Lost 3rd & 4th Gear ??
83Pbass
Beautiful day in South Florida, 68 and sunny. So I decide to take the 4A to work this morning. Nice 10 mile ride down Juno Beach. At about half way I go to shift to 3rd and nothing is there, go for 4th and nothing. Basically the whole right side of the GBX feels like neutral. Turned around and drove home in 2nd gear. I have 1st, 2nd and reverse. Have I toasted my gearbox or is it some sort of linkage thing? Wife was pulling out of the drive way as I limped in. Yep, I got that look.
Sheeeeez !!
Mickey Richaud
DANG! :shocked:
Well, I don't know what I'm talking about, but I'll vote linkage.
TexasKnucklehead
Something in the top cover and selector section would be my guess as well. At least you don't have to pull the transmission out to check it.
Mickey Richaud
Fingers crossed here...
sail
:iagree: I would not drive it, if a setscrew came off one of the selector shafts and falls in the gears then you will really have a problem.
MikeP
I'd vote for the setscrew coming out of the fork, or perhaps a broken 3rd/4th fork. Since you have the other gears the rest of the linkage seems ok so I'd guess it's isolated to that one shaft and fork assembly.
83Pbass
Thanks all, so it sounds and feels like the shifter is no longer mechanically connected to the gearbox. Is it just a matter of pulling up the carpet and removing the top end cover of the the GBX to have a look. No fluids or gaskets to worry about?
This started on Sunday, out for a short drive and noticed that it sometimes only partially went into 3rd just did not feel right, would have to move the shifter around a bit to get it in gear. Then today poof! So it sounds like I may get off lucky, just a set screw or a $90.00 3-4 fork? Is this something a novice can do at home?
Thanks,
Jim
sail
Love and affection?
Pbass: I don't know your experience but you can do this. Here is a brief explanation. Really not so tuff to fix (if we are right) and not nearly as daunting as the gearbox itself. You will need to take out the dash support and gearbox cover to get to the top cover on the gearbox. Put it in neutral as best you can. There are 8 bolts holding the top cover to the gearbox case. Lift the cover, shifter and all up and off. Nothing flys out, nothing leaks. You will probably find the selector fork for 3rd and 4th, which is on the center shaft, is loose on the shaft. There is a set screw that holds it to the shaft which could be loose or might have fallen out. That is hopefully the problem.
Like I said, brief. Here is more info: Buckeye Triumphs Gearbox Cover
Scroll down to gearbox info
VTR Maintenance
TR3driver
Great Pumpkin - R.I.P
I'll also vote for the selector fork loose on the shaft. Had the same exact thing happen to me once in a TR3A, fixed it on the side of the road.
Hard part may be finding another one of those dang pins. Last I checked, they were NLA. If so, you may need to re-engineer the joint slightly (perhaps by reaming for a solid straight pin).
sail
Moss lists them part# 848-060 only $16.95. Later 3's thru 4A which do not have a hole for a retaining wire. 2 thru early 3 NLA. But before you order see if thats it and find all of the old one.
83Pbass
Well, just received a call from the mechanic. Apparently at some time someone modified the 3-4 selector shaft to a two piece unit similar to the 1-2 shaft. The modified end piece of the shaft has fallen off and it is gone. I now require a 3-4 selector shaft for my 4A. Now the best part, the shaft is not available from the after-market suppliers. Do any of you have any ideas as to where I may locate the part or a work around??
Thanks,
Jim
TR3driver
Check with Bill over at Slightly Classics; he supposedly has a bonepile of gearboxes sans bellhousings that he would like to give away. I'm hoping he can hang on until I get over there with a truck, but it hasn't happened yet.
If that doesn't pan out, let me know. I'm sure I've got a spare somewhere.
Machining one would be my last resort (even though I have the tools), as there are quite a few features that need to be precisely located for proper operation.
BTW, to the best of my knowledge, the shift shafts were always one piece (not counting the shift forks). If your 1-2 shaft is in two pieces, you might want to replace it as well.
rlwhitetr3b
Bronze
Take some black paint and remove the 3 - 4 leg of the H on the shift knob.
You did not specify a <span style="font-style: italic">good</span> work around. :jester: :devilgrin:
83Pbass
Found 3rd & 4th gear!! and then some. After much INTERNET sleuthing I found a guy that said he had a contact in England that could get a 3-4 selector shaft but it would take a few weeks. Well after 4 beautiful south Florida weekends with my TR on the fritz I had to do something drastic, Ebay. Came across a fellow in Ft Lauderdale who had a few complete top covers, one in particularly good shape. Grabbed it and went to see my guy. Within days me and my TR were back on the road. In all my excitement, I forgot about my connection across the pond, sure enough a few days after getting the TR on the road a package shows up at my door. I guess the English guy felt bad for taking so long ( now about 6 weeks) and sent me two 3-4 selector shafts. So I now have running TR and a plethora of top cover components.
While driving a bit yesterday I noticed a new noise. After initial start up I get some belt noise that quickly goes away. Yesterday the belt noised morphed into what sounded like an Owl under the bonnet. Lasted a few minutes and subsided as well.
Anyone else have birds singing in their bonnet??
Brosky
Watch out for water pump or alternator bearing noises. The two top suspects.
TR3driver
Had exactly that on the TR3 a few months ago. It was the front generator bearing. The screeching got louder, then quiet several times. I ordered a new bearing, and tried to keep driving the car, as it was quiet most of the time. But the last time it got quiet, it was because the bearing had locked completely, and the belt was slipping.
Fortunately, the new bearing came in the next day.
T BJ7 -lost reverse, then 3rd/4th - advice please! Austin Healey 10
D TR6 lost body shell Triumph 1
pbraun Moke America lost trademark name "MOKE" Other British Cars 0
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
G TR2/3/3A Finding a long lost TR3 Triumph 4
Got_All_4 TR5/TR250 Lost Turn Signals Triumph 2
B Lost Title Woes Restoration & Tools 9
B Lost & Found FORUM Navigation Questions 3
Rut I’ve lost my mind, or what’s left of it! Spridgets 12
D Long Lost Midget Spridgets 0
E Long lost Sprite Spridgets 10
Northcoaster TR4/4A Lost info on person interested in my valve cover Triumph 1
steveg Steve Kingsbury has lost everything. Austin Healey 11
mgedit TR2/3/3A Lost Spark Triumph 26
RAC68 Lost 8 terminal Flasher Relay Plan Austin Healey 39
Basil Lost a member - Blueghost Spridgets 9
P TR6 Lost posts Triumph 3
F Looking for Long Lost BJ-7 Austin Healey 2
DrEntropy We've apparently lost another one Racing 1
J Stator tube lost in steering box Austin Healey 11
YYCDave TR2/3/3A Lost Triumph Found Triumph 5
L TR2/3/3A Tr3a lost power go uphill Triumph 21
Boink Great day for a drive... even if briefly lost. Spridgets 0
Lukens TR2/3/3A Lost a hinge pin on my TR3 Triumph 3
T lost in the forms FORUM Navigation Questions 2
aeronca65t Lost a great friend of vintage racing. Racing 1
DNK I have compleately lost it... Triumph 73
wangdango Lost BN2? Austin Healey 1
bobmga62 Lost 4th gear at high revs Triumph 10
Jer Spridget's are like a lost Puppy... Spridgets 17
W Lost part, look for help and or options Triumph 9
S Wedge Lost stray, TR7 to 8 parts Triumph 11
J I've lost Reverse! MG 13
78Z Lost luxury - Austin P Spotted 3
G 1500 Dual Carbs in, rims lost in space... Spridgets 12
R lost 1st and 2nd! Spridgets 10
tahoe healey lost boys Austin Healey 10
jvandyke I've lost 4th gear! Spridgets 36
bthompson I've lost second gear!! Spridgets 95
G Lost spark [ Best ignition coil for a stock '79] Spridgets 18
Stewart I think I've lost it MG 15
DNK Have We Lost a Member Triumph 30
G Lost part Triumph 10
TonyPanchot lost oil pressure help please Triumph 23
SCguy TR4/4A lost link... TR4 rear shock rebuild Triumph 4
T Have I lost my mind??????? MG 9
M Lost out on Bugeye Spridgets 37
rick_ingram Enthusiast lost MG 1
6 Looking for a lost part. Spridgets 5
Sopwith_Camel lost in transmition Spridgets 4
