starting rebuilt 1300 for 1st time
rikiwho123
well the title says it all; how long should i let the motor run and at what RPM so i can seat the rings ; the car dosen't have plates so i can't take it out on the road yet; the motor is all new ; block 30 over the head is a stage one with hardened seats ; 4 carbs and 4 tube headers stainless steel ; PRI did the head 10-1 comp. ; a lightened flywheel high tourque starter ; roller rockers etc. This is a toy for me i'm retired and have a need for some fun anyway what RPM & HOW LONG Thanks rick.
DNK
If you have the cam man. ,check their recommendations.
Usually 20 minutes or so at about 1600-2000. Turn off and drain oil and refresh. Then your good to go.
Don't forget to use the correct oil and cam break in lube
billspit
Ive heard 2500rpms for 20-30 minutes. Be sure you have the oil circulating before firing it off.
Also as DNK says, defintely add a cam break-in lube to the oil before you fire it.
The rings aren't going to seat for several hundred miles.
Andrew Mace
Regarding rings, one apparently common break-in procedure (once you have plates on the car) is to do about a dozen or so reasonably brisk sprints from about 20-25 mph up to maybe 50 mph in top gear...coast down...and repeat. This is the procedure (as outlined in "How to Keep Your Subaru Alive") my son and I followed earlier this past summer on the engine we built for his '81 Subaru GL, and it seemed to have "worked a treat" as they say. I've done similar "runs" in the past with other engines I've redone, both Triumph and Volvo, and it seems to have worked each time.
myspitfire
:whOh! don't forget the "ZDDP"oil additive AFTER the 2nd oil change & every oil change after.Especially at breakin.
Ken&Whitelightning :driving:
rikiwho123
rikiwho123
well thanks to all used assembly lube on the cam and the bearings and filled the motor with brad penn green oil for the break in ;so now i guess it's time recheck everything get the keys and give it a shot. thanks everyone rick.
DNK
If you use Brad Penn oil you should be set. Run their racing oil for your everyday and you will be golden
D Starting After Carbs Rebuilt Austin Healey 30
J Starting rebuilt engine ! Austin Healey 8
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
S TR2/3/3A TR3 Hard Starting Triumph 4
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G TR4/4A Starting without Transmission attached Triumph 9
P BN4 Hesitates on Starting Austin Healey 12
D Hard Starting Austin Healey 14
mgedit TR2/3/3A 56 TR3 Starting Issue Triumph 9
M Starting from cold Austin Healey 2
R Very Difficult cold weather starting problems! Austin Healey 21
R TR4/4A Starting TR4A after 30 years Triumph 12
R winter hard starting BJ7 Austin Healey 16
P Jump starting a positive ground BJ8 Austin Healey 4
W starting motor Jaguar 0
D TR2/3/3A Starting my Bodywork journey. Triumph 166
P TR6 Quick starting Triumph 2
Joe Reed General Tech Starting a screw in a tight location... MG 9
P TR6 TR6 hard starting Triumph 24
Q Just Starting Restoration Of 1967 E Type Jaguar OTS Jaguar 13
stretchit2 Starting Issue Austin Healey 6
M TR6 Intermittant starting problems Triumph 4
Willie_P TR4/4A Starting long dormant TR engine..start up procedures? Triumph 10
S Hard starting on Webers from cold Austin Healey 12
