After bead blasting the body I noticed some interesting things…
BillyBud
I have seen some posts where authors rail against brazing done by earlier owners. I have a NOS rear clip on my bugeye that I purchased from a dealer many years ago in the early 70’s. It had the correct part number metal tag on a wire and was not an aftermarket reproduction, it’s genuine. It came with a gray paint coating, like a semi gloss (not flat) primer, and I installed it myself.
I recently had the body plastic bead blasted and it exposed some places where the factory had used brazing at the ends of the fender beads. I know most of the car was spot welded together but it appears that this was not practical for some locations so they were brazed. I guess my point here is don’t assume all brazing you find was done by a previous owner, it may be factory.
I also noticed that there were dimpled areas on the rear top of the bonnet which the factory prepped for rear view mirror installation by indenting where the screws would go. These are on both sides of the bonnet. My car has two rear view mirrors mounted through holes in the front fenders above each wheel well., so these were never used. My mirrors were not Lucas style but more like motorcycle threaded post mirrors. They are pretty useless for rear view but they look cool and are a little different so I’ll keep them. I assume maybe the selling dealer installed these mirrors, but not sure.
Bayless
You might be surprised just how strong brazing can be when done right. All right, it is not always the best opton when welding is possible, or practical. It does have its place, however. The main problem is not strength but having a doubled panel to work where necessary. Also, it is imperative that the flux residue be thoroughly removed. Otherwise, any topcoating will eventually fail.
D TR2/3/3A rear fender bead Triumph 2
DornTRoriginal TR2/3/3A Fender Bead Installation Triumph 10
TomMull Bead Roller Restoration & Tools 0
Rob Glasgow Help with fender bead Austin Healey 26
B Painting the Car - Corner Bead Advice Austin Healey 21
Tinkerman TR2/3/3A 1960 TR 3A Fender bead question Triumph 15
T TR2/3/3A front fender bead screws? Triumph 12
A Fender bead photo rear fender Triumph 12
Morris Windshield bead Spridgets 7
T Wheel rim corrosion at tire bead contact Austin Healey 1
aeronca65t bead breaker Restoration & Tools 5
mountainman TR2/3/3A TR3 Bead Moldings Triumph 1
mountainman TR2/3/3A TR3 Front Fender Bead Triumph 2
mountainman TR2/3/3A TR3 Rear Wing Bead Triumph 17
B Fender Bead Car Set Austin Healey 10
G fender bead Triumph 15
R Installing fender bead-BJ7 Austin Healey 4
AngliaGT Bead Blast Aluminium? Restoration & Tools 3
R Fender Bead removal question MG 22
P Chrome Fender Bead Triumph 8
PAUL161 Top fender bead replacement. MG 7
red57 Metal prep of chassis after repairs and shot blasting Austin Healey 5
JimLaney Media blasting engine parts - How to clean? Spridgets 5
D My Sand blasting setup Restoration & Tools 5
kennypinkerton Tractor Supply Blasting cabinet. Restoration & Tools 6
R Media blasting a Bugeye body Spridgets 8
R Media Blasting a Bugeye Body Austin Healey 7
J Upgrade to blasting cabinet Restoration & Tools 7
B Sand blasting trunk deck BAD,________? GOOD? Triumph 11
wangdango Soda blasting body panels? Austin Healey 12
jackq Soda blasting Restoration & Tools 3
R Sand blasting Spridgets 16
A question about media blasting and engine paint. Austin Healey 14
G Which blasting media to polish? Spridgets 1
T Air compressor min CFM for media blasting Triumph 14
kurts100 Dipping vs. Blasting a Bugeye Spridgets 12
I TR6 TR6 wheel blasting/painting Triumph 6
E Body Blasting and Mechanical Work Triumph 9
rlandrum Media Blasting - What to use Triumph 16
J special equipment for soda blasting? Triumph 15
LarryKerr Blasting and Welding needed in Greater Atlanta MG 4
S Media blasting Spridgets 14
beaulieu Need bulk soda [50-100lb bag] for soda blasting ? Restoration & Tools 6
73Midget Blasting Cabinet Restoration & Tools 8
timbn2 Definitive Answer on Media Blasting, Please... Austin Healey 10
B Media Blasting Austin Healey 5
W compressor revisited - painting &blasting. Restoration & Tools 9
Cain Blasting Media Triumph 2
1 Media blasting experience? Spridgets 11
John Loftus media blasting report Austin Healey 10
