Burning Smell from Left Rear Wheel
bighealeysource
Bronze
Well, been trouble shooting minor brake problems, but now have a distinct burning oil smell and high heat coming from left rear wheel. I just got back from a drive - gorgeous down here in coastal SC - and very distinct burning smell and high heat coming off that left rear wheel/hub.
I am thinking it's a possible very minor rear end oil leak that I noticed when I had the drum off, combined with having difficulty getting that brake adjusted correctly. Almost no adjustment possible as adjuster locked all the way down or out, and I am getting friction from the lining combined with that minute leak. Didn't bother fixing that when I had it apart, but looks like I should have.
Any thoughts ?
Thanks,
Mike
mezy
I doubt you would get heat from an oil leak, more chance of brake binding, does it smell a bit like cow poo.
MikeAH100M
I had the same issue and it ended up being a stuck piston on one of the cylinders that caused the brake to bind. I replaced (twice since the first Moss replacement leaked and had to return) and the problem went away. Also helped to adjust the master cylinder slightly to give some more room/play to adjust.
bighealeysource
bighealeysource
Bronze
Hey guys,
Just got the drum off with a bit of persuasion from a hammer. Not an oil leak, just binding exactly like Mike above says ! I've smelled cow poo
before, but can;t recall that smell. Just smelled like something burning which I now believe was the brake linings against the drum. Think this
goes back to the issue of fitment but will definitely check out that wheel cylinder. I'll be back !
Thanks,
Mike
bighealeysource
bighealeysource
Bronze
I was thinking about this left rear brake issue and the locked wheel cylinder really makes sense. Going to take out the old one and
install a new one from Moss and see what happens ! Hoping it is this easy.
mezy
I would check it out first to see exactly what is seized/malfunctioning. It could be anything from handbrake cable/lever, adjuster malfunction, or cylinder. Compare all components from the good side to the bad side.
Make sure that the brake shoes are fitted the correct way as they will have a leading and trailing side. Again, check against the good side,
take pictures and compare.
bighealeysource
bighealeysource
Bronze
AN UPDATE - turns out the wheel cylinder was completely frozen and the small piston would not move. Finally broke it lose but not moving in and out and barely could turn it around in the cylinder. A replacement part from Moss and not that old. I have had a poor experience with Moss
replacement brake parts, this less than 3 year old wheel cylinder and brake shoes with lining falling off.
I did pull the rear hub to replace the oil seal and install a new paper gasket so hopefully fixed the minor oil leak from the axle shaft.
I installed a new rear wheel cylinder ( same Moss part as bad one but that's what I had on hand ) so hoping this one lasts longer. I could fill a dictionary with swear words getting that bloody thing off due to the infamous clips that attach it. Now put everything back together
and see if my left rear brake issue is resolved. Of course get to bleed the brakes but fortunately bought a power bleeder a few years back.
All put back together and can now actually adjust that brake properly and the drum goes on easily !
Question - the brake cylinder is supposed to move slightly as part of the design function, is that correct ? How lose should it be once
installed with the clips that are attached from the back side ?
BobHaskell
Shouldn't be loose, but should move as you put on/release the parking brake.
bighealeysource
bighealeysource
Bronze
Thanks Bob, wanted to make sure I was understanding the manual right !
bighealeysource
bighealeysource
Bronze
Hey y’all,
great video and all makes sense. I did not apply a small amount of grease to the opening the wheel cylinder slides in but will now !
Thanks
Mike
bighealeysource
bighealeysource
Bronze
Well,the old gal is back together, brakes bled, and everything working well. I'll bleed them again to get it as perfect as I can but just wanted to get things cleaned up and put away. Use a power bleeder so pretty easy job to do again. Even adjusted the parking brake a bit while I was at it.
Entire problem going back to an even earlier post about brake problems was that bloody frozen wheel cylinder. Thanks to all who offered their advice and even a video ( thanks Bob ). I haven't been as active on the forum as in the past but still best thing going out there.
The rear brakes allegedly have 'servo effect;' i.e. when the forward shoe engages the drum it pushes the rearward shoe, amplifying it's ability to grab. Since the cylinder moves back-and-forth it's conceivable the hard line to the cylinder could get work-hardened and eventually fracture; though I've never heard of this happening (would probably take a million miles). Still, in theory, there should be a flex line to the cylinders.
Sopwith_Camel General MG Spring and the smell of burning eclectics are in the air MG 4
2 TR2/3/3A Something's burning Triumph 13
HighAltitudeTR3 TR2/3/3A Just started burning some oil... Triumph 8
KVH TR4/4A I Can't Stop Burning Oil; Engine Missing at Take Off Triumph 5
Keith_M 1275 burning coolant Spridgets 20
C TR4/4A Burning through points Triumph 4
J New engines burning oil, Too much fuel? Triumph 14
aeronca65t Midget-flipping and burning in slow-mo Spridgets 11
J Burning Dynamo Austin Healey 2
athenssprite Smoke - oil burning Spridgets 5
athenssprite heavy smoke on start up - burning oil Spridgets 13
D Oil burning at cold start Austin Healey 17
longbridgehealey somethings burning? Spridgets 10
S Got 800K burning a hole in your pocket?? Jaguar 9
P Starting problem .. and a burning problem?? Austin Healey 11
gubba Burning Wires...Yikes...Help Please Triumph 5
2wrench TR6 TR6 Burning/losing oil, what do you think? Triumph 7
D Burning Oil Triumph 7
D New rebuilt engine-burning oil after 700 miles?? Triumph 5
Webb Still Burning Oil? What Type of Oil to Use? Triumph 20
G Burning Fuses & my patience..running out of both Triumph 25
Hegg Elan +2 is burning oil [come on in and laugh!] Lotus 8
Patton Burning up rotors - plus tech tip to get home!!! Austin Healey 16
D MGA Oil Burning MGAs MG 2
edkap2002 TR6 gas smell Triumph 8
NutmegCT Ozone generator - cigarette smoke smell in car? Restoration & Tools 11
M MGB 1978 mg fuel smell MG 23
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
warwick-steve Where did the smell go? Austin Healey 11
N Spitfire Persistant gasoline smell Triumph 9
DanLewis Side draft Weber and smell of gasoline? Spridgets 3
S Gasoline Smell Spridgets 22
K GT6 Exhaust smell when car in motion? Triumph 5
PKPoole TR2/3/3A Gas Smell Triumph 13
P Fixed gas smell Triumph 0
P gasoline smell Triumph 5
7 running lean and "gassy" exhaust smell? Triumph 4
Anthony_S TR2/3/3A TR3 plugs and random smell.... Triumph 1
Morris What's that gas smell? Spridgets 6
J TR2/3/3A Help!! Gas smell from Tr3! Triumph 21
R I Can Almost Smell the Paint Spridgets 8
Jim_Gruber Smell of gas, turns out not floats set too high Spridgets 4
M Gas smell Triumph 11
judow Strong gas smell? Jaguar 4
mailbox Musty carpet smell remover Restoration & Tools 3
R gas fume smell after engine turned off Spridgets 13
S Fuel Leak / Smell Triumph 7
sparkydave Ahh... New car smell Other Cars 6
J Of Seats, Carpet and Old Car Smell MG 20
R Smell of Gasoline Austin Healey 3
