Soda blasting
jackq
While in Roswell this week I got crawling around the 47 Studebaker truck I bought and starting thinking about the best way to get it out of the cluster of cars its surrounded by and worked out a plan. Next...tires. 775 by 17 inch 8 ply bias....Hmmmm. Okay..online at $163 each, not bad. Later I noticed a local paper had been tossed up against the gate?? It was apparently a free copy saying subscribe now and get it half price for the first three months. Ok..opened it and there was an ad for a local company doing clean-ups and media blasting. Called them and told them I was a geezer and was tired of sanding. He has a total mobile unit and wiil come to the yard when I'm ready and do it right there. So the plan is I'll dismantle it right there and for about $600 it"ll be ready for resto. They also said to drag the 65 Mustang over and they'll do that as well.
ll
equiprx
You do know soda blasting will not remove rust?
PAUL161
Soda blasting has it's good and bad points! Bad point is, after the object that has been done, it should be washed with a special cleaning solution to remove all traces of the soda media/chemicals, but a type that doesn't cause the metal to flash. If any traces are left, it'll push the paint. I personally won't use it on a car body, but that's just me. I won't sand blast either as sand blasting causes a high heat build up on thin metal if your not extremely careful, thus causing warping. I only sand blast chassis. I strip my car bodies by either having them dipped or using an aircraft grade stripper. Naturally the self stripping is a lot of work, but you never damage the metal underneath. JMHO. PJ
TomMull
Any thoughts on plastic media? Had a friend who used glass and (I think) acrylic meadia on airplanes, apparently with no damage to the aluminum skin.
Tom
wangdango Soda blasting body panels? Austin Healey 12
J special equipment for soda blasting? Triumph 15
beaulieu Need bulk soda [50-100lb bag] for soda blasting ? Restoration & Tools 6
V Bugeye Sprite TV commercial [Sprite soda] Spridgets 3
V Austin Healey Bugeye Spite TV commercial [Sprite soda] Austin Healey 0
aeronca65t Home Brew soda blaster Restoration & Tools 5
HealeyRick DIY Carb Cleaning Soda Blaster Austin Healey 2
M_Pied_Lourd Off To The Soda Blaster Tomorrow Triumph 21
TR6oldtimer Soda Blaster for my Carbs Triumph 45
B Sand Blast vs. Soda blast? Spridgets 13
M Sandblast, Soda, Dip, or elbow grease? Restoration & Tools 7
1 Soda blast or sand blast? Austin Healey 3
B After bead blasting the body I noticed some interesting things… Spridgets 2
red57 Metal prep of chassis after repairs and shot blasting Austin Healey 5
JimLaney Media blasting engine parts - How to clean? Spridgets 5
D My Sand blasting setup Restoration & Tools 5
kennypinkerton Tractor Supply Blasting cabinet. Restoration & Tools 6
R Media blasting a Bugeye body Spridgets 8
R Media Blasting a Bugeye Body Austin Healey 7
J Upgrade to blasting cabinet Restoration & Tools 7
B Sand blasting trunk deck BAD,________? GOOD? Triumph 11
R Sand blasting Spridgets 16
A question about media blasting and engine paint. Austin Healey 14
G Which blasting media to polish? Spridgets 1
T Air compressor min CFM for media blasting Triumph 14
kurts100 Dipping vs. Blasting a Bugeye Spridgets 12
I TR6 TR6 wheel blasting/painting Triumph 6
E Body Blasting and Mechanical Work Triumph 9
rlandrum Media Blasting - What to use Triumph 16
LarryKerr Blasting and Welding needed in Greater Atlanta MG 4
S Media blasting Spridgets 14
73Midget Blasting Cabinet Restoration & Tools 8
timbn2 Definitive Answer on Media Blasting, Please... Austin Healey 10
B Media Blasting Austin Healey 5
W compressor revisited - painting &blasting. Restoration & Tools 9
Cain Blasting Media Triumph 2
1 Media blasting experience? Spridgets 11
John Loftus media blasting report Austin Healey 10
