TR2/3/3A TR3A Dash and Instrument Cluster Installation
Tinkerman
Afternoon, I'm fast approaching the point that I'll be ready to install the dash and the instrument cluster. The wiring harness is wired to the instrument cluster. My question is: do I install the instrument cluster into the dash and then mount the two units in the dash position? Or do I mount the dash get secured and THEN mount the instrument cluster?
I'm asking this based on my history of putting the cart before the horse in a number of sub-assemblies on this project and I really HATE do-overs.
Any thoughts would be greatly appreciated!
Thanks, Tinkerman
While I've not tried it the other way, I think it will be easier if you mount the dash first, and then deal with the instrument panel.
In fact, I probably would have mounted the dash before wiring the panel, but hopefully the panel will fit through the hole
Dick, I have to agree that mounting the fascia (dash) first is IMO the better approach. I covered all of the vynide with easy release painter's tape to avoid damage. We left all of the securing hardware, fasteners, etc fairly loose so we could remove the fascia quickly if necessary.
Cheers,
Frank
I just did mine a few weeks ago. I put the dash in first. I had wired the cluster piece before I tried to put it into the dash. I had numbered the harness wires when I disconnected them. I put a corresponding number on a short piece of wire attached to the gauge or connection on the cluster. Anyway I used some masking tape to loosely attach the cluster to the dash. I then wired it all up without too many issues. I will suggest that the two connections with several wires going into the same connector will be better connected by using a wire nut and a short piece of wire. Putting only a single wire into the connector on the instrument cluster.
Dick
Put the Dash in first,then instrument cluster but what about the heater? If its not in already,put the heater before the dash.
Marv
Marvin, the heater is in. Gordon, I find two grommet holes in the center of the upper edge of the scuttle panel. One directly behind the other. Are these the grommet holes you are talking about? I would have no trouble getting to either one of them at this point. I can see it would be almost impossible once the dash and cluster are installed. I really appreciate you pointing that out to me, because I would have missed it.
Thanks, Dick
Yes Dick, those are the holes the wire for the vent pull go thru. You have already guessed how I know.....I missed it the first time!
Gordon
The value of the forum are folks like you Gordon! Thanks very much, Dick
Hi Dick make sure you put in the defroster vents when you do the dash. I found that cleaning the threads on the studs that hold the dash make it easier also.
Steve
Thanks Steve, good point.
K TR2/3/3A TR3A Dash support brackets? Triumph 3
NutmegCT TR2/3/3A TR3A dash rail Triumph 17
Tugboat TR2/3/3A Pictures Under TR3A Dash Triumph 20
Tinkerman TR2/3/3A TR3A Dash Capping Triumph 25
V TR2/3/3A TR3a Dash Wiring Triumph 6
Tinkerman TR2/3/3A TR3A Dash Clamp Attaching Point Triumph 10
Tinkerman TR2/3/3A TR3A Covering the Dash Cap Triumph 3
jdubois TR2/3/3A TR3A directional indicator dash light Triumph 4
Tinkerman TR2/3/3A TR3A Vinyl Dash Covering? Triumph 8
ekamm TR2/3/3A under dash acess tr3a Triumph 11
apbos TR2/3/3A TR3a Center Dash Triumph 38
NutmegCT TR2/3/3A dash rail TR3A grab handle Triumph 14
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 16
C TR2/3/3A TR3A Electrical problem Triumph 18
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
