Lost 4th gear at high revs
bobmga62
Ran my spitfire for the first time at nhms this weekend..
During the first practice session, shifting into fourth on the main straight started to really tighten up
by the race, on the second lap on I could not shift into fourth at all.. could pull the lever out of third but its just balked up going into fourth..
between races I changed the transmission fluid to what I had on hand some synthetic and a mixture of pennzoil hypoid..
anyhow, the sam happened again at thigh speed.. ironically, as soon as I brought the revs down on the cool off lap, I was able to shift into fourth no problem.
Since this is registered for the street, I took it out today, absolutely no problem...
any suggestions, any experience with this problem before with members..
thanks
r
TomMull
Interesting issue and a tough one judging from the lack of responses. I don't have anything intelligent to add but will throw out a couple of ideas for discussion. There is a lot to go wrong with the linkage but nothing I can think of that's heat related. Nothing internal either. Is it possible that the problem arises from something becoming temporarily misaligned from hard running and not heat? The 3-4 synchro then comes to mind. Can you tweak it in with double clutch?
Good luck with it. Tom
tdskip
This is a total wild guess, but heat/foaming or something like that preventing proper synchro lubrication?
Doesn't seem likely as I type this...
DNK
I thought that earlier Tom, wasn't sure how it would effect things.
TR3driver
Great Pumpkin - R.I.P
FWIW, Ken G. (a former Triumph dealer mechanic) wrote some years back about problems with using synthetic oils that were too 'slick' for good synchro operation. Symptoms sounded similar to yours, gearbox worked fine at first but started refusing to go into gear when it got hot. I think that was a 'big' TR gearbox, but the Spitfire box works the same way, so might suffer from the same problem.
I'd give the MT90 a try.
DNK
Either way sounds like he needs some track time to heat up that box at speed to try different fluids
bobmga62
bobmga62
i'm inclined to think its a lubrication issue myself....
(back in my early race days, just ran straight 40 weight racing oil.. never had a problem???
will need to schedule in a test day at nhms (only 100 miles) away, cause all other events are 400 miles away...and something about doing Watkins glen without fourth gear would be insane..
thanks for the input guys!!!!
CJD
I'm thinking clutch. It sounds like it's dragging at high temp/or speed. Could be mechanical or hydraulic.
John
tomshobby
I did have problems downshifting into 3rd once. It was right after I built my engine. Turned out I did not tighten one of the clutch slave mount bolts. It allowed the plate to flex and when the engine was warm the downshift problem would show up.
8 Lost 3rd & 4th Gear ?? Triumph 18
jvandyke I've lost 4th gear! Spridgets 36
T BJ7 -lost reverse, then 3rd/4th - advice please! Austin Healey 10
D TR6 lost body shell Triumph 1
pbraun Moke America lost trademark name "MOKE" Other British Cars 0
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
G TR2/3/3A Finding a long lost TR3 Triumph 4
Got_All_4 TR5/TR250 Lost Turn Signals Triumph 2
B Lost Title Woes Restoration & Tools 9
B Lost & Found FORUM Navigation Questions 3
Rut I’ve lost my mind, or what’s left of it! Spridgets 12
D Long Lost Midget Spridgets 0
E Long lost Sprite Spridgets 10
Northcoaster TR4/4A Lost info on person interested in my valve cover Triumph 1
steveg Steve Kingsbury has lost everything. Austin Healey 11
mgedit TR2/3/3A Lost Spark Triumph 26
RAC68 Lost 8 terminal Flasher Relay Plan Austin Healey 39
Basil Lost a member - Blueghost Spridgets 9
P TR6 Lost posts Triumph 3
F Looking for Long Lost BJ-7 Austin Healey 2
DrEntropy We've apparently lost another one Racing 1
J Stator tube lost in steering box Austin Healey 11
YYCDave TR2/3/3A Lost Triumph Found Triumph 5
L TR2/3/3A Tr3a lost power go uphill Triumph 21
Boink Great day for a drive... even if briefly lost. Spridgets 0
Lukens TR2/3/3A Lost a hinge pin on my TR3 Triumph 3
T lost in the forms FORUM Navigation Questions 2
aeronca65t Lost a great friend of vintage racing. Racing 1
DNK I have compleately lost it... Triumph 73
wangdango Lost BN2? Austin Healey 1
Jer Spridget's are like a lost Puppy... Spridgets 17
W Lost part, look for help and or options Triumph 9
S Wedge Lost stray, TR7 to 8 parts Triumph 11
J I've lost Reverse! MG 13
78Z Lost luxury - Austin P Spotted 3
G 1500 Dual Carbs in, rims lost in space... Spridgets 12
R lost 1st and 2nd! Spridgets 10
tahoe healey lost boys Austin Healey 10
bthompson I've lost second gear!! Spridgets 95
G Lost spark [ Best ignition coil for a stock '79] Spridgets 18
Stewart I think I've lost it MG 15
DNK Have We Lost a Member Triumph 30
G Lost part Triumph 10
TonyPanchot lost oil pressure help please Triumph 23
SCguy TR4/4A lost link... TR4 rear shock rebuild Triumph 4
T Have I lost my mind??????? MG 9
M Lost out on Bugeye Spridgets 37
rick_ingram Enthusiast lost MG 1
6 Looking for a lost part. Spridgets 5
Sopwith_Camel lost in transmition Spridgets 4
