Westfield_XI
Accel has an EDIS coil suitable for MegaJolt usage. It even has the same bolt pattern for mounting, that is, if you have a Ford coil now it will be a direct bolt on. The connectors on the coil are different from the OEM Ford in that they do NOT have to two locking clips, however they coil does make a bit more spark, or so they claim.
https://www.accel-ignition.com/ProductDet...xtSearch=140028
I am having Taylor Ignition, an Accel company make up custom wires for me since I do not want to have to wrestle with the boots and crimpers needed to make my own.
