running lean and "gassy" exhaust smell?
Recent chat visitors
70herald
So how normal is this for a pre-emissions control engine (1296 with Stromberg CD150 no emissions stuff at all)
After a drive, my spark plugs are nice and clean, no signs of oil / carbon deposits, (actually a bit orange colored!) If I lean out the engine any more, I have drivability problems.
But the exhaust still smells like I am spraying gasoline...
now to get avoid being super rich I had to adjust the fuel float level about 2mm lower than normal, when I had the height set according to the manual the mixture was very rich no matter how I set the jet. I checked the weight of 3 different floats I have and they were all identical so I don't think that the float has a leak???
Re: running lean and "gassy" exhaust smell?
The plug color is mostly set during cruise. I assume what you are smelling is at idle. Not sure, but you could have a rich idle with a good cruise mixture.
John
Yes obviously I am smelling the gassy smell at idle, I was mostly wondering what other peoples cars smell like at idle since it is really noticeable.
I don't know if this would apply to a CD150 or not, but maybe ... especially since you had to lower the float level to get mixture within range.
On the earlier SU carbs, the jet has to be moved slightly in the housing until it is perfectly centered around the needle. If that centering is not done exactly right, the needle rubs on the side of the jet which, over time, can wear both the jet and needle. The result is that the mixture goes way rich at idle, even after the centering is reset to be correct. I don't think the CD150 requires jet centering, but wear (or damage) to the jet and/or needle might be a possibility.
Another possibility (again for a SU H6, may or may not be applicable to a CD150) is that there is a fuel leak past the outside of the jet. The H6 carbs use a seal that rides on the outside of the jet; if that seal leaks then the idle mixture will go rich (as the extra fuel gets sucked into the engine). Since the leak is fixed, the effect becomes much less at higher rpm.
With the engine warmed up and the choke off, there is no "gassy" smell from my TR3. Very little odor at all, what there is just smells like car exhaust.
Thanks Randall
The CD150 does require the jet being centered basically just put it in place and run the piston up and down a few times before tightening it in place. The piston does go up and down nicely but there still could be a leak around the jet maybe... I guess I could take it apart without taking the carb out.
M TR6 1975 TR6 Backfire from Carbs, running Lean - Help! Triumph 9
SherpaPilot Strombergs Running Lean Triumph 17
R Zenith Stromberg Running Lean - Up-date MG 1
R Zenith Stromberg Running Lean MG 7
N Keeps running lean! Triumph 15
Tim Tucker Running Lean after hard acceleration... Triumph 7
PAUL161 Running slightly lean & no more adjustment? MG 7
Nunyas running wicked lean now... MG 8
A Lean running SU carbs MG 3
W Running lean MG 8
K TR2/3/3A What are the running symptoms........ Triumph 21
T General Tech Running hot Triumph 8
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
shadowfever Running well, then no fire Spridgets 7
C Rough-Running 3000 Austin Healey 29
S MGB Running poorly MG 7
tr6web TR6 TR6 rough running - what can it be? Triumph 17
Hamish Racing TR2/3/3A Winter engine running in - icy Triumph 7
R running car on jack stands Spridgets 16
BierRunner TR6 TR6 Running Rough Triumph 5
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
sparkydave Trouble running hot Spridgets 10
T TR2/3/3A rough running after 20 min shutdown Triumph 9
S TR2/3/3A Running rich SUs. Triumph 25
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Gliderman8 Starter keeps running TVR 20
Rut MGB Running out of gas symptoms MG 21
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
TR3sharon TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
N Running Cold Austin Healey 12
bugedd Car running poorly Spridgets 7
Bob_Spidell Running hot/Overheating Austin Healey 44
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
N Stuck Needle Valve - Rough Running Austin Healey 15
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
BN6 Breaking In Running In a newly built Healey Engine Austin Healey 15
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
M Proper running temp for 1275 Spridgets 28
HighAltitudeTR3 TR2/3/3A Running a little hot... Triumph 14
D Lilly running #3 / since last we talked.... Austin Healey 7
D Lilly second time running... or trying Austin Healey 8
D Lilly first time running in 15 years.... Austin Healey 19
sd80mac7204 TR6 Interesting TR6 running issue Triumph 19
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
F TR2/3/3A SUs Running Rich Triumph 25
S TR2/3/3A Struggling to stay running during warmup? Triumph 0
