Post-War Other Is a TR6 diff and mounts the same as a 2500 saloon?
britishcarfreak
I've read a fair bit about TR6 people fitting a particular nissan LSD to their cars. If the TR6 and 2500 saloon share the same diff then I'll get excited and start looking for one of these rb230 diffs or whatever they're called.
Has anyone got a dimensional diagram from a workshop manual to show the TR6 diff?
piman
Hello Glen,
the internals are the same, with the rear cover being slightly different.
The Dolomite Sprint also shares the same internals and was available, as an option, with an LSD. But they are as rare as hens teeth and very expensive. I am planning to install a Sierra 4x4 LSD diff in my Triumph which will entail fabricating a frame to attach to the Triumph sub frame and making adaptors for the prop shaft and the drive shafts.
Alec
B
britishcarfreak
I'm in the process of having some datsun roller half shafts modified to fit my 2500 and figured that now would be a sensible time to fit a datsun/nissan diff.
There seem to be so many options for diff upgrades I guess I just want to find the easiest one. Trouble is that most of you guys are in the UK or the USA and have access to different parts than us Aussies.
piman
Hello Glen,
I have not seen any details of the Nissan differential so I would be interested to hear how you get on, in due course.
By the way I still run with my standard drive shafts and do not find them to be a problem. I know and have felt the twitch in other cars and wonder if it is partly due to my stiff springs (400 lb) and polyurethane bushes which reduces the amount of travel in the suspension arms?
Alec
B TR6 Help! TR6 Diff Mounts - poly or rubber? Triumph 12
charlie74 TR6 another "?" re TR6 diff mounting Triumph 2
Gliderman8 TR6 TR6 Diff questions Triumph 19
hondo402000 TR6 TR6 dropped the Diff out and half shaft question Triumph 2
Webb TR6 TR6: Pulling the Diff Triumph 7
J TR6 'nother question about the diff on a tr6 Triumph 9
R6MGS TR6 TR6 hazards...again....diff problem thou Triumph 3
B TR6 TR6 Diff Seal Triumph 2
B TR6 TR6 Diff. Drain Plug Question Triumph 5
M TR6 TR6 Diff. Mount Pins Triumph 2
G TR6 TR6 broken diff mount Triumph 3
Alan_Myers TR6 Anyone need a TR6 diff w/Quaife LS installed? Triumph 1
bigbadbluetr6 TR6 TR6 Diff. question Triumph 6
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
