Common Starter failure?
While at MG2014 in French Lick my starter failed. It would spin but not catch the ring gear. I finally found a few minutes today to replace it with a spare off the shelf. The pinion gear on the starter motor had detached from the bendix. Is this a common failure? Or just some oddball thing that could only happen to me? By the way, my wife never complained about having to push start the midget for a whole week.
smaceng
Trevor, you have one great wife........I have never seen this failure, usually the spring breaks on the Bendix.
BTW, you know, you could have pushed, and the wife could have dumped the clutch pedal.....just a thought.
Scott in CA
Trevor Jessie
But then she would probably drive off and leave me! She actually preferred to push because she wasn't comfortable with whole process. Not sure how, but the first time she dumped the the clutch she then immediately killed the car.
AN5Sprite
The only time my wife has driven a Sprite is while I pushed. I have tried many times to get her to drive under normal conditions and she just won't...
nomad
Keep her Trevor! My wife has only had to push a few time's and she won't let me forget it!:highly_amused:
I've had a spring fail but not that. I have a whole shelf of good starter's and a shelf full of BAD generator's
Kurt.
Bayless
The comon failure on starters seems to be people putting grease on the bendix. Pretty soon it catches dirt and fails to engage.
Trevor Jessie
I do not know. I've heard NO oil, but I've also heard people people suggest a few drops of 3n1 oil. I've never removed one that hadn't been covered in oil (from the rear scroll seal I presume). I clean mine with some brake cleaner to rid it of clutch dust and oil. Then I spray it with some electrical contact cleaner/protector. Seems to work fine.
dklawson
I was taught that the proper lube for the Bendix is/was to flush it thoroughly with brake cleaner and after that evaporates, put several puffs of moly powder or powdered graphite on the helix in the Bendix. It provides a dry surface lubricant for a while. I'm sure it works its way out pretty quickly. As above, no oil as it attracts dirt and gets gummy.
As Scott said, the common failure I have seen is the broken spring. Other than that the worst I have seen are severely damaged teeth on the pinion gear.
jlaird
Do they really brake, never had to replace one.
Wife who drove a bugeye for years to the store and raced it on weekends with me in Hawaii absolutely refuses to drive Miss Agatha, not even once has she been behind the wheel. Must be an age thing. And yes she had a very heavy foot and could out run all the guys in class.
dklawson
Yes they (the springs) break but I would not consider it common. When I bought a project car it came with 2 Lucas inertia starters and both had broken Bendix springs. The only other failures I have seen are damaged pinion teeth but I am sure there are other failure modes.
Jer
Only starter issue I had was a broken spring along with a sheared cotter pin in the spring nut which caused the spring nut to back off, it had almost fallen off by the time I pulled the starter (which was still working but noise'y !)
S Classic Motorsports : 10 Common Spridget Mistakes Spridgets 1
G Common Years for Austin-Healey 3000 frames Austin Healey 5
alanjohnturner Classics on the Common - my local show Spotted 5
AH67 Octane Boosters...what is the common wisdom Austin Healey 7
aeronca65t Common problem-clutch pedal Spridgets 2
H Temp gauge stopped working....any common cause? Austin Healey 9
K Common causes of Differential Seal leak? Triumph 13
dklawson Spitfire Spitfire Rear Wheel Flanges-Common Problem or DPO? Triumph 7
I TR6 TR6 most common source of leaks into cockpit? Triumph 7
J Stalling on downgrade stops...common? Triumph 7
BOBBYR low oil pressure is common at idle Austin Healey 17
S GT6 How common are 2500 GT6 engines in TR6s? Triumph 1
T Oil, Ignorance, and Common Sense, and Experience Triumph 13
TR4nut TR4/4A TR4 horn trouble - a common complaint. Triumph 8
M Common engine oil leaks Austin Healey 16
drooartz What do a Bugeye and a bass have in common? Spridgets 2
Scott_Hower Spitfire Common Spitfire weaknesses? Triumph 30
B Spitfire common EFI swaps for 1500 Spits? Triumph 5
G TR2/3/3A TR3 [maybe] - common or not? Triumph 2
Webb Sledge Common Scenario Triumph 7
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
J TR6 72 TR6 starter problem Triumph 10
