Wheel rim corrosion at tire bead contact
twas_brillig
Just took an alloy rim in with a completely separated sidewall from our son's car (looks like he picked up a nail right in the middle of the tread; the nail came out leading to reasonably rapid air loss and overheating of the sidewall, which failed. Lots of black dust inside the tire. He and the car got off the highway and got it changed with no damage) and the tire changer recommended an acid based aluminum primer as a first coat after he cleaned the corrosion off the rim where the bead contacts it, followed by a couple of light sprays of clear - Krylon industrial, I believe.
Corrosion along this area is a problem with alloys, leading to slow air leaks. Anyone got suggestions as to how minimize the corrosion on wheels being used on vehicles (steel and alloy) as well as those that are stacked flat and could get water pooling around the contact area? Also, what are suggestions for preventing corrosion on wire wheels - spokes etc.
Thanks,
Doug
Keoke
DOUGH!:
1] Use only a one step acid based wire wheel cleaner
and an appropriate brush.
2] Rinse wheel thoroughly after cleaning.
3] Only purchase wheels that have SS Spokes.
4] Seal the spoke nipples inside the rim
with a high quality clear RTV.
5] OH!!! Perform steps 1 thrugh 2 regularly.
--------------FWIW-Keoke-- :laugh:
Joe Reed General MG Early Midget horn push on Personal wood rim steering wheel... MG 3
JPSmit Wheel/ Rim Question Spridgets 7
T TR6 Steering Wheel Lock Triumph 2
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
D Removing the steering wheel hub Spridgets 12
Todd78d Wire wheel cleaner Spridgets 1
zoohow wheel spacers Racing 1
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
K 1068 mkIII wire wheel rub Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
K TR6 TR 6 Wheel Studs Triumph 10
AUSMHLY Front Wheel Spin Drag Austin Healey 6
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
Editor_Reid Wrapped Steering Wheel Austin Healey 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
EWD For Sale ā€˜74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ā€˜74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
kodpkd Leather Steering Wheel Cover Austin Healey 3
KVH General Tech Wheel Dollies Triumph 5
S Steering Wheel Brand Austin Healey 5
B TR4/4A What is this Steering Wheel Center? Triumph 6
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
P 100/6 Front Wheel Alignment Austin Healey 10
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering wheel removal. Triumph 4
prb51 BN6 Wheel/Tire Combo Austin Healey 26
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
LAW75 Derrington Steering Wheel Austin Healey 19
C Spitfire rear wheel bearing Triumph 2
W TR2/3/3A Wire Wheel Conversion Triumph 5
waltesefalcon New steering wheel Other Cars 2
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
R Wire Wheel Fit Austin Healey 10
Donald1107 TR2/3/3A Wheel bearings Triumph 8
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S BN1 Wheel-Tyre Combination Austin Healey 10
DocDup1 MGA Wire Wheel Hubs For MGA MG 6
M General MG Wire Wheel Specialist Needed in Los Angeles area MG 0
