GT6 How common are 2500 GT6 engines in TR6s?
skikir
I thought I had a GT6 engine in my TR6 acording to the engine serial number. Of course, I did not think to check when I bought my non running project car since they look the same. Then while repairing a bad piston I discovered the engine had been rebuilt to TR6 specs. Along the way before I realized the the change I had bought a GT6 engine cylinder head which I could not use because of the compression differences. I sold the head to someone who had a GT6 engine in his TR6. After he bought it he too discovered the samething I did. Both our engines are KD series engines. I remember someone else had the same situation also on these boards. I would not think this is a local rebuilder's techniqe since he is in Texas and I am in Oregon. I was wondering how common this is. Or at least if you have a GT6 engine in your TR6 you may want fo investigate it's displacement.
DNK
Interesting,
As long as I don't have an engine with the prefix CT
S Classic Motorsports : 10 Common Spridget Mistakes Spridgets 1
G Common Years for Austin-Healey 3000 frames Austin Healey 5
Trevor Jessie Common Starter failure? Spridgets 11
alanjohnturner Classics on the Common - my local show Spotted 5
AH67 Octane Boosters...what is the common wisdom Austin Healey 7
aeronca65t Common problem-clutch pedal Spridgets 2
H Temp gauge stopped working....any common cause? Austin Healey 9
K Common causes of Differential Seal leak? Triumph 13
dklawson Spitfire Spitfire Rear Wheel Flanges-Common Problem or DPO? Triumph 7
I TR6 TR6 most common source of leaks into cockpit? Triumph 7
J Stalling on downgrade stops...common? Triumph 7
BOBBYR low oil pressure is common at idle Austin Healey 17
T Oil, Ignorance, and Common Sense, and Experience Triumph 13
TR4nut TR4/4A TR4 horn trouble - a common complaint. Triumph 8
M Common engine oil leaks Austin Healey 16
drooartz What do a Bugeye and a bass have in common? Spridgets 2
Scott_Hower Spitfire Common Spitfire weaknesses? Triumph 30
B Spitfire common EFI swaps for 1500 Spits? Triumph 5
G TR2/3/3A TR3 [maybe] - common or not? Triumph 2
Webb Sledge Common Scenario Triumph 7
R Vixen 2500 Seat Buckets TVR 3
R Vixen 2500 Lug Nut Size? TVR 5
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
R Cool Remanufactured Part for Vixen 2500 TVR 7
Zitch For Sale AH 3000 Engine For Sale: $2500 Denver, CO area Austin Healey Classifieds 0
M TR5/TR250 2500 engines prefix CR Triumph 1
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
prb51 Looking at a redone 2500 m TVR 5
L TR2/3/3A TR2000/2500 gearbox on a TR3 ? Triumph 2
2 1972 TVR Vixen 2500 Radiator TVR 6
M 64 Grantura or 74 2500 TVR 9
justin_mercier Post-War Other Need help finding a triumph 2000/2500/2.5pi autobox transmission Triumph 10
Simmo TR5/TR250 2500 Gearbox into TR3A Triumph 2
Simmo TR5/TR250 TR3A to 2500 Gearbox conversion Triumph 1
P TR5/TR250 Car misses over 2500 rpm Triumph 21
T 1972 tvr 2500 TVR 3
MadRiver Washington DC -- Black TVR 2500 M Spotted 0
Grantura_MKI 2500 Vixen for sale TVR 0
S 2500 Kilometres Later Spridgets 6
H 2 Bugeyes Craigslist Orlando $2500 Spridgets 0
eejay56 TR5/TR250 Engine stutters at 2500 Triumph 1
T tvr 2500 headers TVR 0
D TVR 2500-3000 V8 conversion TVR 3
K Why is my B engine idling at 2500? MG 1
B Post-War Other Is a TR6 diff and mounts the same as a 2500 saloon? Triumph 4
B Spitfire Has anyone fit a 2500 wiper motor to a spit mk1? Triumph 3
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
ccw283 GT6 GT6 fender flares Triumph 1
B GT6 trying to ID my New Car. GT6 Triumph 6
