Smell of Gasoline
Recent chat visitors
Rick G
Member
I recently detected the strong smell of Gasoline every time I drive the Healey (60 BT7). After noticing some drops in the driveway I discovered a leak in the line going into the front carb. I ordered new washers and repaired the leak. My problem now is that after several weeks and serveral hundred miles of driving, I still smell the strong oder of Gasoline and it does not stop. I have checked many times but it is not leaking from any place I can see and there is nothing on the ground after leaving it run for 15 to 20 minutes in a stationary position. Any thoughts anyone?
Rick,
Open up the boot and see if the smell is strong in there. If so, I would start looking for a rust through hole in the gas tank, especially if your car still has the original tank.
Ed
Yes that is a good point Rick. However, a more connon problem producing a fuel smell inside the car is the failure of the fuel sender's seal in the top of the fuel tank. In any event do not fail to check in the Car's boot.---Keoke
Probably pinholes in the fuel tank and no seal in the sender unit. Replace the tank if you have pinholes it will out last you. Do not over tighten the sender unit seal lest it "squeeze" out and not seal again.
N Spitfire Persistant gasoline smell Triumph 9
DanLewis Side draft Weber and smell of gasoline? Spridgets 3
S Gasoline Smell Spridgets 22
P gasoline smell Triumph 5
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
edkap2002 TR6 gas smell Triumph 8
NutmegCT Ozone generator - cigarette smoke smell in car? Restoration & Tools 11
M MGB 1978 mg fuel smell MG 23
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
warwick-steve Where did the smell go? Austin Healey 11
Sopwith_Camel General MG Spring and the smell of burning eclectics are in the air MG 4
K GT6 Exhaust smell when car in motion? Triumph 5
PKPoole TR2/3/3A Gas Smell Triumph 13
P Fixed gas smell Triumph 0
7 running lean and "gassy" exhaust smell? Triumph 4
Anthony_S TR2/3/3A TR3 plugs and random smell.... Triumph 1
Morris What's that gas smell? Spridgets 6
J TR2/3/3A Help!! Gas smell from Tr3! Triumph 21
R I Can Almost Smell the Paint Spridgets 8
Jim_Gruber Smell of gas, turns out not floats set too high Spridgets 4
M Gas smell Triumph 11
judow Strong gas smell? Jaguar 4
mailbox Musty carpet smell remover Restoration & Tools 3
R gas fume smell after engine turned off Spridgets 13
S Fuel Leak / Smell Triumph 7
sparkydave Ahh... New car smell Other Cars 6
J Of Seats, Carpet and Old Car Smell MG 20
I Gas smell in trunk Triumph 7
C Why is it I always smell like oil! Triumph 10
RickB Gassy smell in cockpit - Solved! Thought I'd share Spridgets 4
RSMTR8 Wedge TR8 Smell......... Triumph 10
C Raw gas smell. Triumph 3
D 1991 xjs v12 ,smell of fuel. Jaguar 4
S Strong Gas Smell Triumph 20
beaulieu cleaning an old gastank , rust and old gas smell Restoration & Tools 2
Kurtis Smell? Triumph 16
bluemiata90 How to remove dead animal smell from interior MG 4
Todd78d Gasoline Spridgets 18
D General Tech Old gasoline disposal Triumph 17
Editor_Reid "Fuel Diamond" Gasoline Treatment Austin Healey 19
J MGB 1974 1/2 MGB gasoline type MG 5
TomMull TR2/3/3A Gasoline fumes and winter storage Triumph 11
NutmegCT Gasoline resistant sealing tape? Restoration & Tools 3
3798j General Tech Top Tier Gasoline Triumph 4
vette Any Suggestions As to Where to Buy a New BJ7 Gasoline Tank? Austin Healey 24
S Austin Healey LEAD replacement in gasoline Austin Healey 4
Merlin63Tr4 TR4/4A Gasoline in vacuum advance unit. Triumph 10
L Wedge TR7 gasoline odour Triumph 5
fpstude TR4/4A Air Filter Soaked With Gasoline - TR4A Triumph 9
H TR4/4A TR4 Gasoline Sending Unit Triumph 5
