MGB Coil resistance
wkilleffer
Hello everyone,
My car's a 1974 MGB with an 18GK engine and twin HS4 carbs. I've been running a Pertronix distributor with its matching coil for awhile, but just got the car's 25D back from Jeff at Advance, and it looks better than what it probably did when it was new. I'm going to go back to using points and condenser with the rebuilt distributor.
I still have the factory Lucas coil that came with the car when I first obtained it. I checked the resistance to see if it was still useful, and here's what I found:
With a small handheld analog meter, it registered around 6700ohm across the secondary, and the little meter's not capable of giving a reading for the primary.
On the new-to-me Sears Engine Analyzer, the primary shows 5.6ohm and the secondary shows 5100ohm.
Either way, that looks too high given some of the other numbers I've seen. I haven't checked the Pertronix coil, but will sometime this weekend.
Am I right in believing this original coil shouldn't be used?
Thank you,
-Bill
Sarastro
For points, the coil primary should be 3-4 ohms and secondary around 10,000. Assuming that the analyzer is giving you correct readings, the coil is not what it should be.
Virtually all automotive coils have the ~3 ohm primary or lower. If that's a matching Pertronix coil, Pertronix must be into some weirdness that I'm not aware of. You can get a decent coil for $25, so the simplest solution is just to replace it.
Also, any cheapo digital multimeter should measure those resistances with reasonable accuracy.
Sarastro
Not always. If you have a ballasted coil, it PROBABLY has a resistance around 1.5 ohms and a ballast resistor of 1.5-2 ohms. But there exist coils with lower resistance, and higher ballast resistance. And, it's not all that critical. If the total resistance (coil + ballast) is between 3 and 4 ohms, you should be fine.
Lukens TR2/3/3A TR3A coil. Correct resistance? Triumph 6
NutmegCT Ignition coil resistance Triumph 8
B coil resistance ? MG 1
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
Cokerair TR4/4A Fried Ignition Coil Triumph 18
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
F Hot Ignition Coil Austin Healey 6
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
timsgolf Coil Wiring Austin Healey 20
K TR2/3/3A Front coil springs? Triumph 2
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
longbridgehealey Coil terminals Spridgets 1
P TR3B Coil Issue? Triumph 7
A Wedge Won't fire without jumper from coil to battery Triumph 6
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
JPSmit female spade tab - coil Restoration & Tools 13
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
Lin Lucas coil question Austin Healey 8
K What to do for coil bracket on upgraded generator? Austin Healey 8
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
JPSmit Daughter's VW - coil pack? Other Cars 2
S Intermotor or Lucas Sport Coil ? Austin Healey 14
FlyingCat Spitfire Spark to Coil Triumph 23
S TR2/3/3A Front coil spring recommendation? Triumph 7
S TR4/4A Coil-over suspension upgrade Triumph 4
JPSmit Bosch Coil question Spridgets 14
KVH TR4/4A Front Coil Spring Packing Piece Triumph 12
2 TR2/3/3A Coil issues Triumph 31
D coil spring finish Austin Healey 5
M TR4/4A Front coil springs.....Rating & Length? Triumph 1
M TR4/4A Rear coil springs for TR4A Triumph 4
Marla TR4/4A Pertronic coil Triumph 12
M TR4/4A TR4 front coil springs Triumph 0
M TR2/3/3A Why is my coil so hot? Triumph 6
Marvin Gruber Big healey coil springs Austin Healey 7
M Starter field coil for BN1 Austin Healey 17
KVH TR4/4A Front Coil Spring Spacers Triumph 1
S TR2/3/3A Coil wiring Triumph 4
wingsandwheels MGB 1979 MGB coil w/ altered wiring MG 6
JimTR4 TR4/4A Coil - easily confused... Triumph 6
T TR2/3/3A coil mounting bolt oil leak Triumph 2
2wrench TR6 What's for dinner? Fried Coil??? Triumph 4
Griz Coil Wiring Austin Healey 4
2billydavies TR2/3/3A dead battery... until i disconnect the wire from coil to distributor Triumph 10
J TR2/3/3A TR3 coil spring height Triumph 4
Y MGB 1977 MGB Ignition Coil and Wiring. MG 7
2 TR2/3/3A TR2 Coil choices Triumph 5
