First Gear Sliding Hub Endplay
AUSMHLY
Would someone please address this question about 1st gear sliding hub endplay? Mine does the same thing.
If there is too much endplay, what problem would it create?
My guess: If the endplay is gone when in 1st, then it's not an issue (it looks to be designed-in, not a manufacturing defect). You could send the link to Magnus Karlsson and ask him, though; he's done some excellent gearbox and OD assembly videos. You could tell him I suggested him, he does know who I am:
magnus@healeyspecialists.com
The side play on the first motion shaft, I think, is normal (that's why you have pilot bushings).
D first gear sliding hub play Austin Healey 10
L T-Series Gear box servicing cap. MG 5
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Todd78d Sprit MK1 gear box filler Spridgets 2
B Transmission Gear Lockouts Austin Healey 8
S Gear Shift Lever Travel Austin Healey 13
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
S For Sale Differentail gear sets available. Spridget, Morris Spridgets Classified 12
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
C Spitfire gear selection Triumph 10
JPSmit Gear reduction starters anyone? Restoration & Tools 5
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
AUSMHLY Remanufactured Laygear with welded 1st gear Austin Healey 20
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
DocDup1 TR4/4A Second Gear Bushing Triumph 6
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
S TR2/3/3A Gear shift knob Triumph 8
AUSMHLY BJ8 Second Gear Needed Austin Healey 16
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
AUSMHLY BJ8 Gear Shifting Austin Healey 5
R Bugeye reverse gear Spridgets 6
TomMull TR2/3/3A 1st gear again Triumph 3
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
KVH General Tech Gear Shift Sticks Triumph 6
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
D Socket for TR3 Gear box drain plug Restoration & Tools 6
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
Jim_Stevens TR2/3/3A Ring gear shot? Triumph 26
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
Joe Reed MGB Dropping out of 3rd gear... MG 2
J Planetary Gear Removal Austin Healey 3
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
R TR6 Gearbox slips out of 3rd gear Triumph 14
