Richter12x2
Almost have the GT6 ready to go, but the 42 year old mechanical pump isn't keeping up, so I was looking for an electric fuel pump to replace it.
I kept seeing recommendations for the Facet pump, and then the Carter (with a regulator). In both cases I would have to order it to get it in. So I went to see what my local O'Reilly Auto Parts store had that would do 2-3 PSI, and found this:
Looks like a dead ringer for the Facet pump that everyone seems to recommend. Enough that I suspect that it's the same pump being made with a Mr Gasket logo on it.
I'll give it a shot and see how it works.
Now, the post I found discussed using an oil pressure switch as an emergency fuel cut off. Is that a necessity or a nice to have, and are there any recommendations for one that will work?
