New engines burning oil, Too much fuel?
Jerry
We have two rebuilt engines with 200-500 miles on each. They both went through 2 quarts of oil in the breakin miles. Evidence at the plugs indicates that they are running rich. Would rich mixture wash the oil off the cylinder walls and cause it to be burned? There was some during shifting. Any other ideas? One car is TR4, the other is a MGB. Jerry
smaceng
It depends how rich. If, for example, the cars start without using the choke, then that is too rich and could be a problem. Most likely, the rings have not seated, and that is causing the oil burning. I would wait a little longer and see what develops.
waltesefalcon
Burning rich should not be a reason for and engine to burn 2 quarts in 200 - 500 miles. I'd say the rings didn't seat.
trrdster2000
Hope you used a tree hone or something to scuff the walls of the cylinders, very important!
Wayne
Geo Hahn
Also -- what sort of driving did you do during the break-in?
Possibly different schools of thought here but I have always worked new rings by hard acceleration and abrupt backing off.
Tim Tucker
That's how I was told/taught to break-in rings. Vary piston speed alot. No long constant piston speed drives. Also told to not load the engine: uphill, high gear, low rpms. My oil level has gone down <1/8" on the dipstick. I have 960 miles on a fresh rebuild. Hope to do the 1000 mile oil change this weekend...the wix filter, VR1 20-50, and VDDP plus is waiting.
Any chance you're leaking. 2 quarts in short order should be visible in the exhaust. IMO.
Good Luck,
Tim
CJD
Actually, to break in rings you have to load them. The usual method is to use third gear and accelerate under full throttle from about 30 to 60 mph. Then let off the throttle and let the intake vacuum pull the oil back up and cool them as you slow back down to about 30. Repeat a good 10 times.
Too rich normally washes the oil and fuel down, which increases the oil level instead of reducing it.
Did you do anything different, like adding a PCV system?
J
Jerry
No PVC system. But Both Drivers are mild drivers. So I will tell them to push it a little more. Jerry
Keith_M
Are you using break-in oil? I'm not exactly sure what all's different about it except that it contains a lot of zinc, which is necessary for flat-tappet engines. The machine shop that worked on my engine swore by it.
bgbassplyr
You can also use the old tried and true application of 'Bonn-Ami' through the spark plug holes. ISTR about a tea spoon per cylinder. Others may remember this treatment from back in the day.
PAUL161
Jerry, What brand are the rings? Are they chrome rings? chrome rings take longer to break in. Were the cylinders honed with a cross hatch pattern in them, consistent 45 degree angle on the cross hatch? PJ
Bruce100
Before you do all this I would highly recommend you buy an inexpensive vacuum gauge at Northern Tools or Harbor Freight, and verify rings are in fact a problem
J
Jerry
The rings were from MOSS along with new cylinder sleeves and pistons. All new in the box. No I did not hone the cylinders prior to installation. I never have before with new sleeves. So MOSS sells iron rings, I think. Jerry
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
R Extra 948 and 1098 Engines Spridgets 9
S Spitfire Spitfire 1296 engines Triumph 1
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
M TR5/TR250 2500 engines prefix CR Triumph 1
TRMark Alfa 4cyl engines Other Cars 8
T Modern Oils for Our Flat Tappet Engines Austin Healey 26
T Modern Oils for Our Flat Tappet Engines Spridgets 7
T Which Morgan cars have British designed and built engines? Other British Cars 7
JimLaney HELP: Identifying Chasiss and Engines Spridgets 7
D Differences between BT7 and BJ8 engines. Austin Healey 12
alanjohnturner General TR New cranks for 4-pot engines Triumph 0
E 1275 engines and some parts $$ Spridgets 2
aeronca65t Vizard talks about engines Spridgets 19
drambuie Strip cleaning frames engines and bodys Austin Healey 5
JamesWilson Engines dies when hot.... Spridgets 12
Don_Racine 48 Hours ONLY.. ENGINES and MORE Spridgets 0
58Custom People w/ MKIII Midgets & modded A or swap engines Spridgets 6
K TR2/3/3A What was best Spin Oil Filter for TR3 & 4 Engines? Triumph 9
I Top speeds for 948 and 1275 engines Spridgets 16
D Need help IDing A-series engines Spridgets 8
K Paging Andrew Mace: Re Spifire engines Triumph 1
T Mega-Squirt EFI [for A series engines?] Spridgets 6
TR4nut Wet Liner Engines & Valve Interference Triumph 18
G MG and Morris 10 engines, any swapping bits ? MG 5
d_valentino 1500cc Engines Spridgets 0
T TR2/3/3A Other engines into a TR3 Triumph 17
B Engines?? Spridgets 3
MGBGT_noob Opinions on 1950cc engines? MG 9
V Alpine engines Sunbeam (Rootes) 7
S GT6 How common are 2500 GT6 engines in TR6s? Triumph 1
S Tuning 850cc Mini Engines British Motor Corp 4
PAUL161 Factory Built British Cars, With BIG Engines! MG 7
2wrench Intrigued by Petrol Injection engines. Triumph 30
G Buick engines Other Cars 3
Andrew Mace Low-compression TR engines Triumph 2
jlaird Question on engines Spridgets 8
Geo Hahn TR2/3/3A TR3 Engines on eBay -- Scam?... Triumph 14
Bruce_B Break-in of Engines and ROTELLA oil Spridgets 17
SilentUnicorn Triumph Engines Triumph 12
W 948cc orange engines Spridgets 6
bighly New oils may be ruining our engines Austin Healey 15
michalotti_tr GT6 Engines: TR6 vs GT6 Triumph 14
Editor_Reid Remanufactured Rover Engines Triumph 3
Editor_Reid Remanufactured Rover Engines Rover / Land Rover 2
kch Building Healey engines in may issue of Retro Cars Austin Healey 3
I TR6 TR6 engines Triumph 10
aeronca65t Animated Engines Restoration & Tools 26
B Bugeye engines Austin Healey 6
tony barnhill Mini Engines/Transmissions/Heads/Cranks British Motor Corp 7
