Mega-Squirt EFI [for A series engines?]
twas_brillig
Here is a note that I got from a buddy who has converted his early 70s BMW 2002 to Meqasquirt electronic fuel injection. The key item of interest for us folks with the A series engines with the siamesed intake ports is his observation that the new version looks like it'll work with our cylinder heads.
We have a '73 BMW 2002 with dual sidedraft Mikuni's that might be easier to convert to EFI than tune (when it comes home the highschool body shop in a year) and he and I have chatted and done some reading on various web-sites about going to EFI on a Bugeye (using either the SUs or a Weber DCOE as the throttle body), but that'll be a few years away as well. There's also a chap who builds machined aluminum EFI injectors that replace the tops of the larger SU carbs, but doesn't have anything for the smaller SUs that we use. Can't find his web-site at the moment, but his primary emphasis is on Triumphs, mostly the TR6 if memory serves.
Any uber-geeks out there that are wealthy and would care to do all the development work for the good of LBCs?
Doug
Hey guys, Finally It appears MegaSquirt V3 is out. Its a daughterboard upgrade, so I'll likely be applying it to my 2002, although it looks like the case is larger then my msII case.
https://www.ms3efi.com/
Features include (with my notes)
(Based on full featured MS3+MS3X+V3.57)
Speed-density, alpha-n or MAF for fuelling calculations
16x16 fuel tables in 0.1% steps with true interpolation and movable rows/columns
16x16 spark tables in 0.1 degree steps with true interpolation and movable rows/columns
---> This is great, as you can get better tuning with higer resolutions
Wall-wetting transient fuel control for better driveability
---> also brilliant, there was initally some code added to do this (x-tau). It actually adjusts for fuel sitting on the walls of the intake.
On board datalogging to SDcard (max 333Hz sample rate)
Tuning by serial or built-in USB-serial port.
8 channels sequential fuel (hi-z injectors or low-z with external resistors)
--> Probably the most important innovation yet. Having full sequential injection means you could tune for each cylinder. Not a huge deal on our 2002s, but on some strange british non-cross flow heads (like what the minis have) this is a big deal. Also nice for race cars where you can put the injectors far away from the throttle plate for better atomization.
2 additional fuel channels (hi-z or low-z)
8 channels sequential spark (logic level output)
--> This is cool. Must mean that you can do Coil on plug rather easily.
6 channels mid current output for small solenoids or relays
2 'spare' conditioned 0-5V analogue inputs (+2 more raw)
Two wideband oxygen sensor input (external controller required)
(Up to eight widebands supported via external data capture)
GM-style stepper idle control
2 and 3 wire PWM idle control
Closed loop idle control
Closed loop mixture control - ideally with wideband
Closed loop boost control
--> All three are brilliant, and I'm looking forward to the closed loop mixture control the most.
Various boost control systems (gear, time, speed based)
Two stage variable nitrous control
2 step type launch control
--> Launch control might be nice for standing start races?
CAN communications to interconnect other Megasquirt products e.g.
transmission controller
Supports external data capture boards (e.g. for external EGT boards)
EGT data support (with external amplifier)
Staged injection
Dual fuel (e.g. LPG)
Table switching, (mainly for dual fuel use)
Water/Meth injection
Individual cylinder injector trim
--> This is kind of a big deal, mainly for
racing or siamese port engines (hint doug). I was thinking for racing sometimes you get a slightly lean or rich cylinder due to underhood conditions (like how #4 sometimes will be different because its in the back with no flow around the head to cool things)
Injector phase timing
Individual cylinder spark trim
Support for numerous OEM trigger wheel patterns.
Magnetic (VR), Hall, Opto crank sensor input
Magnetic (VR), Hall, Opto cam sensor input
I'm really kind of excited over this, it seems MS has matured quite a bit.
I would think that the simplest method would be to use motorbike throttle bodies. If a pair of TB's will support 180+ HP on a Ducati they would do the same in one of our engines. There are a number of folks in the UK running Suzuki Hayabusa TB's also, even GSXR600's have been used with success. If you buy a set of 4 off a wrecked bike you can use the two outer ones and they already have TPS installed on the throttle shaft. Depending upon the chosen manifold you may not even have to alter the spacing.
I currently am running Megajolt and plan to go with the MegaSquirt system in the future for the drivability and tuneability.
Interestingly I was at a motorcycle shop today and the very first thing the guy said when he saw the carb was that I needed to get a Motorcycle Fuel Injection and do away with the carb. If I understood him correctly, he was talking about the merit of getting it from an older bike where the system was both more forgiving, simpler and self tuning. At that precise moment another employee started talking about his bike which he is converting to Megasquirt. I don't understand any of it but it sure sounds interesting.
A couple of years ago Practical Classics had two articles on FI for A series engines - I'm pretty sure I scanned them though I might have to dig out an old hard drive if anyone is interested.
You know a lot of people talk about all the supposed problems due to the siamesed ports on the A-series, but they seem to do pretty good with decent carbs. No reason that they should not do just as good if not better with FI. Sure it's not ideal, but it ain't a showstopper either. If a V8 can get away with an O2 sensor in each collector to read 4 cylinders with a Carb style throttle body and shared port intake runners why can't an A-series?
An A-series *should* work fine with throttle body style injection IF you have stock manifold with the balance tube AND you set your injectors to fire 4 times per cycle.
Doug would like to inject using his DCOE. The manifold has no balance tube, so the likely hood of one cylinder running rich the other lean is greater.
Sequential injection would be essential for any port injection set up and would be very helpful for the set up Doug would like to create.
Doug, I am an uber-geek, but far from wealthy. I have a stock 1275 manifold and carb set sitting on my work bench. If you wanted to go stock with your carbs, I could develop the fuel injection adapters for you if you were willing to pitch in for materials and supplies.
G Starting Mega squirt main board assembly Spridgets 16
Westfield_XI Alternative coil for MegaJolt/Squirt applications Spridgets 6
HealeyPassion AH Sebring/Ruddspeed EFI project car Austin Healey 6
HealeyPassion EFI AH testing/tuning remotely Austin Healey 2
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
F TR6 Patton EFI Triumph 1
I TR6 TR6 EFI Conversion Triumph 19
HealeyPassion AH EFI build... again Austin Healey 41
HealeyPassion EFI AH Initial Test Day... Austin Healey 6
Tremelune EFI, engine swaps, reliability... Spridgets 12
RAC68 Wedge TR7 - Anyone Convert from Carbs to EFI Triumph 6
Glen_B EFI Megasquirt help available Spridgets 37
Morris EFI for you Doug Spridgets 5
L Turbocharged, efi MG MIDGET. VROOM, whoosh, psssss Spridgets 19
S Wedge TR8 non EFI, Air Filters Triumph 2
S Wedge 1980 TR8 a/c non efi Triumph 19
HealeyPassion EFI Healey project Latest Austin Healey 14
HealeyPassion EFI Healey project Latest Austin Healey 3
Bret Bret's EFI Skunk Works hits a few speed bumps. MG 9
Glen_B EFI bugeye HP numbers Spridgets 4
Glen_B Here are some efi pics Spridgets 14
Glen_B EFI is FINISHED!! Spridgets 10
Glen_B Turbo EFI progress Spridgets 14
Glen_B Bugeye EFI progress Spridgets 10
Bret Up-date on Bret's MG Skunk Works EFI project MG 7
Morris Midget EFI: Opinions wanted Spridgets 15
Glen_B EFI progress Spridgets 5
Glen_B Megasquirt EFI on bugeye Spridgets 11
G Evante EFI Conversion Other British Cars 0
Morris Midget EFI pics Spridgets 8
Morris Midget EFI fuel pressure problem Spridgets 10
M 4CU EFI Module 3.5L Rover V8 1985 Marcos Mantula Rover / Land Rover 9
Bret Bret's EFI & O/D transmission MG 7
Bret Woo Hooo! Up-date on my EFI kit installation! MG 5
Bret Moss EFI kit and O/D tranny Latest thus far... MG 8
healeynut Healey EFI ... q's??? Austin Healey 7
R ALANA -- How's that EFI going? Triumph 14
Atrus Megasquirt EFI Question Spridgets 7
Morris Spridget EFI survey Spridgets 11
LastDeadLast Pinging Alana, EFI related Triumph 1
Morris AH Spares EFI Spridgets 3
A TR6 TR6 EFI - where do I start? Triumph 26
8 efi relay Jaguar 4
Bret Speaking of the Moss EFI kit MG 2
B Spitfire common EFI swaps for 1500 Spits? Triumph 5
Bret Moss EFI kit & other good news! MG 14
Bret MGB Moss Motors EFI for the MGB! MG 3
StagByTriumph Wedge TR7 EFI system on Ebay Triumph 7
Bret MGB MOSS's EFI kit for ZS MGBs MG 2
