TR5/TR250 2500 engines prefix CR
malbaby
I believe the CR engines were fuel injected.
Apart from the cylinder heads are they the same as the standard 2500's.
glemon
Looking at the Piggot original TR book and my limited knowledge it appears they are the same. The cam is different, but you probably knew that.
S GT6 How common are 2500 GT6 engines in TR6s? Triumph 1
R Vixen 2500 Seat Buckets TVR 3
R Vixen 2500 Lug Nut Size? TVR 5
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
R Cool Remanufactured Part for Vixen 2500 TVR 7
Zitch For Sale AH 3000 Engine For Sale: $2500 Denver, CO area Austin Healey Classifieds 0
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
prb51 Looking at a redone 2500 m TVR 5
L TR2/3/3A TR2000/2500 gearbox on a TR3 ? Triumph 2
2 1972 TVR Vixen 2500 Radiator TVR 6
M 64 Grantura or 74 2500 TVR 9
justin_mercier Post-War Other Need help finding a triumph 2000/2500/2.5pi autobox transmission Triumph 10
Simmo TR5/TR250 2500 Gearbox into TR3A Triumph 2
Simmo TR5/TR250 TR3A to 2500 Gearbox conversion Triumph 1
P TR5/TR250 Car misses over 2500 rpm Triumph 21
T 1972 tvr 2500 TVR 3
MadRiver Washington DC -- Black TVR 2500 M Spotted 0
Grantura_MKI 2500 Vixen for sale TVR 0
S 2500 Kilometres Later Spridgets 6
H 2 Bugeyes Craigslist Orlando $2500 Spridgets 0
eejay56 TR5/TR250 Engine stutters at 2500 Triumph 1
T tvr 2500 headers TVR 0
D TVR 2500-3000 V8 conversion TVR 3
K Why is my B engine idling at 2500? MG 1
B Post-War Other Is a TR6 diff and mounts the same as a 2500 saloon? Triumph 4
B Spitfire Has anyone fit a 2500 wiper motor to a spit mk1? Triumph 3
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
R Extra 948 and 1098 Engines Spridgets 9
S Spitfire Spitfire 1296 engines Triumph 1
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
TRMark Alfa 4cyl engines Other Cars 8
T Modern Oils for Our Flat Tappet Engines Austin Healey 26
T Modern Oils for Our Flat Tappet Engines Spridgets 7
T Which Morgan cars have British designed and built engines? Other British Cars 7
JimLaney HELP: Identifying Chasiss and Engines Spridgets 7
D Differences between BT7 and BJ8 engines. Austin Healey 12
alanjohnturner General TR New cranks for 4-pot engines Triumph 0
J New engines burning oil, Too much fuel? Triumph 14
E 1275 engines and some parts $$ Spridgets 2
aeronca65t Vizard talks about engines Spridgets 19
drambuie Strip cleaning frames engines and bodys Austin Healey 5
JamesWilson Engines dies when hot.... Spridgets 12
Don_Racine 48 Hours ONLY.. ENGINES and MORE Spridgets 0
58Custom People w/ MKIII Midgets & modded A or swap engines Spridgets 6
K TR2/3/3A What was best Spin Oil Filter for TR3 & 4 Engines? Triumph 9
I Top speeds for 948 and 1275 engines Spridgets 16
D Need help IDing A-series engines Spridgets 8
K Paging Andrew Mace: Re Spifire engines Triumph 1
T Mega-Squirt EFI [for A series engines?] Spridgets 6
