gasoline smell
pdplot
New problem. Strong odor of gasoline in garage where TR6 is parked. No dripping or leaks visible. Tank was recently filled but filler cap seems tight. Can't seem to trace smell. Any ideas?
PD
Check all of your fuel line connections, especially filter, fuel pump and carbs and tank.
Some TR-6 models had a charcoal canister and the fuel system was sealed, e.g. no venting. Could be this system needs service.
It is not uncommon for small pin hole leaks to develop in the gas tank, especially where it sits on top of the ledge in front of the boot. These leaks start with rust due to trapped moisture. You can easily inspect the possibility of a leak by removing the mill board cover behind the tank (inside the boot).
There is a small length of rubber hose which connects the fuel cap outlet to the tank. Make sure that the rubber has not deteriorated and started to leak.
I'm sure others will have additional suggestions.
Check the bottom of the carbs for dampness.
Also, smell the oil on your dipstick for gas.
If ok there, open the boot and see if it smells bad near the bottom of the gas tank.
On the TR4a it started to smell after fill ups. The seal for the fuel gauge sender wasn't doing its job - allowing gasoline to exit the tank and run down the side. Pretty strong odor when first entering into the garage even though the amount leaving the tank was really small.
Checked the car carefully. No leaks noted. I'll run the car to burn off some fuel and see if the situation improves.
PD
We're relatively new owners of a 72 TR6. 1st thing we after getting it did was fill it up. The next morning the odor in the garage was terrible. I traced it to the tank, a tell-tale moist trail helped but only after I spent an hour or so under the car and in the engine bay looking for a leak. The 'trail' wasn't easy to see. Only with plenty of light and looking from different angles did I spot it. For now we don't fill the tank more than 3/4 full and that has solved the stinking garage issue. When 'top down' season ends I'll pull the tank and give a shot at etching/sealing.
N Spitfire Persistant gasoline smell Triumph 9
DanLewis Side draft Weber and smell of gasoline? Spridgets 3
S Gasoline Smell Spridgets 22
R Smell of Gasoline Austin Healey 3
Todd78d Gasoline Spridgets 18
D General Tech Old gasoline disposal Triumph 17
Editor_Reid "Fuel Diamond" Gasoline Treatment Austin Healey 19
J MGB 1974 1/2 MGB gasoline type MG 5
TomMull TR2/3/3A Gasoline fumes and winter storage Triumph 11
NutmegCT Gasoline resistant sealing tape? Restoration & Tools 3
3798j General Tech Top Tier Gasoline Triumph 4
vette Any Suggestions As to Where to Buy a New BJ7 Gasoline Tank? Austin Healey 24
S Austin Healey LEAD replacement in gasoline Austin Healey 4
Merlin63Tr4 TR4/4A Gasoline in vacuum advance unit. Triumph 10
L Wedge TR7 gasoline odour Triumph 5
fpstude TR4/4A Air Filter Soaked With Gasoline - TR4A Triumph 9
H TR4/4A TR4 Gasoline Sending Unit Triumph 5
NutmegCT gasoline siphon? Restoration & Tools 15
tri_carb_healey proper type of gasoline Austin Healey 6
SkinnedKnuckles Summer Gasoline Blends Triumph 5
T Gasoline additives or not? Triumph 15
T Water in gasoline question. Triumph 32
S Gasoline additives Triumph 6
davester Fuel pump removal without gasoline everywhere? MG 35
regularman Just added up my gasoline bill. Spridgets 7
kyreb1862 Gasoline Leak From Tank Sending Unit MG 12
R gasoline recomended for BJ7 Austin Healey 5
G ethanol gasoline Spridgets 2
L Gasoline with 10% ethanol Triumph 18
AUSMHLY Gasoline shelf life Austin Healey 1
jaybird Figure this one out please! Disappearing gasoline MG 37
Whytock Gasoline problems MG 3
G Gasoline additive - 20%more MPG, 70%less emissions Restoration & Tools 0
A Unleaded Gasoline MG 5
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
edkap2002 TR6 gas smell Triumph 8
NutmegCT Ozone generator - cigarette smoke smell in car? Restoration & Tools 11
M MGB 1978 mg fuel smell MG 23
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
warwick-steve Where did the smell go? Austin Healey 11
Sopwith_Camel General MG Spring and the smell of burning eclectics are in the air MG 4
K GT6 Exhaust smell when car in motion? Triumph 5
PKPoole TR2/3/3A Gas Smell Triumph 13
P Fixed gas smell Triumph 0
7 running lean and "gassy" exhaust smell? Triumph 4
Anthony_S TR2/3/3A TR3 plugs and random smell.... Triumph 1
Morris What's that gas smell? Spridgets 6
J TR2/3/3A Help!! Gas smell from Tr3! Triumph 21
R I Can Almost Smell the Paint Spridgets 8
Jim_Gruber Smell of gas, turns out not floats set too high Spridgets 4
