Lost spark [ Best ignition coil for a stock '79]
G
Long story short, it's time to change my ignition coil on my all stock '79. I'd rather not put a "stock" coil back on it and would like to put the hottest thing on it that's compatable w/ the stock dizzy & etc.
Anything alvalible for ballasted 1500's other than stock?
Can I run the Lucas sport coil w/o a resisitor or will that fry the dizzy?
Would I have to change trigger mechanism in order to run A "HOTTER" coil? ( Pertronix maybe?)
Thanks, BIlly
sparkydave
Re: Best ignition coil for a stock '79
Not sure what the stock ignition is capable of driving, but you might want to consider a Pertronix. The stock electronic ignition was notorious for frequent failures. Lucas finally ditched the old system and was retrofitting the failed ones with a completely different one. Pertronix makes a replacement that's easy to install. FYI, the ballast resistor is NOT the resistor attached to the pedal box, it's actually a resistance wire built into the harness.
Out of curiosity, what's wrong with the stock coil?
G
Arching from the coil tower to the + - leads on the sides. Good plugs, cap, rotor and wire. Can only see it at night. The car runs fine and once it warms sometimes it misses under load. It acts like a carb, but it's brand new (DGV). I pulled it down anyway just to chaeck and all seems fine. A little casting flash that came right out. I thought that might be it but now it's doing it again.
I might swap to pertronix and a hotter coil. Thanks for the heads up on the ressitor as I would have bet $$$ it was the one on the pedal box.
tweety
Splain Lucy Slain.... Seriously, can someone elaborate more on this.
sparkydave
The resistor attached to the pedal box is called the drive resistor, and it's actually part of the stock electronic ignition system, but it's not the ballast resistor in the coil's primary. An aftermarket ignition system like the Pertronix won't need that drive resistor. I left mine in place, and left it connected to the distributor's wiring harness so that I could drop in a still-working stock distributor. The ballast resistor for the coil isn't a discrete resistor (i.e., you won't find an actual resistor anywhere), but it's a resistive wire that looks like ordinary wire.
tweety
ok, that all makes sense......
Is the entire resistive wire white/green? Is the entire lenght of the wire used to achieve the resistance, or is it a short length? What happens if that wires fails? Can it be replaced with a standard coil resistor? If you go with a non ballasted coil, can you just bypass it?
For some reason, this post made all of this "click" in my head. The main reason I ask about the wore failing is that I found a "burned" wire in the engine bay harness. I found it shortly after I bought the car. I did not burn via any type of contact with a hot item, it burned from the inside out. The burned area was short (only about 4") so I simply spliced a new piece of wire in its place. Off the top of my head, I can't remember what color the wire was. I do recall it was connected to the starter solenoid.
This all just has me wondering if this wire might have been the resistive wire. Resistors do their thing by throwing off voltage via heat. Too much heat means that the resistive wire would cook.
Sometimes I think too much, but that's how I learn.
G
.......anyway, the car crapped out on me today. It started running on 3 cyls. I pulled over to check it and had no spark to #1. I turned around to go back home and lot all spark.
I check all of my manuals and there are NO specs at all for ANY of the ignition componants. I've done some preliminary testing and have 3.4 ohms across the pickup and voltage to the coil.
What's the specs on the box?
Also, I think my pick up has been changed as the pug on the dizzy side is different from the box. It looks to be aftermarket but I don't know for sure.
I want all of this stock garbage gone. Is petronix stand alone or needs to go through the box?
dklawson
The traditional color Lucas used for the ballast/resistor wire is "Pink" or Pink/white. It's unlikely to burn out unless you shorted its far end (away from the ignition switch) to ground. However, anything is possible with Lucas.
Sorry, I don't have any suggestions about alternate performance coils.
G
I just realized, I have 12v to a coil that reads 1.8 ohms. That isn't right! No wonder it went "POOF". The strange thing is, I've never had any problem with it and had driven it off-and-on for 6 years and 6000 miles just like it is. I didn't touch ANYTHING on the ignition.
No pink wire, I've got double white wires w/ green stripes. I have a signal from the pickup. It's had to read but it's there. My meter isn't quick enough to get a ggod reading. If I knew which end was up on the pickup coil, I'd just convert to GM 4 prong HEI module. I really think it's the box.
dklawson
Before you say you have a problem based on your voltage measurement... read on.
You cannot simply turn the ignition switch and make a voltage measurement from coil (+) to earth to determine the coil voltage. You MUST make sure current is flowing through the coil when you make this measurement. This is easily done by one of two ways.
1) on cars with points, remove the dizzy cap and fit a coin between the contacts, then make your voltage measurement.
2) on cars with electronic ignition (or on cars with points if you prefer this method) run a jumper wire temporarily from coil (-) to ground.
With either of these methods, you are assuring that the coil power has a path to ground and therefore, any voltage drop created by the ballast resistor or resistor wire is will be measurable between coil (+) and ground. If you fail to use one of these two methods, there's a chance the points are open (or ignition module is "off") and therefore no current flow. When current is NOT flowing you will ALWAYS measure battery voltage on coil (+) when the ignition is on.
Succinctly, you must have current flowing through the circuit for the ballast resistor to create the voltage drop at the coil.
G
Doug, what you're saying doesn't make any sense as the resistor in my case is (supposed) to be b/w the coil and battery, thus voltage will be dropped to the coil when the wire is grounded....either through the module or a voltmeter, it doesn't matter as the wire is still seeing ground either way and current is flowing through the wire to the mater and then ground.
Moss Motors ever says to perform the same test to see if your car is equipted with a ballast resistor or not. I'll get the link in a minute.
Here it is:
https://www.youtube.com/watch?v=pWxJmbm5V3s&feature=player_embedded
Don't forget, I'm concerned about voltage TO the coil, not THROUGH it as I already know my coil resistance vaule so voltage drop is not needed.
dklawson
The Lucas electronic ignitions are not something I work with so I cannot comment on their specifics. Regardless, I have watched the YouTube video link you provided and frankly, they are wrong and have oversimplified the test.
I wrote and deleted a lengthy explanation. Suffice it to say that the Moss video demonstrates half the test steps. They are assuming that the points are closed (or module conducting) to determine the coil operating voltage. The points must be closed so current will flow which allows the ballast resistor to "drop" the coil voltage. You cannot assume that the points are closed. The added steps I listed above (coin between the points or a jumper wire to ground from coil (-)) will insure current is flowing through the coil (and any ballast resistor) during the measurements. Skip that step and your readings WILL give you a 12V reading if the points (or module) are open.
Also, a voltmeter is not a path to ground, exactly the opposite. Multimeters are set up to have very, very high impedance so they do not become a conductive part of the circuit. You do not want a volt meter providing a "short" to ground during test measurements.
G
In the intrest of science (and the fact I like to argue and be right) I rigged up a test using a light to replace the grounded coil to simulate current flow as you described. The results prove undoubtedly that you sir are.......................CORRECT !!!!!!!
It dropped down to 8.5 ahead of the light.
What I don't understand is why are they running a resisted wire to a GM module designed to run off of 12V straight......unless the pickup coil can't handle it or this is the "other" system used later to replace it?
dklawson
Again, I'm not familiar with the Lucas electronic ignitions so I can't comment about why they powered the module the way they did. Powering the module from a line with a voltage drop does sound like a problem. However, perhaps they designed the module so it can operate from supplies ranging from 6V to 14V. I simply don't know.
I do know that an often reported problem with Pertronix modules is when their power supply line is connected to coil (+) on ballasted ignition systems. Some Pertronix modules seem to work OK with that reduced voltage, many do not.
sparkydave
I can't comment on the Youtube video yet, but I concur that if the points are open then just measuring voltage across the coil won't work. It's possible an electronic ignition can have the same problem if one of the rotor slots lined up with the pickup. Connecting a jumper from the coil "-" to ground and measuring between ground and the coil "+" with the ignition on would be a sure fire way to determine if you have a ballasted system or not; ~12 volts would be no ballast, ~6 volts would be with ballast. Since the jumper would be diverting the current, it would also be safe to do this with a Pertronix without having to worry about overheating the Pertronix module.
Sarastro
I've been requested to comment, but as with most things in my life, I'm coming in late.
Doug is quite right, of course, and, as usual, explained it all very well. I'd only add a couple things: first, if you ground the negative terminal of the coil, either with a jumper or by putting a coin in the points, be sure that power is off before you disconnect the jumper or remove the coin. If it's hot, breaking that connection will generate a voltage spike that will definitely get your attention. Second, measuring the voltage at the coil, with the points closed as suggested, will tell you if you have an external ballast resistor, but you may have a 12-volt or, as it is sometimes called, an "internally ballasted" coil. That's just a coil with a higher resistance, so it doesn't need an external ballast resistor. In that case, you'll see 12 volts in the measurement, since you don't have an external resistor. But that doesn't mean that you need one.
One of the best ways to tell if you have a ballast resistor is just to look for the sucker. They're not microscopic. If you don't see one, you might still have a resistor wire that performs the same function or a ballast resistor mounted somewhere out of sight. So, the voltage measurement, properly done, still makes sense.
dklawson
Thank you Steve and Dave. Your comments are greatly appreciated. Good point about shutting off power before removing the jumper or coin. I have been "bitten" by forgetting that.
G
see post below (I couldn't get the quote to stick)
G
You must have missed the above post.
It's a stock '79, no points.
mgedit TR2/3/3A Lost Spark Triumph 26
D TR6 lost body shell Triumph 1
pbraun Moke America lost trademark name "MOKE" Other British Cars 0
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
G TR2/3/3A Finding a long lost TR3 Triumph 4
Got_All_4 TR5/TR250 Lost Turn Signals Triumph 2
B Lost Title Woes Restoration & Tools 9
B Lost & Found FORUM Navigation Questions 3
Rut I’ve lost my mind, or what’s left of it! Spridgets 12
D Long Lost Midget Spridgets 0
E Long lost Sprite Spridgets 10
Northcoaster TR4/4A Lost info on person interested in my valve cover Triumph 1
steveg Steve Kingsbury has lost everything. Austin Healey 11
RAC68 Lost 8 terminal Flasher Relay Plan Austin Healey 39
Basil Lost a member - Blueghost Spridgets 9
P TR6 Lost posts Triumph 3
F Looking for Long Lost BJ-7 Austin Healey 2
DrEntropy We've apparently lost another one Racing 1
J Stator tube lost in steering box Austin Healey 11
YYCDave TR2/3/3A Lost Triumph Found Triumph 5
L TR2/3/3A Tr3a lost power go uphill Triumph 21
Boink Great day for a drive... even if briefly lost. Spridgets 0
Lukens TR2/3/3A Lost a hinge pin on my TR3 Triumph 3
T lost in the forms FORUM Navigation Questions 2
aeronca65t Lost a great friend of vintage racing. Racing 1
DNK I have compleately lost it... Triumph 73
wangdango Lost BN2? Austin Healey 1
bobmga62 Lost 4th gear at high revs Triumph 10
8 Lost 3rd & 4th Gear ?? Triumph 18
Jer Spridget's are like a lost Puppy... Spridgets 17
W Lost part, look for help and or options Triumph 9
S Wedge Lost stray, TR7 to 8 parts Triumph 11
T BJ7 -lost reverse, then 3rd/4th - advice please! Austin Healey 10
J I've lost Reverse! MG 13
78Z Lost luxury - Austin P Spotted 3
G 1500 Dual Carbs in, rims lost in space... Spridgets 12
R lost 1st and 2nd! Spridgets 10
tahoe healey lost boys Austin Healey 10
jvandyke I've lost 4th gear! Spridgets 36
bthompson I've lost second gear!! Spridgets 95
Stewart I think I've lost it MG 15
DNK Have We Lost a Member Triumph 30
G Lost part Triumph 10
TonyPanchot lost oil pressure help please Triumph 23
SCguy TR4/4A lost link... TR4 rear shock rebuild Triumph 4
T Have I lost my mind??????? MG 9
M Lost out on Bugeye Spridgets 37
rick_ingram Enthusiast lost MG 1
6 Looking for a lost part. Spridgets 5
Sopwith_Camel lost in transmition Spridgets 4
