Why not fix the ones that you have? SU pumps are simple and reliable, and the pump the correct volume and pressure. I think that Burlen(sp?)Fuel Systems(in England) makes replacement diaphragms and point sets, and that is about all that ever goes wrong with them.Rebuilding them is easy enough,once you figure out how to set up the points. The first pump might take a little while, but by the fourth pump, you will be an expert.
