Alternative Fuel Pump for a BT-7
Redleg6
Hello Gents:
Can one you provide me with the part number and brand for an alternative fuel pump for a BT-7? I searched the archives as I remember a thread identifying it a awhile ago but searched without successs. Thanks- Karl
Skip & Lynne
Hi Karl I have one of the small square pumps made by Facet on my car. I got it from NAPA and it works great but I had to isolate it with rubber mounts as it was quite noisy. Skip
DerekJ
Karl,
I have a Walbro pump on my car, no problems in 7 years, cheaper than the SU, and its never let me down. I'm curently away from home so can't help you with the part number. give them a call they are very helpful
Derek
www.healeysix.net /ubbthreads/images/graemlins/england.gif
Keoke
OK you guys with the non standard fuel pumps just make sure you have a ground wire run from the tank to the car chassis-Fwiw---Keoke
Dave Russell
Yoda - R.I.P
[ QUOTE ]
[/ QUOTE ]
Why?
Keoke
Generally when generic pumps are installed the Fuel line is cut and rubber sections are installed which breaks the Potential dedicated ground {The Fuel Line} between the tank and car chassis, I am not sactioning the path but it is safer than none-FWIW---Keoke
Dave Russell
Yoda - R.I.P
A ground from the "tank to the car chassis" is not going to ground the pump if there are rubber couplers. It might help the fuel gage sender but won't do anything for the pump. I do agree that a ground from tank sender to car chassis can help the reliability of the gage sender. Did you mean "from the pump to the car chassis? Pumps such as the Facet have two wires, either one of which can be grounded, depending upon the car polarity.
Hangtown Healey
Use the Facet pump that looks like a ignition coil. It is quiet and is an improvement on the old Bendix pump that has been around since the 50's or 40's. It was standard equipment on Alfa's and Ford GT's (used two) They are pretty darn long lasting. You can try it without a fuel regulator or not. It isn't as low as an SU, but close.
Skip & Lynne
Whooooooo Weeeeeeee I just went and bought a small Facet Posi Flow pump $39.95 at NAPA. It isn`t the big one that looks like the ignition coil. I got the one that has a 1 to 4 lb presure rating. I also got a small filter for the inlet side of the pump $3.85 and it is dead silent. I had the square metal one that sounded like a 30 cal machine gun even on rubber mounts. I will use it as a spare . I have the NAPA parts numbers if anyone wants them . Skip
gonzo
Running an aletrnative fuel pump, a German brand, for about 20+ years with no reported problems. It operates at the specified low pressure as indicated (4 -5 lbs.).
I also like the occasional rat-ta-ta-tat clicking on start-up: confirms "contact" before firing the beast up GONZO
[ QUOTE ]
[/ QUOTE ]
Roger that! Facet Interuptor type fuel pump. Available from places like Racer Parts Wholesale or Pegasus Auto Racing. I use a Holley regulator to feed the bank of 45 DCOEs @ 41.5" WC (1-1/2 PSI).
R GT6 Facet Fuel Pump Alternative [GT6] Triumph 4
coj Alternative fuel pumps Austin Healey 19
R Alternative Fuel Pumps for a 420 Jaguar 10
S Alternative Parts Suppliers Austin Healey 7
3798j Hydrogen...There is an Alternative Other Cars 10
red57 Alternative Healey Austin Healey 2
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
Michael Oritt Interesting audio alternative Austin Healey 2
Marla TR4/4A Alternative system... Triumph 8
T Speedhut [or alternative] gauges for a BJ7 Austin Healey 4
Got_All_4 TR2/3/3A Top of steering tube looking for alternative to felt Triumph 10
JimTR4 TR4/4A Alternative spare wheel Triumph 2
B Boot trunk seal alternative advice ? Austin Healey 15
HealeyRick Alternative Sound Systems Restoration & Tools 2
C Alternative Distributor Cap Austin Healey 3
D Cheap sure-shot alternative Spridgets 0
T TR6 TR6 - alternative linkage design? Triumph 4
RAC68 Alternative Remote Brake Booster Austin Healey 3
D Alternative engine/transmission compatibility Spridgets 72
Jim_Gruber Brake Master from Alternative Sources Spridgets 10
BobbyD TR6 TR6 and other TRs - Brake Light Switch Alternative Triumph 7
rkep01 Chrome alternative Spridgets 29
Johnny Here's a few alternative colors for AH.. Austin Healey 0
D Alternative Seats Spridgets 5
Coyote1 TR6 74 TR6 Front Turn Signal Alternative Triumph 9
Jim_Gruber Alternative Tranny Discussion Spridgets 7
The_architect Bugeye heater cable alternative Spridgets 26
JPSmit Dielectric Grease alternative Restoration & Tools 7
Westfield_XI Alternative coil for MegaJolt/Squirt applications Spridgets 6
UmmYeahOk Anyone Know of a Custom Auto Sound Alternative? Triumph 29
T Heater outlet seal alternative MG 3
R POR-15 alternative Triumph 25
SherpaPilot Slave Cylinder Plastic Pipe Alternative? Triumph 15
Dadandson Starter Solenoid Alternative Spridgets 3
Timd Front end rebuild + A-arm replacement alternative Spridgets 6
BritCarFan Mini alternator alternative? British Motor Corp 1
J Peal and stick stickers, alternative Triumph 7
A Grant steering wheel adapter and/or alternative?? Triumph 2
G alternative power MG 15
T Alternative wheels Triumph 12
Trevor Jessie alternative radiator Spridgets 12
kch Alternative carburettors on Healey Austin Healey 10
sultanoswing Alternative Alternator? MG 1
71tr Undercoating Alternative Triumph 1
A Spitfire Alternative Spit engine transplants Triumph 13
R TR2/3/3A Fuel pump? Triumph 16
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
