Starting rebuilt engine !
John_Progess
I am helping a friend attempting to start a newly rebuilt engine. I have removed the plugs and turning the engine with the gear reduction starter trying to establish oil flow/detection. I have cranked the engine approximately 7 times for about 10 seconds each try and I have no oil coming out the flex line to the oil pressure gauge. I'm starting to get a little worried. The oil level has gone down from full line to half way between full and add lines. I think this is the result of filling the oil filter so I think I might have some flow. Should I continue turning the engine over? Am I being a little too cautious? Is there a better way of turning the oil pump? Thanks for your help and have a good day!
John
Jerry
It takes a long time to get the pressure up. If it has filled the oil filter, you are close. The Healey list said at the factory, they started the engines, this pumps them up right away. We are a little cautious. If you used lots of assembly lube, that will protect the bearings.
Jerry
Superwrench
Like Andrea says, Try a few more times. Look in the oil fill and see if oil is coming out at the rocker oil holes ? If oil there than fire it. Good luck !
vette
When I was a teenager, an extremely long time ago, My friends and I built quite a few MG engines and some chevy engines under the the tutelege of my friends father who was an aviation mechanic. Maybe we didn't have extreme high lift cams back then nor special oils, etc. But we set the specs and got fuel into the carbs and fired them up right away then held the rpms to somewhere between 1500 to 2000 for 4 or 5 minutes and that was it. I don't remember ever having a faulty engine or one that failed soon afterwards. Today most engine builders will tell you to put it at 2000 rpms and hold it there for a few minutes. It you don't have oil at the gauge in about 5 to 10 seconds then I would shut it down.
roscoe
Maybe it is from the aircraft engines I've done but I have always pre-heated the oil in a pot and then poured it into the engine when I was ready to run it. Doesn't have to be operating temperature hot, but every little bit makes pumping initially easier. The thinner viscosity has always seemed to work for me and I never liked the idea of packing the oil pump with grease which is what some folks suggest.
To adlib on Roscoe, I don't like the idea of filling the oil pump with (white-lithium, Vaseline, or name your poison) grease either. Just the same customary film that you put on every other assembled part is sufficient. The thin smear of grease will provide enough of a seal so that the pump can produce a vacuum and start filling it up with oil right away (and then you don't have to worry about pumping ALL THAT sludge throughout the system__imagine how long it would take to pass a wad of grease through the pinhole in the timing chain tensioner, or for that matter, the tiny orifice that supplies the pressure gauge...?
Never thought of preheating the oil before, but if you can get it into the crankcase, I can't see it hurting anything (in Florida, room temperature oil will be just fine, thank you).
bob hughes
I used a cheap but decent 20/50 to run the engine in, I do recall that I had to crank it for a while with plugs out to get the initial pressure up, that was 2000 miles ago and I have had no problems, I did use plenty of the graphite grease during the build.
:cheers:
Bob
Patrick67BJ8
John
I used Joe Gibbs "break-in" oil and it was about $7 a quart. We primed my engine before cranking! I'm on a new computer and my files haven't been transferred to it yet but I had a photo of my "primer" that I posted on the BCF that you should be able to look up. Not hard to make and it used a small amount of air pressure from my compressor to force the oil into the engine at the filter connection. We primed it until oil was coming out of the rocker shaft and running down the push rod tubes.
D Starting After Carbs Rebuilt Austin Healey 30
rikiwho123 starting rebuilt 1300 for 1st time Triumph 7
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
S TR2/3/3A TR3 Hard Starting Triumph 4
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G TR4/4A Starting without Transmission attached Triumph 9
P BN4 Hesitates on Starting Austin Healey 12
D Hard Starting Austin Healey 14
mgedit TR2/3/3A 56 TR3 Starting Issue Triumph 9
M Starting from cold Austin Healey 2
R Very Difficult cold weather starting problems! Austin Healey 21
R TR4/4A Starting TR4A after 30 years Triumph 12
R winter hard starting BJ7 Austin Healey 16
P Jump starting a positive ground BJ8 Austin Healey 4
W starting motor Jaguar 0
D TR2/3/3A Starting my Bodywork journey. Triumph 166
P TR6 Quick starting Triumph 2
Joe Reed General Tech Starting a screw in a tight location... MG 9
P TR6 TR6 hard starting Triumph 24
Q Just Starting Restoration Of 1967 E Type Jaguar OTS Jaguar 13
stretchit2 Starting Issue Austin Healey 6
M TR6 Intermittant starting problems Triumph 4
Willie_P TR4/4A Starting long dormant TR engine..start up procedures? Triumph 10
S Hard starting on Webers from cold Austin Healey 12
