simple way to make sure they are adjusted right? thanks for your patience. chris
jlaird
Of course, the bolts with the locknuts go into detents on the shift shafts.
Spridget64SC
Most of the time, the wear is on the inside of the fork and not readily visible from the side cover. These forks can be "Tightened up" in a vise, but this is a very subjective process and needs to be checked with the slide gears themselves and the detent locations. You might be able to peek at the inside of the fork using a small inspection mirror and light. If there is brass deposit on the sides of the slide gear, that is a sure sign of excessive/catastrophic wear and implications of the need for replacement.
HTH,
Mike Miller
T Wedge I just lost 1st gear in the TR8 Triumph 11
D TR6 lost body shell Triumph 1
pbraun Moke America lost trademark name "MOKE" Other British Cars 0
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
G TR2/3/3A Finding a long lost TR3 Triumph 4
Got_All_4 TR5/TR250 Lost Turn Signals Triumph 2
B Lost Title Woes Restoration & Tools 9
B Lost & Found FORUM Navigation Questions 3
Rut I’ve lost my mind, or what’s left of it! Spridgets 12
D Long Lost Midget Spridgets 0
E Long lost Sprite Spridgets 10
Northcoaster TR4/4A Lost info on person interested in my valve cover Triumph 1
steveg Steve Kingsbury has lost everything. Austin Healey 11
mgedit TR2/3/3A Lost Spark Triumph 26
RAC68 Lost 8 terminal Flasher Relay Plan Austin Healey 39
Basil Lost a member - Blueghost Spridgets 9
P TR6 Lost posts Triumph 3
F Looking for Long Lost BJ-7 Austin Healey 2
DrEntropy We've apparently lost another one Racing 1
J Stator tube lost in steering box Austin Healey 11
YYCDave TR2/3/3A Lost Triumph Found Triumph 5
L TR2/3/3A Tr3a lost power go uphill Triumph 21
Boink Great day for a drive... even if briefly lost. Spridgets 0
Lukens TR2/3/3A Lost a hinge pin on my TR3 Triumph 3
T lost in the forms FORUM Navigation Questions 2
aeronca65t Lost a great friend of vintage racing. Racing 1
DNK I have compleately lost it... Triumph 73
wangdango Lost BN2? Austin Healey 1
bobmga62 Lost 4th gear at high revs Triumph 10
8 Lost 3rd & 4th Gear ?? Triumph 18
Jer Spridget's are like a lost Puppy... Spridgets 17
W Lost part, look for help and or options Triumph 9
S Wedge Lost stray, TR7 to 8 parts Triumph 11
T BJ7 -lost reverse, then 3rd/4th - advice please! Austin Healey 10
J I've lost Reverse! MG 13
78Z Lost luxury - Austin P Spotted 3
G 1500 Dual Carbs in, rims lost in space... Spridgets 12
tahoe healey lost boys Austin Healey 10
jvandyke I've lost 4th gear! Spridgets 36
bthompson I've lost second gear!! Spridgets 95
G Lost spark [ Best ignition coil for a stock '79] Spridgets 18
Stewart I think I've lost it MG 15
DNK Have We Lost a Member Triumph 30
G Lost part Triumph 10
TonyPanchot lost oil pressure help please Triumph 23
SCguy TR4/4A lost link... TR4 rear shock rebuild Triumph 4
T Have I lost my mind??????? MG 9
M Lost out on Bugeye Spridgets 37
rick_ingram Enthusiast lost MG 1
6 Looking for a lost part. Spridgets 5
